1. Re: CS5, 10.6.4, Nvidia 10.6.3 extensions, No Crash
Was DYP Jul 9, 2010 5:50 AM (in response to Was DYP)Disclaimer: For what every reason space between paragraphs get striped out when this is posted. I guess this is the best you'll get.
Doyle
2. Re: CS5, 10.6.4, Nvidia 10.6.3 extensions, No Crash
davisdont Jul 9, 2010 4:44 PM (in response to Was DYP)hi, how's it running- is it still good?
i found i could buy a few hours after messing with the kexts but nothing long term.
only going back to 10.6.2 made me stable again
3. Re: CS5, 10.6.4, Nvidia 10.6.3 extensions, No Crash
Was DYP Jul 9, 2010 5:06 PM (in response to davisdont)No problem yet and I just got done working with 2 multilayered psd files with type layers. Really stable and snappy since the 10.6.3 extensions were put into 10.6.4.
Are you sure your problems are not font related. I don't why Apple keeps insisting on shipping and installing with every update, bad fonts. Maybe to make Adobe look bad?
I would strip every font out in the Library/Fonts and System/Library/Fonts folders that the OS will allow. That is what I always do after every OS update and I have had no trouble with CS4 either. Always clean font caches and reboot when you do this.
Doyle
4. Re: CS5, 10.6.4, Nvidia 10.6.3 extensions, No Crash
davisdont Jul 9, 2010 5:30 PM (in response to Was DYP)excellent! really pleased it's working for you, and it gives me hope to know it's possible!
i'll give it another go, it's definitely the gpu issue, log's full of opengl exceptions
big best!
5. Re: CS5, 10.6.4, Nvidia 10.6.3 extensions, No Crash
Andre Schneider Jul 17, 2010 9:42 AM (in response to Was DYP)Any instructions on how to do to go back to the 10.6.3 estensions? I only found instructions on how to go back to full 10.6.3
Andre
6. Re: CS5, 10.6.4, Nvidia 10.6.3 extensions, No Crash
Was DYP Jul 17, 2010 10:06 AM (in response to Andre Schneider)I keep disc image (dmg) backups of previous OS version partitions that I can mount and copy the extensions from. And that is what I did.
You do have to, or you should anyway boot from another partition to do the copying. You might be able copy to the partition you booted from but I have never tried that. I don't every do OS updates to the partition I am booted into either.
Doyle
7. Re: CS5, 10.6.4, Nvidia 10.6.3 extensions, No Crash
Andre Schneider Jul 17, 2010 10:23 AM (in response to Was DYP)Hi Doyle,
Do you have OpenGL available after you went back on your drivers? I tried downgrading the drivers on mine but now Photoshop doesn't see the OpenGL on my card.
Thanks in advance for the help!
Andre
8. Re: CS5, 10.6.4, Nvidia 10.6.3 extensions, No Crash
Was DYP Jul 17, 2010 11:31 AM (in response to Andre Schneider)Yes OpenGL is available to me and works the same as it did in 10.6.3.
9. Re: CS5, 10.6.4, Nvidia 10.6.3 extensions, No Crash
davisdont Jul 17, 2010 11:59 AM (in response to Andre Schneider)try booting into safe mood (hold down shift while booting) it'll rebuild the kext cashe , reboot again normally and you should find stuff fixed and hopefully get open gl back
10. Re: CS5, 10.6.4, Nvidia 10.6.3 extensions, No Crash
Jeffrey Tranberry Jul 17, 2010 1:37 PM (in response to davisdont)Mac OS X 10.6 Help: Reverting to a previous Mac OS X version
http://docs.info.apple.com/article.html?path=Mac/10.6/en/15216.html
