Good day,
I want two tables when they grow to be the same height, The tables are next to each other.
I have this code under the add new row button :
var
subformIndex = this.parent.parent.parent.index;
OutputReviewMainTable.OutputMainTable.Row1.instanceManager.addInstance(1);
var
rows = xfa.resolveNodes("Scorecard.Page1.flowedHorzontal.OutputReviewMainTable.OutputMainTable.Row1[*]");
var
tableH = 0;
for
(var i = 0; i < rows.length; i++){
tableH
= tableH + xfa.layout.h(OutputReviewMainTable.OutputMainTable.Row1, "mm");
xfa.resolveNode("Scorecard.Page1.flowedHorzontal["
+ subformIndex + "].OutputReviewTables.OutputSPOTable.Row1.Output_Rev_Objective").h = tableH + "mm";
this code works perfectly under the AddNewRow button, it helps the two tables grow equally, that is they have the same height. I tried putting the same code under the initialize event, so that when the xml populates the two table rows,they have the same height, but its like I didnt do anything.
Is there a way for me to solve this problem, please help me, I've now run out of ideas.
Ace
Total Likes
When you add that code to the Initialize you will probably have to force a lyout to occur (this layout happens automatically when you add a row). So try adding the command xfa.layout.relayout() to the end of your initialization script.
Paul
Total Likes
I just tried it, the tables still behave the same.
Total Likes
If you send your form to LiveCycle8@gmail.com I will have a look and see if I can figure out why itis not behaving.
Paul
Total Likes
Thanks Paul, I've mailed it.
Total Likes
