Hi
I am trying to perform Web Service Authentication in Coldfusion. The webservice is written using a CFC.
It is a normal CFC, and I am generating the Web Service URL as test.cfc?WSDL
Is there a way that I can authenticate a web service method using SOAP headers ?
There is a code mechanism in ASP.NET, where we can beautify the web service with codes that will ask for a username and password for
accessing a method of a web service.
I am testing the web services using SOAP Sonar, it is a very good tool. When testing, if there is an authentication mechanism in a web service,
then it will prompt you to enter the user name and password. At the moment, I have included two fields (username and password) for each
method to do the custom authentication against a login info stored in Application.cfm.
I found a way using WSSJ4 from Apache, but it looked too complex and not very straight forward to acheive it.
Please if anyone have found a solution, please let me know.
Thank you in advance..
Josh Thomas
Please try the follwoing code set
/*REMOTE METHOD
soaptest.cfc
<cffunction name="addNumbers" access="remote" returntype="test" output="false">
<cfargument name="firstNumber" type="string" required="true"/>
<cfargument name="secondNumber" type="string" required="true"/>
<cfset retunVal="NO">
<cfset username=0>
<cfif isSOAPRequest()>
<cfset retunVal="YES">
<cfset username = getSOAPRequestHeader("http://localhost/testsoap/", "setInit")>
<cfset retunVal= arguments.firstNumber + arguments.secondNumber & username>
</cfif>
<cfreturn retunVal />
</cffunction>
/*calling remote method
index.cfm
<cfsavecontent variable="soap">
<?xml version="1.0" encoding="UTF-8"?>
<soapenv:Envelope
xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns="http://localhost/testsoap/">
<soapenv:Header>
<setInit>1</setInit>
</soapenv:Header>
<soapenv:Body>
<addNumbers soapenv:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" >
<firstNumber>1000</firstNumber>
<secondNumber>10</secondNumber>
</addNumbers>
</soapenv:Body>
</soapenv:Envelope>
</cfsavecontent>
<!--- Note that there's no ?wsdl appendage to the url --->
<cfhttp url="http://localhost/testsoap/soaptest.cfc" method="post">
<cfhttpparam type="header" name="content-type" value="text/xml">
<cfhttpparam type="header" name="SOAPAction" value="">
<cfhttpparam type="header" name="content-length" value="#len(soap)#">
<cfhttpparam type="header" name="charset" value="utf-8">
<cfhttpparam type="xml" name="message" value="#trim(soap)#">
</cfhttp>
