TypeError: Error #1006: value is not a function.
Guest
Jul 07, 2010 Jul 07, 2010
I'm getting this error:
    at project_fla::MainTimeline/createMap()
    at project_fla::MainTimeline/frame1()
heres the actionscript:
function createMap(target:Object, map:Array, tilesize:Number):void {
    for (var ix:Number=0; ix<map[0].length; ix++) {
        for (var iy:Number=0; iy<map.length; iy++) {
            this["t"+String(ix)+"x"+String(iy)] = new Object();
            this["t"+String(ix)+"x"+String(iy)] = new tile();
            this["t"+String(ix)+"x"+String(iy)].gotoAndStop(map[ix][iy]);
            this["t"+String(ix)+"x"+String(iy)].x = Flxy(new Point(ix,iy), tilesize).x;
            this["t"+String(ix)+"x"+String(iy)].y = Flxy(new Point(ix,iy), tilesize).y;
            target.addChild(this["t"+String(ix)+"x"+String(iy)]);
{/A]
What's wrong with the code?
ActionScript
14.2K
Deleted User
There ya go. You have to give your clip on stage an instance name -when you select the clip - the instance name is the field above the instance behavior dropdown at the very top of the properties panel...
Guest
oh, heres the other function being used in that function. its in frame1 aswell
function Flxy(p:Point, s:Number):Point {
    return new Point(s*(p.x-p.y)/2,s*(p.x+p.y)/4);
Guest
In Publish Settings > Flash Tab in the Advanced section check Permit Debugging - that will tell the line number of the error... I don't see anything at first glance. Although, I'm not sure why you have:
You can omit the new Object line...
Guest
I forgot to emit that line.  It was a test of mine to try and get rid of the error but it didn't work .
It's gone now.
the line with the error is this:
line 88: target.addChild(this["t"+String(ix)+"x"+String(iy)]);
Guest
In a quick test that line seems to work OK for me... I think you can much simplify this though - something like so:
    var t:tile;
            t = new tile();
            t.name = "t" + String(ix) + "x" + String(iy);
            t.gotoAndStop(map[ix][iy]);
            t.x = Flxy(new Point(ix,iy), tilesize).x;
            t.y = Flxy(new Point(ix,iy), tilesize).y;
            target.addChild(t);
Guest
I put in your code instead. Thanks for that .  Still getting the error tho.
target.addChild(t);
is giving me an error for some reason.  It's driving me crazy.
Guest
What is target?
Guest
target is a movieclip on the stage called "g".
createMap(g, array, 40);
Guest
Outside of your function can you just do: g.addChild(new tile());  ?
Guest
I just found out that it works when i use:
createMap(this, array, 40);
however,
i need to addChild into that g movieclip
Guest
when i try that outside the function it says
1061: Call to a possibly undefined method addChild through a reference with static type String.
does it think g is a string?
Guest
Guest
hm.  it has an instance name g... in-fact all the other functions using that target work
i changed the instance name to "game" instead and used that same name in all the preceding functions and it works fine now.
i didn't define "g" anywhere else so it still confuses me. lol
but as long as it's working.  Thank you
