Locked
your computer does not have sufficient memory resource to publish your file
Participant ,
Jul 14, 2010 Jul 14, 2010
I just downloaded CP5 trial version to see what's new.  Is it just me or is it really buggy?
I received 'Adobe Captivate has stoped working' half a dozen times but managed to convert a small CP4 project (35 slides not a lot of animation or voice over) and tried to preview it.  I got the message 'your computer does not have sufficient memory resource to publish your file'.  I'm working on a new laptop with 4 GB of ram and I still get that message even when I kill everything else and only have Captivate running.  I'm working with Windows 7 on 64-bit OS.  Has anyone else run into this?  How much memory does CP5 draw?
Needless to say I won't be upgrading any time soon...
Best,
Aimee
16.0K
Hello,
Did you run Captivate as administrator? I'm working on a similar configuration, same OS and CP5 works fine, even with several open projects, Photoshop, Soundbooth and a couple of other programs running. It seems very strange to me. Do you have a dedicated Graphics card? CP is rather video-heavy, I made sure to have a 1GB card, but 512MB would do also.
Lilybiri
Participant ,
Hi Aimee,
Can you please check the "VM Size" of AdobeCaptivate.exe in Windows Task Manager (or better if you have "process explorer" as it gives the exact virtual size) at the time when you get the message box saying "does not have sufficient memory..." (check the VMSize before dismissing the message box). This message generally comes when the memory allocation failure happens inside Captivate process. I just want to make sure if it is really consuming so much of memory.
Regards
Rahul
Contributor ,
Sorry for this inconvinience. Could you please share your project file with us using acrobat.com  so that we can have a look at this?
Sikandar
Participant ,
Jul 15, 2010 Jul 15, 2010
Well, this morning it is working fine.  I did try it several times yesterday but perhaps after the install it runs some update checks or some
thing in the background?
I'll keep playing it and if I get the message again I will check the VM size and report it here.  In the meantime, my advise for anyone else who receives this message is to give it some time and a reboot (actually I didn't even reboot I just left my computer running over night).
Thanks for all your replies.
Best,
Aimee
Participant ,
Jul 21, 2010 Jul 21, 2010
Okay it happened again.
Here's the error:
And here is the CPU:
I would be happy to upload the project file if you provide me instructions about where to put it.  However, I opened another project to test if it was just that project and I received the same error.
Contributor ,
You could upload it to acrobat.com.
-Sikandar
Guest
Aug 01, 2010 Aug 01, 2010
Anyone with solution unto this?
Enthusiast ,
Hello Aimee,
Did you share the file on Acrobat.com? Or you can mail me the file at viswanat@adobe.com
Vish
Aug 02, 2018 Aug 02, 2018
I had the same error message. It was publishing last week, today it was not.  Tried removing all cache files, CC cleaner, re-booting.  Still got the error.  I deleted one slide and it published.  The slide had "Effects" on it.  Also noticed in the thumbnails of the slides, some of the graphics were missing.  Don't know if this will help, but it worked for me.
Participant ,
Aug 02, 2010 Aug 02, 2010
I don't think it is a problem with the file because:
1) it doesn't always happen with that file
2) it also has happened when testing other files
Enthusiast ,
Aug 03, 2010 Aug 03, 2010
Hello There,
Can you consistantly repro this issue? In that case we can try doing a remote connect and investigate further. If you are able to get this issue consistantly with any file, please share the file and that would help us in reproducing it locally.
Vish
Participant ,
Aug 04, 2010 Aug 04, 2010
Hi Vish,
Once or twice I was not able to reproduce - but I've no idea what was different. Since then I get the error every time I try to preview or publish (sometimes when I publish it actually doesn't give me an error it just stops working and I get a windows message that the program has stopped functioning). I have the same results with all projects.
Nonetheless, I've copied one of the project files to Acrobat.com if you want to take a look:
https://acrobat.com/#d=oKmIxddLLRMh1Zp0sAWYVA
Let me know if you want to do a remote session.
Aimee
Participant ,
Hi Aimee,
I just tried opening two copies of your project in Cp5 and previewed them about 20 times (along with doing some minor modifications). But could not reproduce the issue on my machine.
In your previous post you had posted a snapshot of TaskManager. But that was not much helpful as the "Memory" column just displays the amount of RAM occupied by the program. What I wanted to know was the "Virtual size" of the process at the time when the error occurred.
Can you please download "process explorer" software and check the column named "Virtual Size" as shown below (When you get the error dialog).
That might give us some more idea, else we will do a remote session.
Regards
Rahul
Participant ,
Aug 05, 2010 Aug 05, 2010
Hi Rahul,
Well I did say I was pretty sure it wasn't the project file...
Does this screen shot tell you anything?
Participant ,
Hi Aimee,
That was helpful, now it is sure that its not running out of memory.
We will investigate this issue soon and will keep you posted.
Regards
Rahul
Participant ,
Hi Aimee,
Can you please try disabling the swf compression and use Cp for some time to see if the error still happens.
You can do this from Preferences->Project->SWF size and quality -> Compress SWF file.
Regards
Rahul
Participant ,
Aug 06, 2010 Aug 06, 2010
Thanks Rahul,
I will definitely try this but I'm about to catch a flight and will not be back till Tuesday. Then I'll do it and post the result. Thanks for your attention to this issue.
Participant ,
Aug 10, 2010 Aug 10, 2010
Hi Rahul,
I tested it and when I uncheck only 'compress swf file' I still receive the message.
HOWEVER,
if I uncheck both 'compress swf file' and 'advanced project compression' I am able to both preview the project in a web browser and publish it.
I've tested it three or four times and it seems to consistently work.
Participant ,
That's a useful information, We will investigate this soon.
Regards
Rahul
Oct 01, 2010 Oct 01, 2010
Is there a resolution for this?  I'm having the exact same issue occur when attempting to publish.
VM Size at error occurence is ~257MB
Participant ,
Hey - for me it worked when I unchecked both 'compress swf file' and 'advanced project compression' in the Preferences->Project->SWF size and quality.
Did you try that?
Unchecking those options seem to help.  I'm still hoping that there's a fix though because we have to compress all of our swf files before we upload them to our servers.
Participant ,
Right. I hope there is a better solution as well. I'm curious what the specs are of your machine. I'm working with Win7 64 bit. The 64 bit gives me problems with CP4 as well and I wonder if that is contributing to the problems I experienced with CP5.
I'm using a 32bit WinXP SP3 machine.  I have 4GB of RAM even though I can't fully utilize it all with the 32bit OS.  You're not the first person I've seen say they've had issues with 64bit and CP 4/5.  I had a few really frustrating issues with CP4 as well.  It's hard to find the common denominator with some of these issues sometimes.
Help resources
