I have been cooking right along in Captivate, and making some really cool things. Unfortunatly, I seem to have recently developed a glitch I cannot get rid of. I attempt to copy a slide, import a slide, copy and paste significant portions of a slide to a new slide, etc., and Captivate gives me the "sorry for the inconvenience, but the program must shut down" window.
I have tried other files than what I was working in. I have re-booted. I have uninstalled and re-installed a new instance of the program. I am at a loss.
Thoughts on this?
Hi Anthony,
It would seem that your Captivate file might have become corrupted. In this first instance (if you are using Adobe Captivate 4 or later), I would look for the .bak file which Adobe Captivate automatically creates. Make a copy this file and remove the .bak file suffix. Next, try opening the backup file and see if that makes any difference.
If not then instead of trying to import your slides, I would suggest you carry out the following steps:
If all goes well you should then be able to save the new project file. However, if Adobe Captivate crashes this will tell you that there is a corrupted Slide / Object in your original project file. If that is the case then you should do the following:
Now you should keep copying and pasting the slides from the original file. At some point you might find that one of the slides won't paste or that it might appear as a blank slide. Now you can either try to re-create that slide or switch back to the original file and try and work out which Slide in the last group of slides you copied where the corruption might of occured.
Let us know how you get on
Best regards,
Mark
