Illustrator layers into After Effects CS5
Jul 10, 2010 Jul 10, 2010
A client supplied an eps Logo with one layer and many "sub-layers" (sorry, don't know Illustrator well enough to call them anything else but
it's broken down to every tiny element such as every letter, portions of graphics, etc.),
When importing into AE CS5, it just recognizes the one "layer" like it was flattened. How do I separate these other layers in AI or After Effects
so I can animate them?
26.8K
LEGEND , Jul 12, 2010 Jul 12, 2010
you cannot import 'sub' layers as separate objects, you have to convert all 'sub' layers to regular layers by using the "release to layers" command in illustrator.
Check your terminology! You are only confusing the OP. There are no sub-layers, only objects in an EPS file. You're right about the Release to Layers, though. it would be the easiest way to get every object onto a separate layer.
Mylenium
You need to import the document as a composition to get access to the individual layers.
See this page for information on preparing files in Illustrator: "Preparing and importing Illustrator files"
See this page for information about importing layered still images as compositions: "Importing a still image as a composition"
Guest
@speakeasy11, apparently, you cannot import 'sub' layers as separate objects, you have to convert all 'sub' layers to regular layers by using the "release to layers" command in illustrator. Then, you have to pull all the newly converted layers to top-level layers.   Have a look here  http://aftereffects.digitalmedianet.com/articles/viewarticle.jsp?id=30923-0&afterinter=true
Mike
Mylenium
Guest
Jul 13, 2010 Jul 13, 2010
well, whatever terminolgy you use, here is a screen shot of an eps file in illustrator which is likely what the original poster is seeing with his file http://testbeforelaunch.com/temp/eps.jpg the "objects" or more appropriety "paths", as mentioned before must be "released to layers"
Wrong terminology. EPS files have no layers. They are flat files that contain a bunch of objects. So what you see in AE is correct. Your file must be organized into proper layers first in AI.
Mylenium
