I'm sure this has come up before, but I can't locate the definitive answer.
I am using RH8 and have a merged WebHelp system containing a parent projects and 10 or so child projects. Previously, when I generated the WebHelp projects, I selected the Mark of the Web check box for the parent and all the children. Everything seemed to work fine.
Now, I've been asked to create a new child project with links to a large number of PDF files. After reviewing the documents on this forum, I realized I needed to (1) unselect Mark of the Web to see the PDFs in the generated output and (2) change my IE settings to Allow Active Content to Run from Files on PC. Unfortunately, while I can now see PDFs just fine, my merged help is no longer working correctly--the link from the parent topic to a project generated w/o Mark of the Web no longer works. That is:
If Mark of Web selected:
PDFs don't work
merged help does
If Mark of Web not selected:
PDFs work
merged help does not
How can I make everything work?
Thanks.
Are you testing locally?
Have you tried after publishing to the server? If not do so as that will likely make the difference.
it's working now. Turns out I hadn't regenerated all of the projects and the parent after unselecting Mark of the Web.
