I need to create a form that is going to contain some text fields, check boxes, radio buttons and also a possibility of list menus with ability to multi select elements from it. I would like to have all the information displayed on one "main" text field at the botton of the form separated by commas and one space (eg. name, last, school, etc ). Can someone please help me or even let me know if it is even possible.
Sincerely,
Alex
Total Likes
Yes it is possible .....do you want the information to appear as you are filling the fields or do you want it as a single operation at the completion of the form? Usually the user clicks a button (submit, email, complete or something like that) to indicate that they are finished filling the form. We coudl put the code on that operation.
It might be easier for you to email me the form and I will add the code for the 1st few fields (to give you the idea) then you coudl complete it.
You can send it to LiveCycle8@gmail.com ....please include a description of what you want to do in the email.
Paul
Total Likes
could you please post some information on the forums about how this problem was solved. It sounds similiar to mine
I have about 45 text fields that can optionally be filled out by the user. Each one only allows a single character and should auto tab to the next one as the user goes along.
As each one is filled out, they appear in another box at the bottom of the form creating one long string.
I have gotten this to work with this.rawValue = a.rawValue + b.rawValue + etc
The problem with the above code, is that the larger field calculates as you go along the form. I have nulls showing up since the fields are not filled untill later.
Total Likes
Could you wrap it in an "if"?
if (a.rawValue != null) then this.rawValue = this.rawValue + a.rawValue;
if (b.rawValue != null) then this.rawValue = this.rawValue + b.rawValue;
If it were an array you could use looping.
Total Likes
Likes
Likes
