1. Re: CS4: Converting AVCHD to DV-AVI Type II - what's your tool / approach?
able123 Jul 5, 2010 7:05 PM (in response to Christopher Duncan)Hi,
Did you look at Jeff Bellune's tutorials ? Maybe one would suit you...
http://www.bellunevideo.com/tutlist.php
In other words, if I dropped an .mts file on a timeline in Premiere and then exported it to AVI / NTSC DV Widescreen (or some other such setting), would this give me the same results, i.e. a native DV-AVI Type II file?
That could work OK...and you can choose uncompressed if you want better quality AVI...but file will be bigger
Rod
2. Re: CS4: Converting AVCHD to DV-AVI Type II - what's your tool / approach?
Christopher Duncan Jul 5, 2010 7:27 PM (in response to able123)Hi, Rod.
Good stuff, appreciate the link.
While it would be nice if I could find a suitable program to just batch convert the files, I don't seem to be having much luck on that front. It's a bit more of a workflow hassle to step it through Premiere -> Media Encoder in order to get the initial raw SD footage that I want to edit, but on the bright side it does seem to be the path of maximum control in terms of the quality of files I end up with for editing. So maybe that's the way to go.
Thanks, man.
Chris
3. Re: CS4: Converting AVCHD to DV-AVI Type II - what's your tool / approach?
JSS1138 Jul 5, 2010 9:51 PM (in response to Christopher Duncan)I'd recommend just getting the faster ponies.
4. Re: CS4: Converting AVCHD to DV-AVI Type II - what's your tool / approach?
Christopher Duncan Jul 6, 2010 4:18 AM (in response to JSS1138)function(){return A.apply(null,[this].concat($A(arguments)))}
Excellent suggestion. Can I borrow your checkbook for a moment? ;-)
6. Re: CS4: Converting AVCHD to DV-AVI Type II - what's your tool / approach?
Christopher Duncan Jul 9, 2010 5:55 AM (in response to JSS1138)function(){return A.apply(null,[this].concat($A(arguments)))}
JSS1138 wrote:
And you thought just buying a high-def camera was all you needed...
I once saw a bumper sticker that said, "A boat is a whole in the water, into which you pour money."
I'm sure there's an analogy for computers in there somewhere.
7. Re: CS4: Converting AVCHD to DV-AVI Type II - what's your tool / approach?
Harm Millaard Jul 9, 2010 9:06 AM (in response to Christopher Duncan)Was that not intended to be HOLE without the W from water?
8. Re: CS4: Converting AVCHD to DV-AVI Type II - what's your tool / approach?
Christopher Duncan Jul 9, 2010 9:12 AM (in response to Harm Millaard)An object lesson, boys and girls.
Never type until you've consumed a sufficient quantity of caffiene.
9. Re: CS4: Converting AVCHD to DV-AVI Type II - what's your tool / approach?
Bill Hunt Jul 9, 2010 11:50 AM (in response to Christopher Duncan)I have been known to say about the same thing - and all too often...
Hunt
