An Air project that was working fine with FB4 is no longer working after the upgrade to FB 4.0.1 (277662). No idea what's going on here...
VerifyError: Error #1014: Class IIMEClient could not be found.
at flash.display::MovieClip/nextFrame()
at mx.managers::SystemManager/deferredNextFrame()
at mx.managers::SystemManager/preloader_preloaderDocFrameReadyHandler()
at flash.events::EventDispatcher/dispatchEventFunction()
at flash.events::EventDispatcher/dispatchEvent()
at mx.preloaders::Preloader/timerHandler()
at flash.utils::Timer/_timerDispatch()
at flash.utils::Timer/tick()
This is a known issue, refer to the bug http://bugs.adobe.com/jira/browse/SDK-26376
If you believe you still should be using 1.5.3 in 4.1 SDK, you can re-open the issue and track it.
-Sunil
That helped a lot (with air 1.5.3)! Thank you very much.
Actually I didn't know what the correct namespace for air 2 was. So I decided to remain on 1.5.3 for the time being.
But there is no reason to stay on that as I now found the correct settings:
<application xmlns="http://ns.adobe.com/air/application/2.0">
And with that it works without your workaround.
