Fetching process & task details assigned to a group
Avatar
Level 1
Hi everybody,
I'm planning to integrate a workflow created with Adobe Process Manager with a web application developed in Java.
The workflow is designed in such a way the tasks first gets assigned to a group queue and users belonging to the group claim tasks and after performing the required operations, forward it to the next group queue.
The invocation of processes, claiming tasks & re-assigning it further are all planned to be performed with Adobe's Livecycle APIs available in Java.
Following is the problem that I'm currently faing:
After successfully creating a new instance of the process, performing a search on the available processes / tasks does not return the newly created process (as it is initally assigned to a group and not to the user who is performing the search operation - even with administrator).
In such a scenario, requesting guidance (using Java APIs) on how to fetch the details of the process & tasks related with the process that is assigned to a group please.
Expecting a favourable reply at the earliest pls (as it is really needed urgently)...Thanx.
Avatar
Level 10
You have to remember you can only search on tasks that the user (used in the connection properties ) has initiated or participated in.
If you want to get around that, you can use the TaskSearch from the TaskManagerQueryService and use a TaskSearchFilter with the isAdminIgnoreAllAcls() set to true.
Jasmin
Avatar
Level 1
Thanx for the prompt reply.
In my case, the process will first get assigned to a group queue instead of a particular user. Later on, when a user belonging to that group logs in, the user claims the task.
In such a scenario, wanted to know how can the logged-in user get to know the details of the task which he can calim by invoking TaskManager's claimTask() API.
Thanx.
Avatar
Level 1
Managed to proceed further slightly...
As a next step, need an API to fetch the details of all users belonging to a group please. Tried looking @ the API quick start guides & other examples, but didn't manage to get it. Would be of great help if someone can share the API detail / example here.
Thanking you for your suggestions !!!
