1. Re: AVConversionConvertToPDF and EPS file format
Bernd Alheit Jul 9, 2010 4:16 AM (in response to joeln3)Is there a way to convert an EPS file to PDF?
Use the Acrobat Distiller.
2. Re: AVConversionConvertToPDF and EPS file format
joeln3 Jul 9, 2010 6:27 AM (in response to Bernd Alheit)Thanks Bernd for you answer. Thus I have another question : is the distiller ever installed with Acrobat?
Thanks in advance,
Joe
3. Re: AVConversionConvertToPDF and EPS file format
Bernd Alheit Jul 9, 2010 6:53 AM (in response to joeln3)is the distiller ever installed with Acrobat?
Yes.
4. Re: AVConversionConvertToPDF and EPS file format
joeln3 Jul 9, 2010 6:57 AM (in response to Bernd Alheit)OK, thanks.
5. Re: AVConversionConvertToPDF and EPS file format
lrosenth Jul 9, 2010 9:13 AM (in response to joeln3)Should work just fine with PS and EPS. What error(s) are you getting back from your call?
6. Re: AVConversionConvertToPDF and EPS file format
lrosenth Jul 9, 2010 9:14 AM (in response to joeln3)Distiller is always installed with Acrobat - but you'll have more API control with the AVConversion APIs.
7. Re: AVConversionConvertToPDF and EPS file format
joeln3 Jul 11, 2010 11:38 PM (in response to lrosenth)Hello Leonard,
Actually the result is an Acrobat crash. Here is the crash message :
Problem signature:
Problem Event Name: APPCRASH
Application Name: Acrobat.exe
Application Version: 9.3.3.177
Application Timestamp: 4c1d77c5
Fault Module Name: ADMPlugin.apl
Fault Module Version: 9.3.3.177
Fault Module Timestamp: 4c1d1f78
Exception Code: c0000005
Exception Offset: 000549f5
OS Version: 6.0.6002.2.2.0.256.6
Locale ID: 2060
Additional Information 1: 1e38
Additional Information 2: e55e043791c04a058f1d7ac712eac3a4
Additional Information 3: fcc8
Additional Information 4: 5b51d2afad257b7effa403c01ee041e9I use the AVConversionConvertToPDF(kAVConversionNoFlags, asPath, ASGetDefaultFileSys(), pdDoc, oAVStatusMonitorProc) method to convert the eps file to pdf and it crashes. Using a bmp it works fine.
Do you have an idea why it doesn't work?
Thanks in advance,
Joe
Edit : I also tried using the AVConversionConvertToPdfWithHandler() method with the AVConversionToPdfHandler = "com.adobe.acrobat.ps" and it doesn't work. I use the *ps handler because I read that I have to use it for EPS. But I don't remember where I read it...
8. Re: AVConversionConvertToPDF and EPS file format
lrosenth Jul 12, 2010 4:30 AM (in response to joeln3)Offhand, no - sounds like a definitely bug. I'd report it as such.
9. Re: AVConversionConvertToPDF and EPS file format
joeln3 Jul 13, 2010 1:42 AM (in response to lrosenth)Actually the conversion works fine with another plug-in so I don't know why it crashes in my current application...
I use the SDK 8.2.
For information this was an earlier discussion concerning the AVConversion http://forums.adobe.com/message/2126967#2126967
that's where I read that I had to use the *ps conversion for eps
10. Re: AVConversionConvertToPDF and EPS file format
joeln3 Jul 13, 2010 4:49 AM (in response to joeln3)Leonard, I think that the problem came from my code. Now it work!
Thanks again,
Joe
