I'm running a volume licensed version of Flash Builder 4 part of the CS5 Web Premium suite. After updating to Flash Builder 4.0.1, it now loads as Flash Builder Standard. Is that just the title that is showing incorrectly on the start screen and about page, or have I somehow magically been downgraded from Premium to Standard?
Thanks.
It's magic. Lucky guy. Actually, I went through this a bit. You can tell if it's really premium if you can use the profiler or flexunit perspective, I believe. Anyway, it took me a couple tries so that I had to uninstall cs4, reinstall flex premium, then reinstall cs5 making sure that it 'recognized' that flex was already installed, as it should indicate that before you install cs5.
I'm definitely downgraded to standard. When I go to Flex Unit it tells me I need a Premium license.
So far this has happened on 2 computers. One (win XP sp3) with Flash Builder pre-installed and then CS 5 installed and one (Windows 7 Home Premium 64-bit) with no Abode products installed until all of CS 5 was installed. It can`t just be you and I who have experienced this.
Never mind. I just checked the CS5 Web Premium site and it says it comes with Flash Builder Standard (not Premium)...Odd how it opened as the Premium version prior to the 4.0.1 upgrade though.
Right. That's why we had to install FB premium first so it won't install the standard version during the cs5 installation.
