I'm trying out the ORM CFC Wizard from a table in my RDS Dataview. When I do this I get the option to select where I want the CFC created and the checkbox to create the CFC in script.
Once I click OK, the next screen is blank.
I've searched through the forums and found some suggestions of turning off debugging and renaming all references to "Framework" to "framework".
I've made sure debugging is turned off and went through and made sure all references to "Framework" are all lowercase with no luck.
Has anyone been able to fix this issue with success?
I'm running CF 9 on JBOSS 5.2 on OS X 10.6.3 if that helps any. RDS works fine as I can see my datasources.
One thing I noticed, if I refresh the ORM Wizard screen it does generate a premature end of file error on the XML. But this error doesn't happen on the first try.
Ben
Hello,
Did you ever resolve this issue...I am having the same problem.
Mac OS X 10.6
Coldfusion builder 1 with update 1
When I right-click "Reload" I get a big dump:
coldfusion.xml.XmlProcessException: An error occured while Parsing an XML document. at coldfusion.xml.XmlProcessor.parse(XmlProcessor.java:183) at coldfusion.runtime.Cast._Xml(Cast.java:1345) at coldfusion.tagext.validation.CFTypeValidatorFactory$CFXMLValidator.validate(CFTypeValidatorFactory.java:425) at coldfusion.runtime.UDFMethod.validateValueType(UDFMethod.java:182) at coldfusion.runtime.UDFMethod._validateArg(UDFMethod.java:1072) at coldfusion.runtime.UDFMethod._validateArg(UDFMethod.java:1089) at cfRequestProcessor2ecfc1904329852$funcPARSEREQUEST.runFunction(/Library/WebServer/Documents/Adobe CFC Generator/handlers/framework/RequestProcessor.cfc:14) at coldfusion.runtime.UDFMethod.invoke(UDFMethod.java:472) at coldfusion.filter.SilentFilter.invoke(SilentFilter.java:47) at coldfusion.runtime.UDFMethod$ReturnTypeFilter.invoke(UDFMethod.java:405) at coldfusion.runtime.UDFMethod$ArgumentCollectionFilter.invoke(UDFMethod.java:368) at coldfusion.filter.FunctionAccessFilter.invoke(FunctionAccessFilter.java:55) at coldfusion.runtime.UDFMethod.runFilterChain(UDFMethod.java:321) at coldfusion.runtime.UDFMethod.invoke(UDFMethod.java:517) at coldfusion.runtime.TemplateProxy.invoke(TemplateProxy.java:495) at coldfusion.runtime.TemplateProxy.invoke(TemplateProxy.java:354) at coldfusion.runtime.CfJspPage._invoke(CfJspPage.java:2301) at coldfusion.tagext.lang.InvokeTag.doEndTag(InvokeTag.java:375) at coldfusion.runtime.CfJspPage._emptyTcfTag(CfJspPage.java:2723) at cfORMManager2ecfc1990215907$funcLOADTABLES.runFunction(/Library/WebServer/Documents/Adobe CFC Generator/handlers/framework/ORMManager.cfc:265) at coldfusion.runtime.UDFMethod.invoke(UDFMethod.java:472) at coldfusion.runtime.UDFMethod$ReturnTypeFilter.invoke(UDFMethod.java:405) at coldfusion.runtime.UDFMethod$ArgumentCollectionFilter.invoke(UDFMethod.java:368) at coldfusion.filter.FunctionAccessFilter.invoke(FunctionAccessFilter.java:55) at coldfusion.runtime.UDFMethod.runFilterChain(UDFMethod.java:321) at coldfusion.runtime.UDFMethod.invoke(UDFMethod.java:517) at coldfusion.runtime.TemplateProxy.invoke(TemplateProxy.java:495) at coldfusion.runtime.TemplateProxy.invoke(TemplateProxy.java:354) at coldfusion.runtime.CfJspPage._invoke(CfJspPage.java:2301) at coldfusion.tagext.lang.InvokeTag.doEndTag(InvokeTag.java:382) at coldfusion.runtime.CfJspPage._emptyTcfTag(CfJspPage.java:2723) at cflayoutpage2ecfm1151129293.runPage(/Library/WebServer/Documents/Adobe CFC Generator/handlers/layoutpage.cfm:37) at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:231) at coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:416) at coldfusion.runtime.CfJspPage._emptyTcfTag(CfJspPage.java:2722) at cfApplication2ecfc1209604170$funcONREQUEST.runFunction(/Library/WebServer/Documents/Adobe CFC Generator/handlers/Application.cfc:84) at coldfusion.runtime.UDFMethod.invoke(UDFMethod.java:472) at coldfusion.runtime.UDFMethod$ReturnTypeFilter.invoke(UDFMethod.java:405) at coldfusion.runtime.UDFMethod$ArgumentCollectionFilter.invoke(UDFMethod.java:368) at coldfusion.filter.FunctionAccessFilter.invoke(FunctionAccessFilter.java:55) at coldfusion.runtime.UDFMethod.runFilterChain(UDFMethod.java:321) at coldfusion.runtime.UDFMethod.invoke(UDFMethod.java:220) at coldfusion.runtime.TemplateProxy.invoke(TemplateProxy.java:490) at coldfusion.runtime.TemplateProxy.invoke(TemplateProxy.java:336) at coldfusion.runtime.AppEventInvoker.invoke(AppEventInvoker.java:88) at coldfusion.runtime.AppEventInvoker.onRequest(AppEventInvoker.java:280) at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:338) at coldfusion.filter.RequestMonitorFilter.invoke(RequestMonitorFilter.java:48) at coldfusion.filter.MonitoringFilter.invoke(MonitoringFilter.java:40) at coldfusion.filter.PathFilter.invoke(PathFilter.java:87) at coldfusion.filter.LicenseFilter.invoke(LicenseFilter.java:27) at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:70) at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:28) at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38) at coldfusion.filter.NoCacheFilter.invoke(NoCacheFilter.java:46) at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38) at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22) at coldfusion.filter.CachingFilter.invoke(CachingFilter.java:53) at coldfusion.CfmServlet.service(CfmServlet.java:200) at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:89) at jrun.servlet.FilterChain.doFilter(FilterChain.java:86) at coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringServletFilter.java:42) at coldfusion.bootstrap.BootstrapFilter.doFilter(BootstrapFilter.java:46) at jrun.servlet.FilterChain.doFilter(FilterChain.java:94) at jrun.servlet.FilterChain.service(FilterChain.java:101) at jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:106) at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42) at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:286) at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:543) at jrun.servlet.jrpp.JRunProxyService.invokeRunnable(JRunProxyService.java:203) at jrunx.scheduler.ThreadPool$DownstreamMetrics.invokeRunnable(ThreadPool.java:320) at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:428) at jrunx.scheduler.ThreadPool$UpstreamMetrics.invokeRunnable(ThreadPool.java:266) at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
I'm having the same problem on CF Builder as a plugin to Flash Builder 4.
Running standalone CF Builder, it works fine.
Does anyone have an answer for this?
I'm having the same issue.
I get the prompt to select a location and if I want a script-based cfc... after that, it's blank. If I right-click and reload the content, I get this:
http://screencast.com/t/okhY2hjbS9
This is on a standalone CF Builder install on Mac OS. I've tried an uninstall and reinstall, all without luck.
Ben
Oddly, it works for me within Flash Builder 4 after I installed ColdFusion Builder as a plugin, but still won't work in CF Builder.
I'm giving up on ORM for now anyway, it's been a pain to use it for all but the simplest things, and there's so little documentation available that it seems hopeless for now. I spent hours trying to get a create operation to work with an identity column in Sql Server, to no avail.
I too experienced the blank ORM generator UI on my Mac, but there was an easy fix for me.
In ColdFusion Builder
After doing this I was able to create ORM cfc files as expected.
Hope that helps.
G
Wow, This worked for me. Thanks!
Hey thanks for pointing that out! In my case, it was by UNchecking "use mozilla" that did the trick, and showed me why it was working in FB and not CFB.
Thanks again,
Jack
