I have a query of a table of data.. I have another identical table (same fields) that I need to transfer the all the data associated with a client ID and insert it into another table. Than, remove the data from the 1st table.
Story: a client enters transacations into a database table called "open". At the end of the day, he/she will run the query - print a report and click a "close" button that I need to take this data in "open" and insert it into "closed". table.
Thanks for your help.
The syntax you want is:
insert into sometable
(field1, field2, etc)
select value1, value2, etc
from wherever
In you specific case, why don't you have just one table? You could have a field called status that you simply update.
Thanks Dan. (that's one of my best friends name)
I do have a field for an "update" but I need to send this data over to a table to export for another client/owner.
<insert into possales (library_id, salesdate, total)
select library_id, salesdate, total from todaysales>
After I sent the data over to this .cfm page, I checked the database and it wasn't updated or data inserted.
FYI: I am using an access database too.
How many records should have been copied? What happens if you run that same query in access?
No records were copied. I am just wondering if I have the wrong statement. This gets frustrating.. Seriously, what is the big deal with an insert statement. I used a CF insert instead of just a insert.
I actually was using a insert and I put a CFinsert and got this error:
Invalid token ( found on line 1 at column 25. | |
The CFML compiler was processing:
The error occurred in xxxxxxxxxxxxxxxxxxxxx\sitesample\processsystembatch.cfm: line 1 | |
1 : <CFinsert into sales(id, salesdate, provider) 2 : select id, salesdate from batchsales> 3 : |
Don't use <cfinsert>, as it has a specific purpose and that purpose is not what you're trying to do.
Use <cfquery>.
Adam
Guys: I have to be an idiot. I cannot seem to get this straight. Can someone just correct this code I have PLEASE !!
From table called TodaySales and Insert data in WeekSales
I have a record called Total in both tables. So how do I do this?
Thanks guys and sorry to be "begging" for this...
Hi
Try out this and let me know
<cfquery datasource="mysite" name="copytable">
INSERT INTO WeekSales
(Total)
select Total from TodaySales
</cfquery>
replace datasource name "mysite" with your datasource name
thanks
Thanks... this did work... BUT... can I use a WHERE statement with this??
In other words: can I do a insert for a specific sales date? Kinda like this but it doesn't work:
INSERT INTO TodaySales
(phone)
select phone from users
WHERE salesdate = todaysdate
</cfquery>
One of these tables will have all of the sales but I don't want to take ALL of the sales in this table and insert into another table.
You say it doesn't work. What actually happens?
Error Executing Database Query. | ||||||||
[Macromedia][SequeLink JDBC Driver][ODBC Socket][Microsoft][ODBC Microsoft Access Driver] Syntax error (comma) in query expression '(partynumber,totalbill,foodsales,drinksales)'. | ||||||||
The error occurred in\sitesample\processsystembatch.cfm: line 9 | ||||||||
7 : select (partynumber,totalbill,foodsales,drinksales) from foodsales 8 : 9 : where #our_id# = #our_id# 10 : 11 : </cfquery> | ||||||||
I'm sure you noticed the logic error in your where clause, but, looking for the syntax error, what happens if you run this?
select (partynumber,totalbill,foodsales,drinksales) from totalsales where 1=2
What happens if you try it without the brackets?
I used the # # for the varibles past. I did a where 123 = 123
and I get the same results. I didn't realize what I was trying to do would be so difficult.
You don't need the parens around the list of fieldnames in the SELECT part of the statement. Yes, you can put a WHERE clause at the end of the whole thing.
So in this case the "where" should work:
(Total)
(phone)
</cfquery>
Wolfgang
You cannot do two INSERT INTO/SELECT FROM statements in one CFQuery tag. Try this:
<cfquery>
INSERT INTO WeekSales ( Total )
SELECT <whatever> from <table>
WHERE <something> = <something else>
</cfquery>
Then do the TodaySales
<cfquery>
INSERT INTO TodaySales ( Total )
</cfquery>
CFQuery does not work with multiple commands being run at once.
Re: Insert from one table into another - I searched ..You cannot do two INSERT INTO/SELECT FROM statements in one CFQuery tag. Try this:
<cfquery>
</cfquery>
<cfquery>
</cfquery>
Thank´s Owain for the patient correction
Wolfgang
my sites PKV
PKV Vergleich
