12 Replies Latest reply: Jan 4, 2011 4:43 PM by Anthony Curcione RSS
    Crashing when I try to specify audio input
    fijiwinkle Community Member
      Hey all. My name is William.
      I am having trouble with Premiere. I started using it a few days ago and it is working great; however, I now want to record a voice-over. I haven't recorded audio in Premiere before, so I searched the help database. It told me I would need to specify the audio input, which sounded reasonable to me, so I went into Settings -> Audio Hardware and selected "Built in input/Built-in output" and it had the spinning wheel of death for a few moments (I'm on a Mac) and then crashed. I had turned off my error dialog boxes before due to a previous problem with Photoshop frequently thinking it had crashed when in fact I had quit it, so I have no way to report the problem other than here.
      I have also tried setting the option to "System default input/output" and it still crashes.
      (edit) The Mac error reporter displays this:
      Process:         Adobe Premiere Pro CS5 [52687]
      Path:            /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/MacOS/Adobe Premiere Pro CS5
      Identifier:      com.adobe.AdobePremierePro
      Version:         5.0.1 (5.0.1)
      Code Type:       X86-64 (Native)
      Parent Process:  launchd [209]
      Date/Time:       2010-07-15 17:01:08.778 -0700
      OS Version:      Mac OS X 10.6.4 (10F569)
      Report Version:  6
      Interval Since Last Report:          161111 sec
      Crashes Since Last Report:           3
      Per-App Interval Since Last Report:  15174 sec
      Per-App Crashes Since Last Report:   4
      Anonymous UUID:                      0D904B93-C3BF-4482-8531-3F3DCD043ABB
      Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
      Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000048
      Crashed Thread:  38
      Thread 0:  Dispatch queue: com.apple.main-thread
      0   libSystem.B.dylib             0x00007fff8649f342 semaphore_wait_signal_trap + 10
      1   libSystem.B.dylib             0x00007fff864a488d pthread_mutex_lock + 469
      2   com.apple.audio.CoreAudio     0x00007fff880ff8fc CAMutex::Lock() + 58
      3   com.apple.audio.CoreAudio     0x00007fff8811932a IOA_Device::StartCommandExecution(void**) + 42
      4   com.apple.audio.CoreAudio     0x00007fff8811acc3 HP_Device::ExecuteCommand(HP_Command*) + 75
      5   com.apple.audio.CoreAudio     0x00007fff88143768 IOA_MultiDevice::EvaluateSubDeviceList(bool) + 456
      6   com.apple.audio.CoreAudio     0x00007fff8813a6a3 IOA_AggregateDevice::PrefsChangedNotification(__CFString const*) + 311
      7   com.apple.audio.CoreAudio     0x00007fff881440bb IOA_MultiDeviceDescription::PrefsChangedNotificationHandler(__CFNotificationCenter*, IOA_MultiDeviceDescription*, __CFString const*, void const*, __CFDictionary const*) + 69
      8   com.apple.CoreFoundation      0x00007fff84eed8f8 __CFXNotificationHandleMessage + 568
      9   com.apple.CoreFoundation      0x00007fff84eed653 __CFXNotificationReceiveFromServer + 291
      10  com.apple.CoreFoundation      0x00007fff84eafbce __CFMachPortPerform + 366
      11  com.apple.CoreFoundation      0x00007fff84e88171 __CFRunLoopRun + 5201
      12  com.apple.CoreFoundation      0x00007fff84e8684f CFRunLoopRunSpecific + 575
      13  com.apple.HIToolbox           0x00007fff86e3d91a RunCurrentEventLoopInMode + 333
      14  com.apple.HIToolbox           0x00007fff86e3d67d ReceiveNextEventCommon + 148
      15  com.apple.HIToolbox           0x00007fff86e3d5d8 BlockUntilNextEventMatchingListInMode + 59
      16  com.apple.AppKit              0x00007fff810cb29e _DPSNextEvent + 708
      17  com.apple.AppKit              0x00007fff810cabed -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 155
      18  com.apple.AppKit              0x00007fff81305ed3 -[NSApplication _realDoModalLoop:peek:] + 442
      19  com.apple.AppKit              0x00007fff81323c9f -[NSApplication runModalSession:] + 57
      20  com.adobe.dvaui.framework     0x0000000102e4bec5 dvaui::ui::OS_Dialog::ModalLoop() + 149
      21  com.adobe.dvaui.framework     0x0000000102e4bc23 dvaui::ui::OS_Dialog::RunModal() + 195
      22  com.adobe.dvaeve.framework    0x00000001066aac09 dvaeve::UI_EveManager::DisplayView(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::istream&, dvaui::drawbot::SupplierInterface const*, dvaui::ui::UI_Node*) + 1785
      23  com.adobe.dvaeve.framework    0x00000001066a6df1 dvaeve::UI_Eve::ParseEveScript(std::basic_stringstream<char, std::char_traits<char>, std::allocator<char> >&) + 1169
      24  com.adobe.premiere.dialogs    0x000000010726081e DLG::RunPrefsDialog(ASL::InterfaceRef<BE::IProjectSettings, BE::IProjectSettings>, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, int const&) + 334
      25  com.adobe.premiere.frontend   0x000000010b404374 FE::DocumentManager::OnPreferences(UIF::Command const&) + 388
      26  com.adobe.premiere.frontend   0x000000010b411b3b FE::DocumentManager::ObeyCommand(UIF::Command const&) + 267
      27  com.adobe.premiere.uiframework 0x000000010333601c UIF::Commander::PostCommand(int) + 60
      28  com.adobe.dvacore.framework   0x000000010010fb96 int dvacore::config::ErrorManager::ExecuteFunction<void>(boost::function0<void>*, void*) + 38
      29  com.adobe.premiere.frontend   0x000000010b3e632e boost::function0<int>::operator()() const + 46
      30  com.adobe.premiere.frontend   0x000000010b3e5873 FE::ApplicationErrorManager::ExecuteFunctionWithTopLevelExceptionHandler(boost::function0 <int>) + 35
      31  com.adobe.dvacore.framework   0x000000010010ead5 void dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler<void>(boost::f unction0<void>, bool*) + 197
      32  com.adobe.dvacore.framework   0x0000000100110a03 void dvacore::config::ExecuteTopLevelFunction<void>(boost::function0<void>, bool*) + 99
      33  com.adobe.premiere.frontend   0x000000010b42f24c -[PremiereCocoaMacApplication handleMenuCommand:] + 140
      34  com.apple.AppKit              0x00007fff81220152 -[NSApplication sendAction:to:from:] + 95
      35  com.apple.AppKit              0x00007fff812446be -[NSMenuItem _corePerformAction] + 365
      36  com.apple.AppKit              0x00007fff81244428 -[NSCarbonMenuImpl performActionWithHighlightingForItemAtIndex:] + 121
      37  com.adobe.dvaui.framework     0x0000000102e84a6e -[DVAMacMenu performActionForItemAtIndex:] + 62
      38  com.apple.AppKit              0x00007fff814c841d -[NSMenu _internalPerformActionForItemAtIndex:] + 35
      39  com.apple.AppKit              0x00007fff8137a217 -[NSCarbonMenuImpl _carbonCommandProcessEvent:handlerCallRef:] + 136
      40  com.apple.AppKit              0x00007fff81226c14 NSSLMMenuEventHandler + 321
      41  com.apple.HIToolbox           0x00007fff86e16997 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1002
      42  com.apple.HIToolbox           0x00007fff86e15ee6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 395
      43  com.apple.HIToolbox           0x00007fff86e33ba9 SendEventToEventTarget + 45
      44  com.apple.HIToolbox           0x00007fff86e62cd1 SendHICommandEvent(unsigned int, HICommand const*, unsigned int, unsigned int, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 387
      45  com.apple.HIToolbox           0x00007fff86e8fb06 SendMenuCommandWithContextAndModifiers + 56
      46  com.apple.HIToolbox           0x00007fff86e8fabe SendMenuItemSelectedEvent + 101
      47  com.apple.HIToolbox           0x00007fff86e8f9be FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 150
      48  com.apple.HIToolbox           0x00007fff86e70cb3 MenuSelectCore(MenuData*, Point, double, unsigned int, OpaqueMenuRef**, unsigned short*) + 467
      49  com.apple.HIToolbox           0x00007fff86e70408 _HandleMenuSelection2 + 453
      50  com.apple.AppKit              0x00007fff810f7c39 _NSHandleCarbonMenuEvent + 236
      51  com.apple.AppKit              0x00007fff810cb74e _DPSNextEvent + 1908
      52  com.apple.AppKit              0x00007fff810cabed -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 155
      53  com.apple.AppKit              0x00007fff810908d3 -[NSApplication run] + 395
      54  com.adobe.premiere.frontend   0x000000010b42e394 FE::MacApplication::RunSelf(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 164
      55  com.adobe.premiere.frontend   0x000000010b3d993e FE::Application::Run(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 2510
      56  com.adobe.premiere.frontend   0x000000010b43215d AppMain + 253
      57  com.adobe.premiere.startup    0x000000010b575c58 (anonymous namespace)::LaunchFrontendFramework(ASL::ObjectPtr<ASL::Module, ASL::AtomicValue> const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, int, void*) + 168
      58  com.adobe.AdobePremierePro    0x0000000100003660 (anonymous namespace)::CallStartupFramework(int, char const* const*) + 288
      59  com.adobe.AdobePremierePro    0x0000000100003bdb main + 155
      60  com.adobe.AdobePremierePro    0x00000001000034a4 start + 52
      Thread 1:  Dispatch queue: com.apple.libdispatch-manager
      0   libSystem.B.dylib             0x00007fff864b808a kevent + 10
      1   libSystem.B.dylib             0x00007fff864b9f5d _dispatch_mgr_invoke + 154
      2   libSystem.B.dylib             0x00007fff864b9c34 _dispatch_queue_invoke + 185
      3   libSystem.B.dylib             0x00007fff864b975e _dispatch_worker_thread2 + 252
      4   libSystem.B.dylib             0x00007fff864b9088 _pthread_wqthread + 353
      5   libSystem.B.dylib             0x00007fff864b8f25 start_wqthread + 13
      Thread 2:
      0   libSystem.B.dylib             0x00007fff864d9eb6 __semwait_signal + 10
      1   libSystem.B.dylib             0x00007fff864ddcd1 _pthread_cond_wait + 1286
      2   com.adobe.amt.services        0x000000010d735c53 AMTConditionLock::LockWhenCondition(int) + 37
      3   com.adobe.amt.services        0x000000010d72ecce _AMTThreadedPCDService::PCDThreadWorker(_AMTThreadedPCDService*) + 92
      4   com.adobe.amt.services        0x000000010d735cbe AMTThread::Worker(void*) + 28
      5   libSystem.B.dylib             0x00007fff864d8456 _pthread_start + 331
      6   libSystem.B.dylib             0x00007fff864d8309 thread_start + 13
      Thread 3:
      2   ...ple.CoreServices.CarbonCore 0x00007fff806d74c3 TSWaitOnCondition + 118
      3   ...ple.CoreServices.CarbonCore 0x00007fff80646cc4 TSWaitOnConditionTimedRelative + 177
      4   ...ple.CoreServices.CarbonCore 0x00007fff80640bcf MPWaitOnQueue + 215
      5   ...e.Frameworks.ASL.Foundation 0x00000001004607c0 ASL::(anonymous namespace)::TaskProc(void*) + 96
      6   ...ple.CoreServices.CarbonCore 0x00007fff80618ea1 PrivateMPEntryPoint + 63
      7   libSystem.B.dylib             0x00007fff864d8456 _pthread_start + 331
      8   libSystem.B.dylib             0x00007fff864d8309 thread_start + 13
      Thread 4:
      5   com.adobe.dvacore.framework   0x000000010018029f dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 143
      6   com.adobe.dvacore.framework   0x0000000100110ade boost::function0<void>::operator()() const + 46
      7   com.adobe.dvacore.framework   0x00000001001786d3 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 99
      8   ...obe.boost_threads.framework 0x00000001000c8ac4 thread_proxy + 132
      9   libSystem.B.dylib             0x00007fff864d8456 _pthread_start + 331
      10  libSystem.B.dylib             0x00007fff864d8309 thread_start + 13
      Thread 5:
      1   ...dobe.dvatransport.framework 0x000000010062634e boost::asio::detail::kqueue_reactor<false>::run(bool) + 478
      2   ...dobe.dvatransport.framework 0x0000000100627405 boost::asio::detail::task_io_service<boost::asio::detail::kqueue_reactor<false> >::run(boost::system::error_code&) + 517
      3   ...dobe.dvatransport.framework 0x0000000100604fcc SkyConnectionEnv::MainLoop() + 76
      4   ...dobe.dvatransport.framework 0x0000000100605039 SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
      5   ...obe.boost_threads.framework 0x00000001000c8ac4 thread_proxy + 132
      6   libSystem.B.dylib             0x00007fff864d8456 _pthread_start + 331
      7   libSystem.B.dylib             0x00007fff864d8309 thread_start + 13
      Thread 6:
      Thread 7:
      Thread 8:
      Thread 9:
      Thread 10:
      Thread 11:
      2   ...dobe.dvatransport.framework 0x000000010062753f boost::asio::detail::task_io_service<boost::asio::detail::kqueue_reactor<false> >::run(boost::system::error_code&) + 831
      3   ...dobe.dvatransport.framework 0x0000000100628135 boost::asio::detail::posix_thread::func<boost::asio::detail::resolver_service<boost::asio ::ip::tcp>::work_io_service_runner>::run() + 53
      4   ...dobe.dvatransport.framework 0x000000010060d379 asio_detail_posix_thread_function + 25
      Thread 12:
      Thread 13:
      0   libSystem.B.dylib             0x00007fff8649f2fa mach_msg_trap + 10
      1   libSystem.B.dylib             0x00007fff8649f96d mach_msg + 59
      2   com.apple.CoreFoundation      0x00007fff84e873c2 __CFRunLoopRun + 1698
      3   com.apple.CoreFoundation      0x00007fff84e8684f CFRunLoopRunSpecific + 575
      4   com.apple.audio.CoreAudio     0x00007fff8812faf6 HALRunLoop::OwnThread(void*) + 152
      5   com.apple.audio.CoreAudio     0x00007fff8811caf5 CAPThread::Entry(CAPThread*) + 125
      Thread 14:
      0   libSystem.B.dylib             0x00007fff8649f35a semaphore_timedwait_signal_trap + 10
      1   libSystem.B.dylib             0x00007fff864ddbc2 _pthread_cond_wait + 1015
      2   ...ple.CoreServices.CarbonCore 0x00007fff80646ce4 TSWaitOnConditionTimedRelative + 209
      3   ...ple.CoreServices.CarbonCore 0x00007fff80640bcf MPWaitOnQueue + 215
      4   com.adobe.dvacore.framework   0x000000010018029f dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 143
      5   com.adobe.dvacore.framework   0x0000000100110ade boost::function0<void>::operator()() const + 46
      6   com.adobe.dvacore.framework   0x00000001001786d3 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 99
      7   ...obe.boost_threads.framework 0x00000001000c8ac4 thread_proxy + 132
      8   libSystem.B.dylib             0x00007fff864d8456 _pthread_start + 331
      9   libSystem.B.dylib             0x00007fff864d8309 thread_start + 13
      Thread 15:
      Thread 16:
      Thread 17:
      Thread 18:
      Thread 19:
      4   com.apple.CoreFoundation      0x00007fff84e865d6 CFRunLoopRun + 70
      5   com.adobe.dvacore.framework   0x000000010016a859 dvacore::threads::RunPlatformEventLoop() + 89
      6   com.adobe.dvacore.framework   0x0000000100170491 dvacore::threads::(anonymous namespace)::EventLoopExecutor::EventLoopMain(dvacore::threads::SyncPoint&) + 177
      7   com.adobe.dvacore.framework   0x0000000100110ade boost::function0<void>::operator()() const + 46
      8   com.adobe.dvacore.framework   0x00000001001786d3 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 99
      9   ...obe.boost_threads.framework 0x00000001000c8ac4 thread_proxy + 132
      10  libSystem.B.dylib             0x00007fff864d8456 _pthread_start + 331
      11  libSystem.B.dylib             0x00007fff864d8309 thread_start + 13
      Thread 20:
      1   libSystem.B.dylib             0x00007fff864d9d45 nanosleep + 148
      2   com.adobe.premiere.scriptlayer 0x000000010644f76b ScObjects::Thread::sleep(unsigned int) + 59
      3   com.adobe.premiere.scriptlayer 0x000000010643a273 ScObjects::BridgeTalkThread::run() + 163
      4   com.adobe.premiere.scriptlayer 0x000000010644f866 ScObjects::Thread::go(void*) + 166
      Thread 21:
      0   libSystem.B.dylib             0x00007fff864e2df2 recvfrom + 10
      1   ServiceManager-Launcher.dylib 0x0000000125996982 Invoke + 54020
      2   ServiceManager-Launcher.dylib 0x0000000125995adf Invoke + 50273
      3   ServiceManager-Launcher.dylib 0x0000000125994b26 Invoke + 46248
      4   ServiceManager-Launcher.dylib 0x0000000125994b81 Invoke + 46339
      5   ServiceManager-Launcher.dylib 0x0000000125994c02 Invoke + 46468
      6   ServiceManager-Launcher.dylib 0x000000012598f30d Invoke + 23695
      7   ServiceManager-Launcher.dylib 0x000000012598f4a6 Invoke + 24104
      8   ServiceManager-Launcher.dylib 0x000000012598ff2f Invoke + 26801
      9   ServiceManager-Launcher.dylib 0x000000012599001d Invoke + 27039
      10  ServiceManager-Launcher.dylib 0x000000012599331f Invoke + 40097
      11  ServiceManager-Launcher.dylib 0x00000001259935c5 Invoke + 40775
      12  ServiceManager-Launcher.dylib 0x0000000125993b84 Invoke + 42246
      13  ServiceManager-Launcher.dylib 0x0000000125993d71 Invoke + 42739
      14  ServiceManager-Launcher.dylib 0x0000000125985daf Login + 1773
      15  ServiceManager-Launcher.dylib 0x0000000125987295 Login + 7123
      16  ServiceManager-Launcher.dylib 0x00000001259942a8 Invoke + 44074
      17  ServiceManager-Launcher.dylib 0x00000001259966c1 Invoke + 53315
      18  libSystem.B.dylib             0x00007fff864d8456 _pthread_start + 331
      19  libSystem.B.dylib             0x00007fff864d8309 thread_start + 13
      Thread 22:
      Thread 23:
      Thread 24:
      Thread 25:
      2   ...ple.CoreServices.CarbonCore 0x00007fff806d4c1b TS_exception_listener_thread + 126
      3   libSystem.B.dylib             0x00007fff864d8456 _pthread_start + 331
      4   libSystem.B.dylib             0x00007fff864d8309 thread_start + 13
      Thread 26:
      1   com.adobe.MediaFoundation     0x0000000100aa912c MF::DirectoryChangeMonitor::(anonymous namespace)::EventQueueThreadProc(void*) + 428
      2   libSystem.B.dylib             0x00007fff864d8456 _pthread_start + 331
      3   libSystem.B.dylib             0x00007fff864d8309 thread_start + 13
      Thread 27:
      2   com.adobe.adobeswfl           0x000000012f84504d APXGetHostAPI + 2430509
      3   com.adobe.adobeswfl           0x000000012f606a39 APXGetHostAPI + 77849
      4   com.adobe.adobeswfl           0x000000012f845161 APXGetHostAPI + 2430785
      5   com.adobe.adobeswfl           0x000000012f8452ba APXGetHostAPI + 2431130
      6   com.adobe.adobeswfl           0x000000012f8453b0 APXGetHostAPI + 2431376
      Thread 28:
      Thread 29:
      4   com.apple.CoreMediaIOServices 0x00007fff82ca563f MIO::DAL::RunLoop::OwnThread(void*) + 147
      5   com.apple.CoreMediaIOServices 0x00007fff82ca720a CAPThread::Entry(CAPThread*) + 140
      Thread 30:
      2   com.adobe.adobeswfl           0x000000012f845019 APXGetHostAPI + 2430457
      3   com.adobe.adobeswfl           0x000000012f9da943 APXGetHostAPI + 4091683
      Thread 31:
      3   com.adobe.adobeswfl           0x000000012f86195c APXGetHostAPI + 2547516
      Thread 32:
      0   libSystem.B.dylib             0x00007fff864e2dce select$DARWIN_EXTSN + 10
      1   com.apple.CoreFoundation      0x00007fff84ea8e92 __CFSocketManager + 818
      Thread 33:
      4   com.apple.Foundation          0x00007fff857b34c3 +[NSURLConnection(NSURLConnectionReallyInternal) _resourceLoadLoop:] + 297
      5   com.apple.Foundation          0x00007fff85733e8d __NSThread__main__ + 1429
      Thread 34:
      Thread 35:
      0   libSystem.B.dylib             0x00007fff864b8eaa __workq_kernreturn + 10
      1   libSystem.B.dylib             0x00007fff864b92bc _pthread_wqthread + 917
      2   libSystem.B.dylib             0x00007fff864b8f25 start_wqthread + 13
      Thread 36:
      4   com.apple.AVCVideoServices    0x0000000124dd16dc AVS::AVCVideoServicesThreadStart(AVS::AVCVideoServicesThreadParams*) + 186
      Thread 37:
      Thread 38 Crashed:
      0   com.apple.audio.CoreAudio     0x00007fff8814d0dd IOA_SubDeviceList::StartIOCycle() + 39
      1   com.apple.audio.CoreAudio     0x00007fff8811f3a8 IOA_Device::CallIOProcs(AudioTimeStamp const&, AudioTimeStamp const&, AudioTimeStamp const&) + 40
      2   com.apple.audio.CoreAudio     0x00007fff8811f2e5 HP_IOThread::PerformIO(AudioTimeStamp const&, double) + 771
      3   com.apple.audio.CoreAudio     0x00007fff8811d2f4 HP_IOThread::WorkLoop() + 1832
      4   com.apple.audio.CoreAudio     0x00007fff8811cbc7 HP_IOThread::ThreadEntry(HP_IOThread*) + 9
      Thread 38 crashed with X86 Thread State (64-bit):
        rax: 0x0000000000000000  rbx: 0x0000000125ad4cc0  rcx: 0x0000000125ad4cc0  rdx: 0x0000000125ad4d00
        rdi: 0x0000000120727120  rsi: 0x0000000125ad4e40  rbp: 0x0000000125ad4bd0  rsp: 0x0000000125ad4ba0
         r8: 0x000000000c8f017e   r9: 0x0000000125ad4e9f  r10: 0x000000000000002c  r11: 0x0000000000001200
        r12: 0x0000000120726a80  r13: 0x0000000120727120  r14: 0x0000000125ad4e40  r15: 0x0000000125ad4cc0
        rip: 0x00007fff8814d0dd  rfl: 0x0000000000010206  cr2: 0x0000000000000048
      Binary Images:
             0x100000000 -        0x100003ff7 +com.adobe.AdobePremierePro 5.0.1 (5.0.1) <85AF6150-7D5A-5887-2A90-521EFC21081F> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/MacOS/Adobe Premiere Pro CS5
             0x100008000 -        0x10000dffd +com.adobe.AdobeCrashReporter 3.0 (3.0.20100302) <DFFB9A08-8369-D65F-161F-7C61D562E307> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
             0x100012000 -        0x10007cff7 +com.adobe.amtlib amtlib 3.0.0.64 (3.0.0.64) <6B2F73C2-10AB-08B3-4AB0-A31C83D1E5E0> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
             0x1000af000 -        0x1000b6ff3 +com.adobe.boost_date_time.framework boost_date_time version 5.0.0 (5.0.0.0) <69AC803F-9948-EC7C-F94F-6F2F224AA24B> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
             0x1000c6000 -        0x1000ceff3 +com.adobe.boost_threads.framework boost_threads version 5.0.0 (5.0.0.0) <34CE7AC8-6D0E-B470-D591-FCB3533E4620> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
             0x1000dd000 -        0x10025dff7 +com.adobe.dvacore.framework dvacore version 5.0.0 (5.0.0.0) <0C54067E-DF6C-A44C-9CFE-4FADED4CA06B> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
             0x1003e3000 -        0x100402fff +com.adobe.dvamediatypes.framework dvamediatypes version 5.0.0 (5.0.0.0) <A3601FD2-1397-2B3B-45D1-DD2756DCD76B> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
             0x100422000 -        0x100423fff +PRM ??? (???) <90E8FCC0-0B33-987F-39D4-098AD1F8E751> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/PRM.framework/Versions/A/PRM
             0x100427000 -        0x10048dff5 +com.adobe.MediaCore.Frameworks.ASL.Foundation 1.0 (1.0) <6989DA03-F7DB-0EE6-4D76-51660533399F> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/ASLFoundation.framework/Versions/A/ASLFoundation
             0x100577000 -        0x10058dfff +ASLMessaging ??? (???) <656C2251-8B9C-D2D7-B424-7A3A4AAF5B71> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/ASLMessaging.framework/Versions/A/ASLMessaging
             0x1005ab000 -        0x1005acfff +com.adobe.MediaCore.Frameworks.Memory 1.0 (1.0) <2C12990E-7C2A-A6B2-727F-40C5B298A89D> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/Memory.framework/Versions/A/Memory
             0x1005b1000 -        0x1005c2ff1 +ASLUnitTesting ??? (???) <9CF2A18B-5579-55E4-8F71-5A61D30CDE8F> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/ASLUnitTesting.framework/Versions/A/ASLUnitTesting
             0x1005db000 -        0x1005dcfff +com.adobe.boost_system.framework boost_system version 5.0.0 (5.0.0.0) <4A2C3C82-0C3B-96D2-5713-91326D2B5493> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
             0x1005e2000 -        0x100658ff7 +com.adobe.dvatransport.framework dvatransport version 5.0.0 (5.0.0.0) <96333093-C4D9-C3A9-81D7-815FF26DEBBE> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatransport
             0x1006db000 -        0x100718ff3 +com.adobe.dvamarshal.framework dvamarshal version 5.0.0 (5.0.0.0) <7AC12C26-0042-21B9-713E-6B045CD22975> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarshal
             0x100791000 -        0x10096cfff +com.adobe.dynamiclink.framework dynamiclink version 5.0.0 (5.0.0.0) <CF65C95F-F3D2-6194-181B-FF5413690866> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamiclink
             0x100a97000 -        0x100accfef +com.adobe.MediaFoundation ??? (1.0) <9C0ADB1D-B427-DB15-0A06-9C0D347E7331> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/MediaFoundation.framework/Versions/A/MediaFoundation
             0x100b11000 -        0x100b88fe3 +com.adobe.MediaCore.Frameworks.AudioRenderer ??? (1.0) <03B8847C-5931-CB8E-D4A4-BA1A1E2BE94B> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AudioRenderer.framework/Versions/A/AudioRenderer
             0x100c22000 -        0x1016f4fef +com.adobe.MediaCore.Frameworks.Backend ??? (1.0) <7F40E4C1-9666-1C64-8C78-FF7D842D70D3> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/Backend.framework/Versions/A/Backend
             0x10240c000 -        0x1025afff3 +com.adobe.MediaCore.Frameworks.ImageRenderer ??? (1.0) <78968FD8-65E8-F692-ED9B-81EC23978FD0> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/ImageRenderer.framework/Versions/A/ImageRenderer
             0x1026dd000 -        0x102719ff7 +com.adobe.MediaCore.Frameworks.MLFoundation 1.0 (1.0) <8CD6AD9D-180A-8101-9196-DE6C8273FB6E> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/MLFoundation.framework/Versions/A/MLFoundation
             0x10276a000 -        0x1027c0fff +com.adobe.MediaCore.VideoFrame 1.0 (1.0) <2269F5F4-DDDD-2286-B14E-F6779D042FC4> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/VideoFrame.framework/Versions/A/VideoFrame
             0x10282d000 -        0x102864fff +com.adobe.MediaCore.Frameworks.PluginSupport 1.0 (1.0) <E37F7508-9650-5B0C-C6F5-9ABD2EC9FFD7> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/PluginSupport.framework/Versions/A/PluginSupport
             0x1028a5000 -        0x1028e3fff +com.adobe.MediaCore.Frameworks.SweetPeaSupport 1.0 (1.0) <C587EB69-AC08-90A7-A0E6-07E16F783B58> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/SweetPeaSupport.framework/Versions/A/SweetPeaSupport
             0x102939000 -        0x10297bfe1 +com.adobe.MediaCore.Frameworks.AudioSupport 1.0 (1.0) <091114FD-8A59-A1C6-1BD8-7AA11C0817A7> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AudioSupport.framework/Versions/A/AudioSupport
             0x1029c4000 -        0x1029c8fff +com.adobe.MediaCore.Frameworks.MediaUtils 1.0 (1.0) <9A447195-1E4E-DD8C-E067-3AFD29F9D79D> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/MediaUtils.framework/Versions/A/MediaUtils
             0x1029ce000 -        0x1029e8ffb +com.adobe.MediaCore.Frameworks.AudioFilterHost 1.0 (1.0) <85712A0E-D630-34C2-AD0D-B69995CC8441> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AudioFilterHost.framework/Versions/A/AudioFilterHost
             0x102a10000 -        0x102a6effd +AdobeXMP ??? (???) <561026BB-C6EA-29CE-4790-CABCB81E8884> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
             0x102a7c000 -        0x102b08fe3 +AdobeXMPFiles ??? (???) <472EE67E-C811-A97D-7436-B3C2E9A299AC> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
             0x102b40000 -        0x102b78fff +com.adobe.MediaCore.Frameworks.AudioFilters ??? (1.0) <E249BD40-348A-09AE-B514-123955F3A9EB> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AudioFilters.framework/Versions/A/AudioFilters
             0x102be3000 -        0x102befff5 +com.adobe.boost_signals.framework boost_signals version 5.0.0 (5.0.0.0) <0F902CE5-655D-CC5B-316F-50A1B04E9DD8> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
             0x102c01000 -        0x102f4bfef +com.adobe.dvaui.framework dvaui version 5.0.0 (5.0.0.0) <5FDA25F7-EE84-B362-E191-DC4ABCF20FCA> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
             0x1032f6000 -        0x103591fe1 +com.adobe.premiere.uiframework 1.0 (1.0) <7118E069-5048-1D1B-2D41-DD060790017D> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/UIFramework.framework/Versions/A/UIFramework
             0x1038c5000 -        0x1039e4fff +com.adobe.MediaCore.Frameworks.VideoRenderer 1.0 (1.0) <988AF792-F0E6-1B00-FF35-F01C57143EFB> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/VideoRenderer.framework/Versions/A/VideoRenderer
             0x103b4a000 -        0x103ceaff7 +com.adobe.MediaCore.Frameworks.ImporterHost 1.0 (1.0) <6CE6C72E-815C-A858-2FB1-0B44AF6DDE6C> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/ImporterHost.framework/Versions/A/ImporterHost
             0x103eb5000 -        0x103f7afeb +com.adobe.MediaCore.Frameworks.ExporterHost 1.0 (1.0) <DC794655-06BD-91B5-4D13-1A6B4A6BED04> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/ExporterHost.framework/Versions/A/ExporterHost
             0x104094000 -        0x10410dff7 +com.adobe.MediaCore.Frameworks.PlayerHost 1.0 (1.0) <B89DEFED-1D66-6263-355F-B63D03BD93D3> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/PlayerHost.framework/Versions/A/PlayerHost
             0x1041aa000 -        0x104219fff +com.adobe.MediaCore.Frameworks.RecorderHost 1.0 (1.0) <1F730A4D-ED60-4BFC-E603-0E5318890051> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/RecorderHost.framework/Versions/A/RecorderHost
             0x104299000 -        0x1042a6ff7 +com.adobe.MediaCore.Frameworks.ProjectConverterHost 1.0 (1.0) <FF66C377-A842-54BC-556E-9479C7190C69> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/ProjectConverterHost.framework/Versions/A/ProjectConverterHos t
             0x1042b9000 -        0x10438bfff +com.adobe.MediaCore.Frameworks.VideoFilterHost 1.0 (1.0) <193F321C-BF5D-C6DC-F9F1-E74B793A61C7> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/VideoFilterHost.framework/Versions/A/VideoFilterHost
             0x10444d000 -        0x10445cfff +com.adobe.MediaCore.Frameworks.ProjectSupport 1.0 (1.0) <CCA9E97D-85EA-3B53-7446-9D6E78DF7B18> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/ProjectSupport.framework/Versions/A/ProjectSupport
             0x104470000 -        0x104487ff6 +com.adobe.AMEAppFoundation.framework ??? (1.0) <0DC62713-FDFE-A465-C9D2-CF179A0B32F3> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AMEAppFoundation.framework/Versions/A/AMEAppFoundation
             0x1044a8000 -        0x1044cbff1 +com.adobe.PostEncodeHost.framework ??? (1.0) <7D706D5A-5CA2-7EEC-CF17-A62872208417> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/PostEncodeHost.framework/Versions/A/PostEncodeHost
             0x1044f9000 -        0x104538fff +com.adobe.dvatemporalxmp.framework dvatemporalxmp version 5.0.0 (5.0.0.0) <E42C1BA9-14A7-355C-BDB3-4947E3BAB6A0> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvatemporalxmp
             0x104550000 -        0x10456dfff +AdobeBIB ??? (???) <258F8418-4511-610F-526B-1B00695037B6> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
             0x104577000 -        0x104617fef +com.adobe.AdobeScCore ScCore 4.1.23 (4.1.23.7471) <B5706E32-47E4-52DC-0605-712F96BC74FC> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
             0x10465d000 -        0x104701ffb +com.adobe.AdobeExtendScript ExtendScript 4.1.23 (4.1.23.7471) <4749CAD2-7EDF-6D17-A5A5-7B45189FEEA7> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
             0x104763000 -        0x1047b9ff3 +com.adobe.MediaCore.Frameworks.BravoInitializer 1.0 (1.0) <1E76782C-AC03-9EA5-9C5E-E5BF4EB8C688> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/BravoInitializer.framework/Versions/A/BravoInitializer
             0x104839000 -        0x10494dfff +AdobeACE ??? (???) <E359887D-1E7F-5E62-CB8D-37CE4DBFB4D8> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
             0x104972000 -        0x104cbbfe7 +AdobeAGM ??? (???) <BEEAAC1B-CC8F-1A91-C0A2-03BE0343A313> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
             0x104d8d000 -        0x1050befe7 +AdobeCoolType ??? (???) <D234D9AD-924B-9C1C-8F11-ECECAE7BBC05> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
             0x10515a000 -        0x10521cff7 +AMEWrapper ??? (???) <5F99BE97-C24A-6149-61CB-82A4012251B9> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AMEWrapper.framework/Versions/A/AMEWrapper
             0x1052d9000 -        0x1053ecfff +com.adobe.EncoderHost.framework ??? (1.0) <1431196B-3883-1890-FE9D-0B6F052612D8> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/EncoderHost.framework/Versions/A/EncoderHost
             0x1054f2000 -        0x10557aff7 +com.adobe.premiere.MBCProvider 1.0 (1.0) <BB7A1F4B-BAB0-3880-2D4B-1B165E6D49B8> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/MBCProvider.framework/Versions/A/MBCProvider
             0x1055f9000 -        0x105c76fff +com.adobe.Mezzanine ??? (1.0) <E8E59521-D480-D78C-09E3-157683EE8968> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/Mezzanine.framework/Versions/A/Mezzanine
             0x106196000 -        0x1061a6ff8 +com.adobe.ahclientframework 1.5.0.30 (1.5.0.30) <5D6FFC4E-7B81-3E8C-F0D4-66A3FA94A837> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
             0x1061b1000 -        0x106262fff +com.adobe.dvaworkspace.framework dvaworkspace version 5.0.0 (5.0.0.0) <5F192875-55DD-ADB9-0059-7F91EE15BD55> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
             0x10633e000 -        0x1064b5ff7 +com.adobe.premiere.scriptlayer 1.0 (1.0) <D26E0158-EE09-3ADB-22E6-9FC38966FEC1> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/ScriptLayerPPro.framework/Versions/A/ScriptLayerPPro
             0x106690000 -        0x106761fe1 +com.adobe.dvaeve.framework dvaeve version 5.0.0 (5.0.0.0) <E0CFD42D-C0B5-2263-537E-94C445438299> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
             0x106864000 -        0x106907fff +com.adobe.MediaCore.Frameworks.UI 1.0 (1.0) <12C0A4E1-03D5-68B9-EAFC-787869901268> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/MediaCoreUI.framework/Versions/A/MediaCoreUI
             0x106993000 -        0x106b79fff +com.adobe.SettingsUI.framework ??? (1.0) <C5DFEE49-FD5E-176A-52A8-55803BD58520> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/SettingsUI.framework/Versions/A/SettingsUI
             0x106dc3000 -        0x106f24fef +com.adobe.premiere.hsl 1.0 (1.0) <CE804842-637B-94D6-23E3-EF2FE70E1C6F> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HSL.framework/Versions/A/HSL
             0x1070a7000 -        0x1073f0ff9 +com.adobe.premiere.dialogs 1.0 (1.0) <287FABEB-954A-BFE0-40E7-C066967D3CD7> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/Dialogs.framework/Versions/A/Dialogs
             0x1076c4000 -        0x1076d4ff7 +com.adobe.premiere.HandlerAudioMiniMixer 1.0 (1.0) <F23C9266-EF5C-50D4-272E-E6FD289D7986> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerAudioMiniMixer.framework/Versions/A/HandlerAudioMiniMi xer
             0x1076f1000 -        0x107789fff +com.adobe.premiere.HandlerAudioMixer 1.0 (1.0) <AE50E31F-E9CE-BFBB-B41C-110CC920512B> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerAudioMixer.framework/Versions/A/HandlerAudioMixer
             0x107842000 -        0x1078d3fff +com.adobe.premiere.HandlerCapture 1.0 (1.0) <7574C707-338E-0211-94E9-DAC04754D505> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerCapture.framework/Versions/A/HandlerCapture
             0x107986000 -        0x10799efff +com.adobe.premiere.HandlerCSXS 1.0 (1.0) <25214B05-53CB-A1C3-01B7-CBFAB6311931> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerCSXS.framework/Versions/A/HandlerCSXS
             0x1079cc000 -        0x107bfeff7 +com.adobe.premiere.HandlerEffectControls 1.0 (1.0) <A485A3A0-950D-75A7-B681-B87A22A50558> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerEffectControls.framework/Versions/A/HandlerEffectContr ols
             0x107e05000 -        0x107e5fffb +com.adobe.premiere.HandlerEffects 1.0 (1.0) <035D5639-395B-95C6-CC33-72F5A8D26B06> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerEffects.framework/Versions/A/HandlerEffects
             0x107ebf000 -        0x107ecbfff +com.adobe.premiere.HandlerEvents 1.0 (1.0) <ABF2D371-0593-D3AB-08CB-D958A9F889A4> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerEvents.framework/Versions/A/HandlerEvents
             0x107ee7000 -        0x107ef7fff +com.adobe.premiere.HandlerGetProperties 1.0 (1.0) <B166664A-CCE9-D505-08AE-7D08A2FB76F1> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerGetProperties.framework/Versions/A/HandlerGetPropertie s
             0x107f12000 -        0x107f29fff +com.adobe.premiere.HandlerHistory 1.0 (1.0) <7C721FE1-E1A4-C30E-B1E1-97F3DB156FC4> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerHistory.framework/Versions/A/HandlerHistory
             0x107f4e000 -        0x107f98ff3 +com.adobe.premiere.HandlerInfo 1.0 (1.0) <A4E55B2E-76DE-7A35-E4CA-6132D7316284> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerInfo.framework/Versions/A/HandlerInfo
             0x107ff0000 -        0x108037ff7 +com.adobe.premiere.HandlerMetadataEditor 1.0 (1.0) <96985FF3-8785-06AE-88FF-1727D21A66E7> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerMetadataEditor.framework/Versions/A/HandlerMetadataEdi tor
             0x1080aa000 -        0x10810bff3 +com.adobe.premiere.HandlerMediaBrowser 1.0 (1.0) <8EA3C40A-F748-2002-51E8-80D05ECC9E13> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerMediaBrowser.framework/Versions/A/HandlerMediaBrowser
             0x10818a000 -        0x1081adff7 +com.adobe.premiere.HandlerMulticam 1.0 (1.0) <26316673-B806-DF8C-77A9-2F6A0110C5AD> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerMulticam.framework/Versions/A/HandlerMulticam
             0x1081e4000 -        0x108268ff7 +com.adobe.premiere.HandlerProgramMonitor 1.0 (1.0) <A8D8F4A5-74D7-85D4-69FE-9A3BEFF07D7A> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerProgramMonitor.framework/Versions/A/HandlerProgramMoni tor
             0x108317000 -        0x1084baffb +com.adobe.premiere.HandlerProject 1.0 (1.0) <E10941A9-41F0-8C11-43CD-C8C9D5AF1C06> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerProject.framework/Versions/A/HandlerProject
             0x108697000 -        0x108770fff +com.adobe.premiere.HandlerSourceMonitor 1.0 (1.0) <9F1E93BC-D2D9-8F47-A159-E25A32A92B49> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerSourceMonitor.framework/Versions/A/HandlerSourceMonito r
             0x108845000 -        0x108a1ffff +com.adobe.premiere.HandlerTimeline 1.0 (1.0) <B37FC8A0-33ED-CAA5-CF99-FD4775968153> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerTimeline.framework/Versions/A/HandlerTimeline
             0x108bf1000 -        0x108c56fff +com.adobe.premiere.FontEngine 1.0 (1.0) <E19F93B0-F3F2-C926-62C8-C13E5936A9CF> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/FontEngine.framework/Versions/A/FontEngine
             0x108cee000 -        0x108d1eff3 +com.adobe.premiere.TitleLayer 1.0 (1.0) <A9D21E4A-B36A-6158-3B87-9528E613A9F3> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/TitleLayer.framework/Versions/A/TitleLayer
             0x108ec7000 -        0x108ed4ff7 +com.adobe.premiere.TitleImageManager 1.0 (1.0) <FE1010C2-EDEA-50B4-92C8-B6B67C148A4C> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/TitleImageManager.framework/Versions/A/TitleImageManager
             0x108eeb000 -        0x108f8aff4 +com.adobe.premiere.TitleCharacterFactory 1.0 (1.0) <C83953BD-723B-1AB8-D279-7932CB7AD66B> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/TitleCharacterFactory.framework/Versions/A/TitleCharacterFact ory
             0x108feb000 -        0x109119fe3 +com.adobe.premiere.TitleCG 1.0 (1.0) <387A643D-6B30-7482-AC1C-4E36D5739595> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/TitleCG.framework/Versions/A/TitleCG
             0x1091e7000 -        0x109550fff +com.adobe.premiere.TitleLayout 1.0 (1.0) <6CCC5DFC-BDE0-5C85-6134-CAA28DCDFFE3> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/TitleLayout.framework/Versions/A/TitleLayout
             0x109c5a000 -        0x109cd4feb +com.adobe.premiere.TitleRenderer 1.0 (1.0) <CD1AE52E-03E3-18DA-CDD2-7FA530F678F0> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/TitleRenderer.framework/Versions/A/TitleRenderer
             0x109d83000 -        0x10a582fef +com.adobe.HandlerTitler.framework HandlerTitler version .. (...) <CC33326D-0065-5F55-5963-53C0130F3930> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerTitler.framework/Versions/A/HandlerTitler
             0x10ae11000 -        0x10af54fef +WRServices ??? (???) <DD50D315-C0EC-C729-AC67-92588187E8C7> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
             0x10afa0000 -        0x10afcfff7 +com.adobe.premiere.HandlerTools 1.0 (1.0) <AAD14A18-1599-7F89-75FE-6DC7C894D8FB> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerTools.framework/Versions/A/HandlerTools
             0x10b053000 -        0x10b090ff7 +com.adobe.premiere.HandlerTrim 1.0 (1.0) <EBC8F704-70EB-09F8-A533-25FC846BB2B1> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerTrim.framework/Versions/A/HandlerTrim
             0x10b0dc000 -        0x10b0ebfff +com.adobe.premiere.HandlerVSTEditor 1.0 (1.0) <B27D17DC-801C-2525-ED64-E42498D955BE> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/HandlerVSTEditor.framework/Versions/A/HandlerVSTEditor
             0x10b105000 -        0x10b119fff +com.adobe.premiere.CSXSHost 1.0 (1.0) <859F3054-D26D-0A31-41AA-34B6517AA19F> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/CSXSManager.framework/Versions/A/CSXSManager
             0x10b132000 -        0x10b2cdfff +com.adobe.PlugPlug 2.0.0.746 (2.0.0.746) <CB23C5AA-0E4B-182B-CB88-57DD32893F92> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
             0x10b375000 -        0x10b399fff +com.adobe.premiere.registration 1.0 (1.0) <89775C75-6F53-1A49-6DB0-108AE7DED66E> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/PrRegistration.framework/Versions/A/PrRegistration
             0x10b3b3000 -        0x10b482ff5 +com.adobe.premiere.frontend 1.0 (1.0) <FC72BB6C-253D-AA13-9DE9-E9BB7D5CE74E> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/Frontend.framework/Versions/A/Frontend
             0x10b570000 -        0x10b590fef +com.adobe.premiere.startup 1.0 (1.0) <FE592C25-583C-1AE6-5DB2-DD356D6DF19E> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/Startup.framework/Versions/A/Startup
             0x10b5a8000 -        0x10b68efe7  libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <26FC56A6-EFD6-22FA-E1F1-4E1BA61C85BB> /usr/lib/libcrypto.0.9.7.dylib
             0x10b6e6000 -        0x10b9befe6 +libxerces-c-3.0.dylib ??? (???) <46020284-EEA8-7D7B-388C-BF23A318C997> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/libxerces-c-3.0.dylib
             0x10bb38000 -        0x10bb38ff7  libmx.A.dylib 315.0.0 (compatibility 1.0.0) <B146C134-CE18-EC95-12F8-E5C2BCB43A6B> /usr/lib/libmx.A.dylib
             0x10bb3b000 -        0x10bb83fff +com.adobe.MediaCore.Frameworks.GPUFoundation ??? (1.0) <AD67C587-F3A4-625B-A9E1-A3F0C696E5E0> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/GPUFoundation.framework/Versions/A/GPUFoundation
             0x10bc90000 -        0x10bd40fff +com.adobe.exo.framework exo version 5.0.0 (5.0.0.0) <C09B268B-CFA1-7410-A9CD-10BE615AE3FB> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/exo.framework/Versions/A/exo
             0x10be46000 -        0x10be88fff +com.adobe.dynamiclinkui.framework dynamiclinkui version 5.0.0 (5.0.0.0) <1A6308C7-A971-7B75-E855-7599D2A647D1> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/dynamiclinkui.framework/Versions/A/dynamiclinkui
             0x10bede000 -        0x10bf09fff  com.apple.carbonframeworktemplate 1.0 (1.0) <2E4B79F1-3A34-0E34-25AB-7017375FDF3D> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/amefoundation.framework/Versions/A/amefoundation
             0x10bf45000 -        0x10bf6efff +ameproperties ??? (???) <7925BD83-5982-1A63-CD87-3849B74028E3> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/ameproperties.framework/Versions/A/ameproperties
             0x10bfb2000 -        0x10bfd3fff +AdobeBIBUtils ??? (???) <5DBF8E0C-F733-1148-9588-A01126793FD2> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
             0x10bfe0000 -        0x10bfe5fff +com.adobe.AppServices.framework ??? (1.0) <6BFBE64B-369E-58B0-25BF-6AF004A844BD> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AppServices.framework/Versions/A/AppServices
             0x10bff0000 -        0x10c046feb +com.adobe.headlights.LogSessionFramework ??? (2.0.1.011) <03B80698-2C3B-A232-F15F-8F08F8963A19> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
             0x10c08b000 -        0x10c091ff7  com.apple.agl 3.0.12 (AGL-3.0.12) <1AB34F57-2E8D-42FB-A484-5CCB928CA456> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
             0x10c098000 -        0x10c0edfff +com.adobe.dvametadata.framework dvametadata version 5.0.0 (5.0.0.0) <5E44BBC4-EE86-9909-D702-6EFE64AFC1EA> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
             0x10c164000 -        0x10c26bfef +com.adobe.dvametadataDB.framework dvametadataDB version 5.0.0 (5.0.0.0) <4EEEFD49-BBD8-01C4-8310-BF2DA639ED15> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/dvametadataDB.framework/Versions/A/dvametadataDB
             0x10c2b1000 -        0x10c337fff +com.adobe.dvametadataUI.framework dvametadataUI version 5.0.0 (5.0.0.0) <161A2DC8-5C4F-CA09-84F0-9D34ACDF11D1> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvametadataUI
             0x10c3c2000 -        0x10c3d9ff3 +com.adobe.dvastoryparser.framework dvastoryparser version 5.0.0 (5.0.0.0) <1BF0E64A-D20F-BC1D-DF8C-B362CC90ED17> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/dvastoryparser.framework/Versions/A/dvastoryparser
             0x10c3ee000 -        0x10c433fff +DynamicLinkMedia ??? (???) <74CB54FC-948C-CAAD-890A-3CE6DD751B53> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/DynamicLinkMedia.framework/Versions/A/DynamicLinkMedia
             0x10c4a2000 -        0x10c55aff0 +com.diaquest.pro4.omf 1.0.0.1022 (1.0.0.1022) <17FB2E1D-FC77-C307-AF1A-D940396FC0C7> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/Pro4OMF.framework/Versions/A/Pro4OMF
             0x10c57a000 -        0x10c57eff8 +com.adobe.ape.shim adbeape version 3.1.65.7508 (3.1.65.7508) <0C380604-C686-C2E4-0535-C1FAB230187E> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
             0x10c582000 -        0x10c5e4ff7 +com.adobe.MediaCore.Frameworks.Utilities.QT32Client 1.0 (1.0) <41753EC8-DB89-28DB-8D83-6FD19A941E85> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/QT32Client.framework/Versions/A/QT32Client
             0x10c657000 -        0x10c6c7fff +PProDynamicLinkServer ??? (???) <8965F2BA-9EAC-A416-C936-A62E57CF7F88> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/PProDynamicLinkServer.framework/Versions/A/PProDynamicLinkSer ver
             0x10c770000 -        0x10c8b2fef +com.adobe.MediaCore.Frameworks.Display ??? (1.0) <697EA766-6B92-44C1-60CC-DD91813A98F0> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/Display.framework/Versions/A/Display
             0x10cb14000 -        0x10cb78fff +aif_core ??? (???) <3533CEBF-44A1-22E1-5962-8055FA0FEF3A> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/aif_core.framework/Versions/A/aif_core
             0x10cb93000 -        0x10cdc0fff +aif_ogl ??? (???) <4626986B-F548-6133-0AC1-2F950DBAD5EE> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/aif_ogl.framework/Versions/A/aif_ogl
             0x10ce9d000 -        0x10cebbfff +image_runtime ??? (???) <9097A2BE-88FD-3A2F-CACB-AE8BDE35C167> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/image_runtime.framework/Versions/A/image_runtime
             0x10ced7000 -        0x10cf23fe7  com.apple.glut 3.4.4 (GLUT-3.4.4) <78324374-C4AC-2358-3D61-55060E44FC38> /System/Library/Frameworks/GLUT.framework/Versions/A/GLUT
             0x10cfa4000 -        0x10cfbdfeb +libtbb.dylib ??? (???) /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/libtbb.dylib
             0x10cfce000 -        0x10cfd4feb +libtbbmalloc.dylib ??? (???) /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/libtbbmalloc.dylib
             0x10d3d9000 -        0x10d3e1fff +com.adobe.asneu.framework asneu version 1.7.0.1 (1.7.0.1) <3D59CB21-F5C7-4232-AB00-DFEB04206024> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
             0x10d3ee000 -        0x10d3f0fef  com.apple.textencoding.unicode 2.3 (2.3) <B254327D-2C4A-3296-5812-6F74C7FFECD9> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
             0x10d6e4000 -        0x10d70afff  GLRendererFloat ??? (???) <10AFC7E0-A5CE-8F0E-7084-439BE59F7E95> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFl oat
             0x10d712000 -        0x10d782ff6 +com.adobe.amt.services AMTServices 3.0.0.64 (BuildVersion: 3.0; BuildDate: Mon Jan 26 2010 21:49:00) (3.0.0.64) <52FF1F9B-9991-ECE2-C7E3-09DA1B368CBE> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/amtservices.framework/Versions/A/amtservices
             0x10d7f0000 -        0x10d7f4fff  com.apple.audio.AudioIPCPlugIn 1.1.2 (1.1.2) <F6E20DCA-3C00-8990-1F60-E5517F7D0C77> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/C ontents/MacOS/AudioIPCPlugIn
             0x11e800000 -        0x11e98dfe7  GLEngine ??? (???) <57D733C2-F7CB-2B8F-CD34-C85A193145DE> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
             0x11e9be000 -        0x11ede1fef  libclh.dylib 3.1.1 C  (3.1.1) <83F3C7DB-D2E2-07B0-E433-386C9428AD72> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
             0x11eeec000 -        0x11eef2fff  com.apple.audio.AppleHDAHALPlugIn 1.8.7 (1.8.7f1) <97D7045E-CFD7-AD5C-6954-3B7C3F367C63> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
             0x11f000000 -        0x11f078fef +com.adobe.adobe_caps adobe_caps 3.0.116.0 (3.0.116.0) <4A355686-1451-B19A-0C55-DFE49FD2539E> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
             0x11fff3000 -        0x11fff8fff +com.adobe.MediaCore.ExporterCoreAudio 1.0 (1.0) <E3EDBFFA-6C22-D7ED-CA25-D203949CB312> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-Ins/Common/ExporterCoreAudio.bundle/Contents/MacOS/ExporterCoreAudi o
             0x120b66000 -        0x120b68fff +com.adobe.MediaCore.Motion 1.0 (1.0) <1A5319DD-E3B3-5A68-F66C-978DDDF580FB> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-Ins/Common/Motion.bundle/Contents/MacOS/Motion
             0x120b6b000 -        0x120b6dffa +com.adobe.MediaCore.Opacity 1.0 (1.0) <0E67D617-0B41-05E6-F77C-FD970F1A23B8> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-Ins/Common/Opacity.bundle/Contents/MacOS/Opacity
             0x120b72000 -        0x120b77fff +com.adobe.MediaCore.AEFilterCrop 1.0 (1.0) <7BD7880F-2096-0EAA-EE43-12D66D202868> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-Ins/Common/AEFilterCrop.bundle/Contents/MacOS/AEFilterCrop
             0x120b7c000 -        0x120b7eff7 +com.adobe.MediaCore.AEFilterGaussianBlur 1.0 (1.0) <F7836261-E7D6-6C9F-6222-6F3429673D62> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-Ins/Common/AEFilterGaussianBlur.bundle/Contents/MacOS/AEFilterGauss ianBlur
             0x120b93000 -        0x120b94fff  ATSHI.dylib ??? (???) <0C6E12AA-4D29-7892-77CA-0B9D2C1627F5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/ATSHI.dylib
             0x120c23000 -        0x120c3dfff +com.adobe.pip ??? (5.0.0.2021) <47380937-5088-41F7-50FA-ADAC9B15C783> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
             0x1214e2000 -        0x1214f8ffb +com.adobe.MediaCore.DeviceControlFirewire 1.0 (1.0) <13EE2049-0992-2186-AE79-9FECF42ED839> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-Ins/Common/DeviceControlFireWire.bundle/Contents/MacOS/DeviceContro lFirewire
             0x122e5c000 -        0x122e86ff1 +com.mainconcept.mc_dec_dv 8.5 (8.5.0.14572) <CFF0820D-B6C1-0DB8-43DE-35169748FD94> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/mc_dec_dv.framework/mc_dec_dv
             0x122e9f000 -        0x122ec6ff1 +com.mainconcept.mc_enc_dv 8.5 (8.5.0.14572) <46AB8404-6892-F7BF-150E-D8249ECFD0B8> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/mc_enc_dv.framework/mc_enc_dv
             0x12315e000 -        0x123179fff  com.apple.carbonframeworktemplate 1.0 (1.0) <C0AAB79C-8A00-3504-89F9-8DF31CE7EF77> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/VXMLPresetReader.framework/vxmlpresetreader
             0x12328d000 -        0x1233befef +com.adobe.premiere.AAFProjectConverter 1.0 (1.0) <299DEB9E-5BC3-394F-8C11-E928E0B21AF7> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-Ins/Common/AAF.bundle/Contents/MacOS/AAF
             0x1234bc000 -        0x1236ddfef +libMXF_SDK_r.4.2.319.dylib 4.2.0 (compatibility 4.2.0) /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_r.4.2.319.dylib
             0x123874000 -        0x1238b6ff3 +libMXF_SDK_XML_r.4.2.319.dylib 4.2.0 (compatibility 4.2.0) /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_XML_r.4.2.319.dylib
             0x1238de000 -        0x123baaff6 +libxerces-c-3.0.dylib ??? (???) /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-Ins/Common/MOG/Frameworks/libxerces-c-3.0.dylib
             0x123d40000 -        0x124115fef +libxqilla.5.0.0.dylib 6.0.0 (compatibility 6.0.0) /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-Ins/Common/MOG/Frameworks/libxqilla.5.0.0.dylib
             0x1243dc000 -        0x124405fff +libMOG_Framework_r.2.0.8.dylib 2.0.8 (compatibility 2.0.8) <F686FD64-AF59-C0EA-F3E4-FA05E4144F73> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMOG_Framework_r.2.0.8.dylib
             0x124420000 -        0x12448afe7 +libMXF_SDK_Modules_r.1.1.34.dylib 1.1.0 (compatibility 1.1.0) /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_Modules_r.1.1.34.dylib
             0x1244c4000 -        0x1244d3fe7 +com.adobe.MediaCore.Frameworks.AudioConverter 1.0 (1.0) <B62BE0C9-9A05-D974-0ED6-3CAB08BB6CC5> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AudioConverter.framework/Versions/A/AudioConverter
             0x1244f7000 -        0x12471afff  com.apple.audio.codecs.Components 2.0.1 (2.0.1) <6DA1101A-DE4D-6EC9-8B3E-499F5FAE1FAE> /System/Library/Components/AudioCodecs.component/Contents/MacOS/AudioCodecs
             0x124775000 -        0x12479bff3 +com.adobe.MediaCore.ExporterQuickTimeHost 1.0 (1.0) <19A6FE2A-B579-DADF-E40B-B50B80562D3D> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-Ins/Common/ExporterQuickTimeHost.bundle/Contents/MacOS/ExporterQuic kTimeHost
             0x1247cc000 -        0x1247e3fff +com.adobe.MediaCore.Frameworks.QTParser 1.0 (1.0) <F9D865FF-81B3-1EFA-03F4-4E600B13B22E> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/QTParser.framework/Versions/A/QTParser
             0x124a89000 -        0x124b8ffff +com.adobe.FCPXProjectConverter 1.0.24 (1.0.24) <5CB031BF-85C8-3330-FC99-091F637BEC05> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-Ins/Common/FCPXProjectConverter.bundle/Contents/MacOS/FCPXProjectCo nverter
             0x124c3b000 -        0x124c72fff +com.adobe.MediaCore.ImporterQuickTime 1.0 (1.0) <7D43FB64-540D-311F-0601-D4726D709434> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-Ins/Common/ImporterQuickTime.bundle/Contents/MacOS/ImporterQuickTim e
             0x124ca8000 -        0x124cbfff7 +com.red.ImporterRED 1.01 (1.0) <0142ECAF-941B-D394-18FC-48D5067026B9> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-Ins/Common/ImporterRED.bundle/Contents/MacOS/ImporterRED
             0x124cdb000 -        0x124d51fff +com.adobe.MediaCore.PlayerMediaCore 1.0 (1.0) <F6FE3EDB-69EB-1306-5DE8-E57B27A392E6> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-Ins/Common/PlayerMediaCore.bundle/Contents/MacOS/PlayerMediaCore
             0x124dc1000 -        0x124df6ffa  com.apple.AVCVideoServices 1.0 (42) <ABDC5101-F07C-34AD-63A4-1F6F256BB0AA> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AVCVideoServices.framework/Versions/A/AVCVideoServices
             0x124e24000 -        0x124e42fe7 +com.adobe.MediaCore.AudioVideoIO 1.0 (1.0) <7E4798E3-4212-4AE3-D2BE-0A15A71EFEC9> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/AudioVideoIO.framework/Versions/A/AudioVideoIO
             0x125109000 -        0x125118fe4 +com.adobe.MediaCore.PremiereFiltersMetaPlugin 1.0 (1.0) <E2DCBA0C-4C59-971A-512C-794FF69C386F> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-Ins/Common/PremiereFiltersMetaPlugin.prmp/Contents/MacOS/PremiereFi ltersMetaPlugin
             0x12512e000 -        0x125149ffb +com.adobe.MediaCore.RecorderHDVMac 1.0 (1.0) <D6724AFA-6990-DA86-6874-A37B9F9FF6E4> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-Ins/Common/RecorderHDVMac.bundle/Contents/MacOS/RecorderHDVMac
             0x125168000 -        0x12531efef +com.mainconcept.mc_dec_mp2v 8.5 (8.5.0.14572) /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/mc_dec_mp2v.framework/Versions/8.5/mc_dec_mp2v
             0x125327000 -        0x1253f7ff7 +com.adobe.MediaCore.IPPMPEGDecoder 1.0 (1.0) <249F98B5-150A-DA92-1535-8EA193781B35> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/IPPMPEGDecoder.framework/Versions/A/IPPMPEGDecoder
             0x12543c000 -        0x125462fff +com.adobe.MediaCore.RecorderQTKit 1.0 (1.0) <0BC1733C-3391-B3DC-39C8-40168C8AE4BF> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-Ins/Common/RecorderQTKit.bundle/Contents/MacOS/RecorderQTKit
             0x12548d000 -        0x12549ffe6 +com.adobe.MediaCore.TransitionsMetaPlugin 1.0 (1.0) <A2B12358-85C3-1033-9D33-CF4FF7E2A335> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-Ins/Common/TransitionsMetaPlugin.prmp/Contents/MacOS/TransitionsMet aPlugin
             0x1257cc000 -        0x1257ecffb +com.adobe.ape adbeapecore version 3.1.65.7508 (3.1.65.7508) <284C86BE-ACD8-31DD-E58D-544F581BC93B> /Library/Application Support/Adobe/APE/3.1/adbeapecore.framework/adbeapecore
             0x125983000 -        0x1259abfef +ServiceManager-Launcher.dylib ??? (???) <4608E5E7-7F22-A4FF-527C-E97EA339FCCC> /Library/Application Support/Adobe/CS5ServiceManager/lib/ServiceManager-Launcher.dylib
             0x129a98000 -        0x129a9efe7  libFontStreams.A.dylib 543.50.0 (compatibility 64.0.0) <4A8E88F8-1E04-09C9-5019-3C2742DC5D7B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libFontStreams.A.dylib
             0x12b95b000 -        0x12b95cff7 +com.adobe.PProAEFilter.Bevel_Edges ??? (1.0) <2D4E8290-6E13-B656-4F90-B9B32D697E08> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-Ins/Common/Bevel_Edges.bundle/Contents/MacOS/Bevel_Edges
             0x12b95f000 -        0x12b95fff7 +com.adobe.PProAEFilter.Mosaic ??? (1.0) <9C0ECB15-FDB3-C92E-278A-04AEB7ACF273> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-Ins/Common/Mosaic.bundle/Contents/MacOS/Mosaic
             0x12b962000 -        0x12b967fff +com.adobe.PProAEFilter.Twirl ??? (1.0) <EBD9ED28-3B0F-55E3-447D-FD18C2E457DD> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-Ins/Common/Twirl.bundle/Contents/MacOS/Twirl
             0x12cc8f000 -        0x12cccdff7  com.apple.DP.ScreenInputDevice 13.0 (13.0) <22174597-D163-7A20-C82A-C00C2CA19640> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Resources/AppleScreenInpu tDevice.plugin/Contents/MacOS/AppleScreenInputDevice
             0x12f5c6000 -        0x13040dfcf +com.adobe.adobeswfl ??? (2.0.0.7489) <DBD38111-48D6-C031-EF50-D034C94ED38B> /Library/Application Support/Adobe/APE/3.1/adbeapecore.framework/Resources/AdobeSWFL.bundle/Contents/MacOS/Ado beSWFL
             0x131b66000 -        0x131b82ff7 +com.adobe.MediaCore.ImporterJPEG 1.0 (1.0) <C74B6673-E592-C08C-18FC-41FB3F4F982F> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-Ins/Common/ImporterJPEG.bundle/Contents/MacOS/ImporterJPEG
             0x13419e000 -        0x1341b9fff +com.adobe.MediaCore.ImporterPNG 1.0 (1.0) <34C3496E-7D32-1836-D09F-FDE8F10C4659> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-Ins/Common/ImporterPNG.bundle/Contents/MacOS/ImporterPNG
             0x136bd4000 -        0x136c39fff +com.adobe.MediaCore.ImporterMp3 1.0 (1.0) <008D2CDF-50B0-A83C-42FC-9F25A60890C3> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Plug-Ins/Common/ImporterMp3.bundle/Contents/MacOS/ImporterMp3
             0x136cc6000 -        0x136cddfe7  libJapaneseConverter.dylib 49.0.0 (compatibility 1.0.0) <1B9D1076-CC7C-521A-676C-F7BE51F65271> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
             0x136ce1000 -        0x136cf0fe7  libSimplifiedChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <0628B99F-F193-89BF-6332-B8C50D301F29> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
             0x136cf4000 -        0x136d06fff  libTraditionalChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <A77665EF-B6FB-00B4-2F3D-90D7845814C9> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
             0x136d0a000 -        0x136d2bfef  libKoreanConverter.dylib 49.0.0 (compatibility 1.0.0) <FA6280BD-A73C-3A3D-6494-81EB80FE1C24> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
             0x1371c8000 -        0x137205feb +com.adobe.AAM.AdobeUpdaterNotificationFramework UpdaterNotifications 1.0.0.64 (1.0.0.64) <CD8BD7C7-0F66-29B6-C158-A6EF8DF69996> /Applications/Adobe Premiere Pro CS5/Adobe Premiere Pro CS5.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotification s
             0x200000000 -        0x2006fbff7  com.apple.GeForceGLDriver 1.6.16 (6.1.6) <4F3D3917-641B-AA12-04DE-D3A1995C3B18> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
          0x7fff5fc00000 -     0x7fff5fc3bdef  dyld 132.1 (???) <B536F2F1-9DF1-3B6C-1C2C-9075EA219A06> /usr/lib/dyld
          0x7fff80003000 -     0x7fff80004ff7  com.apple.audio.units.AudioUnit 1.6.3 (1.6.3) <D4183AC4-8A65-8368-A9AF-E2A13D18519C> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
          0x7fff80005000 -     0x7fff80014ff7  com.apple.opengl 1.6.8 (1.6.8) <0CDC4F98-7981-A114-1778-AF171075138E> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
          0x7fff80015000 -     0x7fff80015ff7  com.apple.Carbon 150 (152) <19B37B7B-1594-AD0A-7F14-FA2F85AD7241> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
          0x7fff80299000 -     0x7fff802e8fef  libTIFF.dylib ??? (???) <A66CBA9C-A38D-5EDB-BFB5-CB398F033D6F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
          0x7fff802e9000 -     0x7fff802ecfff  com.apple.help 1.3.1 (41) <E311A81E-9870-A430-1E16-AFF6C92CE6E5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
          0x7fff802ed000 -     0x7fff80335ff7  libvDSP.dylib 268.0.1 (compatibility 1.0.0) <170DE04F-89AB-E295-0880-D69CAFBD7979> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
          0x7fff80439000 -     0x7fff80474fff  com.apple.AE 496.4 (496.4) <CBEDB6A1-FD85-F842-4EB8-CC289FAE0F24> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
          0x7fff80475000 -     0x7fff8052efff  libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <5A15E12A-AE8F-1A36-BBC7-564E7D7AD0FB> /usr/lib/libsqlite3.dylib
          0x7fff8052f000 -     0x7fff8057efef  com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0) <BD71B20B-C530-6D10-47A4-9838CF292911> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
          0x7fff8057f000 -     0x7fff805c0fff  com.apple.SystemConfiguration 1.10.2 (1.10.2) <BC27BDD4-9CC8-9AF0-B4C2-DD50FD751CBF> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
          0x7fff805da000 -     0x7fff805daff7  com.apple.Cocoa 6.6 (???) <68B0BE46-6E24-C96F-B341-054CF9E8F3B6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
          0x7fff805db000 -     0x7fff805edfe7  libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <76B83C8D-8EFE-4467-0F75-275648AFED97> /usr/lib/libsasl2.2.dylib
          0x7fff80612000 -     0x7fff80945fe7  com.apple.CoreServices.CarbonCore 861.13 (861.13) <BC2F9B4E-D305-D717-D97E-EC78C7DE9EE9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
          0x7fff80946000 -     0x7fff80946ff7  com.apple.Accelerate 1.6 (Accelerate 1.6) <2BB7D669-4B40-6A52-ADBD-DA4DB3BC0B1B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
          0x7fff80947000 -     0x7fff81044067  com.apple.CoreGraphics 1.543.50 (???) <46A7D60C-0500-B96C-ECAD-1D658487D213> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
          0x7fff81045000 -     0x7fff81086ff7  com.apple.CoreMedia 0.484.11 (484.11) <AEE7E9C9-9604-B0A7-053B-28954659CFE3> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
          0x7fff81087000 -     0x7fff81a7dfff  com.apple.AppKit 6.6.6 (1038.29) <7BDD335D-5425-0354-5AD6-41C4F1B4A2F4> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
          0x7fff81a7e000 -     0x7fff81a83fff  libGFXShared.dylib ??? (???) <1265FAEF-1C97-B339-28A4-4510589B067B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
          0x7fff81ab5000 -     0x7fff81afeff7  com.apple.securityinterface 4.0.1 (37214) <68CC3A69-1078-EAB0-3E18-93D051C4F5E0> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
          0x7fff81b0b000 -     0x7fff81b54fef  libGLU.dylib ??? (???) <34D118CD-F9EE-D023-FEBF-74581DEF31CD> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
          0x7fff81db4000 -     0x7fff81e20ff7  com.apple.CorePDF 1.3 (1.3) <6770FFB0-DEA0-61E0-3520-4B95CCF5D1CF> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
          0x7fff81e21000 -     0x7fff82004fef  libType1Scaler.dylib ??? (???) <4C5DD699-D329-CBC4-018B-D9033DB6A3D6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libType1Scaler.dylib
          0x7fff82005000 -     0x7fff82005ff7  com.apple.vecLib 3.6 (vecLib 3.6) <08D3D45D-908B-B86A-00BA-0F978D2702A7> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
          0x7fff82006000 -     0x7fff82014ff7  libkxld.dylib ??? (???) <EE840168-1F67-6219-8BA3-C46039BCC8B3> /usr/lib/system/libkxld.dylib
          0x7fff82015000 -     0x7fff82184fe7  com.apple.QTKit 7.6.6 (1742) <7E254184-757D-E87C-5B2A-7612A2C85243> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
          0x7fff821d0000 -     0x7fff8222eff7  com.apple.framework.IOKit 2.0 (???) <010C3398-7363-8F4B-719C-263867F15F63> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
          0x7fff8222f000 -     0x7fff825a4fe7  com.apple.RawCamera.bundle 3.0.3 (529) <2E6B251A-C5A5-A3F9-832B-BB1958F938E9> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
          0x7fff825a5000 -     0x7fff825e6fef  com.apple.QD 3.35 (???) <78C9A560-E6F7-DC4F-F85E-E63CF8A98F0B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
          0x7fff825e7000 -     0x7fff8279dfef  com.apple.ImageIO.framework 3.0.3 (3.0.3) <A32D0B5A-7149-7739-22D3-84D38B07E9E5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
          0x7fff828d1000 -     0x7fff828e5fff  libGL.dylib ??? (???) <5AD69545-D1A3-C017-C7AF-B4AFD6F08FA2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
          0x7fff828e6000 -     0x7fff82901ff7  com.apple.openscripting 1.3.1 (???) <2243C17C-EE36-D5B6-3A3E-8258973FF789> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
          0x7fff82902000 -     0x7fff829dcff7  com.apple.vImage 4.0 (4.0) <354F34BF-B221-A3C9-2CA7-9BE5E14AD5AD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
          0x7fff82a1c000 -     0x7fff82aa8fef  SecurityFoundation ??? (???) <6860DE26-0D42-D1E8-CD7C-5B42D78C1E1D> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
          0x7fff82aa9000 -     0x7fff82ab8fff  com.apple.NetFS 3.2.1 (3.2.1) <3C6C2D5E-C1E2-9FF9-97A2-4141A5660EBB> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
          0x7fff82ab9000 -     0x7fff82b89ff7  com.apple.CFNetwork 454.9.7 (454.9.7) <AA6EB690-6CCF-603D-AAC2-35B9E05D1593> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
          0x7fff82b8a000 -     0x7fff82c94ff7  com.apple.MeshKitIO 1.1 (49.2) <F296E151-80AE-7764-B969-C2050DF26BFE> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitIO.frame work/Versions/A/MeshKitIO
          0x7fff82c95000 -     0x7fff82c96ff7  com.apple.TrustEvaluationAgent 1.1 (1) <040B71B1-F8BD-1605-057E-E80DBDE1FE59> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
          0x7fff82c97000 -     0x7fff82cdcfff  com.apple.CoreMediaIOServices 130.0 (1035) <567D7949-3115-4E78-8F27-B28968CC25F7> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOSer vices
          0x7fff82e4c000 -     0x7fff831e5ff7  com.apple.QuartzCore 1.6.2 (227.22) <76EE0A32-B20B-F316-ADDD-4230329253D5> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
          0x7fff831e6000 -     0x7fff831eaff7  libCGXType.A.dylib 543.50.0 (compatibility 64.0.0) <E666EBC7-2D87-A3C6-9461-A596B4E53593> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
          0x7fff831fe000 -     0x7fff833e8fe7  com.apple.JavaScriptCore 6533 (6533.13) <C2D33B72-06F1-B789-6FD3-FB09EEB6C907> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
          0x7fff833e9000 -     0x7fff83426ff7  libFontRegistry.dylib ??? (???) <B63FCC3A-F49E-B42E-6D57-5F59E3A8D8B9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
          0x7fff83457000 -     0x7fff83482ff7  libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <87A0B228-B24A-C426-C3FB-B40D7258DD49> /usr/lib/libxslt.1.dylib
          0x7fff83483000 -     0x7fff8348bfff  com.apple.DisplayServicesFW 2.2.2 (251) <A8AA237B-26DA-455D-4133-69B1D1E45DF4> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
          0x7fff84146000 -     0x7fff84950fe7  libBLAS.dylib 219.0.0 (compatibility 1.0.0) <EEE5CE62-9155-6559-2AEA-05CED0F5B0F1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
          0x7fff84951000 -     0x7fff84951ff7  com.apple.quartzframework 1.5 (1.5) <B182B579-BCCE-81BF-8DA2-9E0B7BDF8516> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
          0x7fff8495f000 -     0x7fff849a2ff7  libRIP.A.dylib 543.50.0 (compatibility 64.0.0) <DF457CB3-CE61-0FD4-1403-BB68BC2CC998> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
          0x7fff849a3000 -     0x7fff849b8ff7  com.apple.LangAnalysis 1.6.6 (1.6.6) <DC999B32-BF41-94C8-0583-27D9AB463E8B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
          0x7fff849b9000 -     0x7fff84ad0fef  libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <4355C785-9388-1061-6427-D004E92A3766> /usr/lib/libxml2.2.dylib
          0x7fff84b86000 -     0x7fff84caeff7  com.apple.MediaToolbox 0.484.11 (484.11) <F50B5552-8527-C75D-873F-66A61D04E32A> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
          0x7fff84caf000 -     0x7fff84d19fe7  libvMisc.dylib 268.0.1 (compatibility 1.0.0) <75A8D840-4ACE-6560-0889-2AFB6BE08E59> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
          0x7fff84d1a000 -     0x7fff84d9ffff  com.apple.print.framework.PrintCore 6.2 (312.5) <E736F6DC-2E69-A14D-6BCF-69D14232F8B8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
          0x7fff84da0000 -     0x7fff84e3afff  com.apple.ApplicationServices.ATS 4.3 (???) <A7CD9E1F-C563-E940-130D-AA7E08C5A29F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
          0x7fff84e3b000 -     0x7fff84fb0ff7  com.apple.CoreFoundation 6.6.3 (550.29) <48810602-63C3-994D-E563-DD02B16E76E1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
          0x7fff84fb1000 -     0x7fff84fb4ff7  libCoreVMClient.dylib ??? (???) <DBB2C09F-4BF4-326C-B775-B7A128C501E3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
          0x7fff8511f000 -     0x7fff85244fef  com.apple.audio.toolbox.AudioToolbox 1.6.3 (1.6.3) <4DCCD01F-7516-4240-09DC-EE553317D345> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
          0x7fff85286000 -     0x7fff85335fff  edu.mit.Kerberos 6.5.10 (6.5.10) <F3F76EDF-5660-78F0-FE6E-33B6174F55A4> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
          0x7fff8542e000 -     0x7fff854abfef  libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <35ECA411-2C08-FD7D-11B1-1B7A04921A5C> /usr/lib/libstdc++.6.dylib
          0x7fff854ac000 -     0x7fff8551afff  com.apple.AppleVAFramework 4.9.20 (4.9.20) <78727165-8D44-0354-6F6C-68FD798E04A1> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
          0x7fff8551b000 -     0x7fff85570fef  com.apple.framework.familycontrols 2.0.1 (2010) <239940AC-2427-44C6-9E29-998D0ABECDF3> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
          0x7fff85571000 -     0x7fff8558afff  com.apple.CFOpenDirectory 10.6 (10.6) <0F46E102-8B8E-0995-BA85-3D9608F0A30C> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
          0x7fff85723000 -     0x7fff859a4fef  com.apple.Foundation 6.6.3 (751.29) <DAEDB589-9F59-9556-CF8D-07556317937B> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
          0x7fff859a5000 -     0x7fff859bbfef  libbsm.0.dylib ??? (???) <83676D2E-23CD-45CD-BE5C-35FCFFBBBDBB> /usr/lib/libbsm.0.dylib
          0x7fff859bc000 -     0x7fff859c1ff7  com.apple.CommonPanels 1.2.4 (91) <4D84803B-BD06-D80E-15AE-EFBE43F93605> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
          0x7fff859c2000 -     0x7fff85ad1fe7  libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <36DA89A6-3AF5-86F2-BDD5-B94C7C0844D4> /usr/lib/libcrypto.0.9.8.dylib
          0x7fff85ad2000 -     0x7fff85bb8fe7  com.apple.DesktopServices 1.5.7 (1.5.7) <8A697128-B6CA-E4A8-C200-6520D5A35FBE> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
          0x7fff85bb9000 -     0x7fff85bbafff  com.apple.MonitorPanelFramework 1.3.0 (1.3.0) <5062DACE-FCE7-8E41-F5F6-58821778629C> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
          0x7fff85be0000 -     0x7fff85be0ff7  com.apple.CoreServices 44 (44) <210A4C56-BECB-E3E4-B6EE-7EC53E02265D> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
          0x7fff85be1000 -     0x7fff85e67ff7  com.apple.security 6.1.1 (37594) <5EDDC08C-C95B-2D24-E1D2-D30D233AB065> /System/Library/Frameworks/Security.framework/Versions/A/Security
          0x7fff85edd000 -     0x7fff85f0dfef  com.apple.shortcut 1.1 (1.1) <A99C9D8E-290B-B1E4-FEA5-CC5F2FB9C18D> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
          0x7fff85f0e000 -     0x7fff85f24ff7  com.apple.MultitouchSupport.framework 204.13 (204.13) <BFFEC259-F103-B25A-BB52-1AA79116DDBA> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
          0x7fff85f25000 -     0x7fff85f54ff7  com.apple.quartzfilters 1.6.0 (1.6.0) <9CECB4FC-1CCF-B8A2-B935-5888B21CBEEF> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
          0x7fff85f55000 -     0x7fff86190fef  com.apple.imageKit 2.0.3 (1.0) <8DA80BC9-C671-BD89-EA2E-3C632D6ECE30> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
          0x7fff86191000 -     0x7fff86220fff  com.apple.PDFKit 2.5.1 (2.5.1) <7B8A187A-F0BB-44E7-FBD4-9E1C5F9D5E85> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
          0x7fff86221000 -     0x7fff86227ff7  IOSurface ??? (???) <EB2019F6-7C5C-3D59-E11F-6119466C12A9> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
          0x7fff86228000 -     0x7fff8622dfff  libGIF.dylib ??? (???) <21FC6B02-6AC3-C4DB-0B50-98144802274C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
          0x7fff8622e000 -     0x7fff862ebff7  com.apple.CoreServices.OSServices 357 (357) <718F0719-DC9F-E392-7C64-9D7DFE3D02E2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
          0x7fff862ec000 -     0x7fff862f0ff7  libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <95718673-FEEE-B6ED-B127-BCDBDB60D4E5> /usr/lib/system/libmathCommon.A.dylib
          0x7fff863f6000 -     0x7fff863f6ff7  com.apple.ApplicationServices 38 (38) <10A0B9E9-4988-03D4-FC56-DDE231A02C63> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
          0x7fff86427000 -     0x7fff86464fff  com.apple.LDAPFramework 2.0 (120.1) <16383FF5-0537-6298-73C9-473AEC9C149C> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
          0x7fff86465000 -     0x7fff8649dff7  libssl.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <94776929-EF76-D979-5412-940C845BAC5D> /usr/lib/libssl.0.9.8.dylib
          0x7fff8649e000 -     0x7fff8665efef  libSystem.B.dylib 125.2.0 (compatibility 1.0.0) <95E02DD0-ADEA-745B-E7FA-ABA064E4658C> /usr/lib/libSystem.B.dylib
          0x7fff8665f000 -     0x7fff8669bfe7  libcurl.4.dylib 6.1.0 (compatibility 6.0.0) <1E041185-131C-C237-C250-38BE933A269A> /usr/lib/libcurl.4.dylib
          0x7fff866d1000 -     0x7fff8688ffff  libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <0E53A4A6-AC06-1B61-2285-248F534EE356> /usr/lib/libicucore.A.dylib
          0x7fff86991000 -     0x7fff86998fff  com.apple.OpenDirectory 10.6 (10.6) <72A65D76-7831-D31E-F1B3-9E48BF26A98B> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
          0x7fff86999000 -     0x7fff869e3ff7  com.apple.Metadata 10.6.3 (507.10) <641395B7-FF2C-B94C-965A-CE6A0830645F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
          0x7fff869e4000 -     0x7fff86a1dff7  com.apple.MeshKit 1.1 (49.2) <3795F201-4A5F-3D40-57E0-87AD6B714239> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKit
          0x7fff86a20000 -     0x7fff86a2bff7  com.apple.speech.recognition.framework 3.11.1 (3.11.1) <5CA110A2-0712-F774-E7CF-AA7A2A106DAC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
          0x7fff86aeb000 -     0x7fff86c29fff  com.apple.CoreData 102.1 (251) <32233D4D-00B7-CE14-C881-6BF19FD05A03> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
          0x7fff86c2a000 -     0x7fff86c71fef  com.apple.QuickLookFramework 2.2 (327.4) <4E1658D4-F268-2A82-C095-1D01E9EAD05F> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
          0x7fff86c72000 -     0x7fff86c74fff  libRadiance.dylib ??? (???) <D67C08B6-4D4A-916D-E936-528E145A56E2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
          0x7fff86c75000 -     0x7fff86c77fff  com.apple.print.framework.Print 6.1 (237.1) <4513DB2F-737C-B43C-2D0E-23CD6E838014> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
          0x7fff86c78000 -     0x7fff86ca9fff  libGLImage.dylib ??? (???) <2F18DB77-CF77-1311-9E20-FE460090C166> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
          0x7fff86caa000 -     0x7fff86dc3fef  libGLProgrammability.dylib ??? (???) <B057FC52-6A97-F450-48D8-325A70423A53> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
          0x7fff86e0f000 -     0x7fff8710dfe7  com.apple.HIToolbox 1.6.3 (???) <CF0C8524-FA82-3908-ACD0-A9176C704AED> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
          0x7fff8710e000 -     0x7fff8711fff7  libz.1.dylib 1.2.3 (compatibility 1.0.0) <FB5EE53A-0534-0FFA-B2ED-486609433717> /usr/lib/libz.1.dylib
          0x7fff87136000 -     0x7fff8717dff7  com.apple.coreui 2 (114) <D7645B59-0431-6283-7322-957D944DAB21> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
          0x7fff8717e000 -     0x7fff8718ffff  com.apple.DSObjCWrappers.Framework 10.6 (134) <3C08225D-517E-2822-6152-F6EB13A4ADF9> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
          0x7fff87190000 -     0x7fff8720efff  com.apple.CoreText 3.1.0 (???) <B740DA1D-EFD0-CCBF-F893-E3004FE58A98> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
          0x7fff8720f000 -     0x7fff8722dfff  libPng.dylib ??? (???) <F6932C8D-E6B1-0871-B698-15180AA948F7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
          0x7fff8722e000 -     0x7fff872eefff  libFontParser.dylib ??? (???) <A4F8189D-1D5B-2F8D-E78E-6D934A8E8407> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
          0x7fff872ef000 -     0x7fff872f5ff7  com.apple.DiskArbitration 2.3 (2.3) <857F6E43-1EF4-7D53-351B-10DE0A8F992A> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
          0x7fff872f6000 -     0x7fff87339fff  libtidy.A.dylib ??? (???) <8AF4DB3A-7BDB-7AF7-0E9C-413BBBD0E380> /usr/lib/libtidy.A.dylib
          0x7fff8733a000 -     0x7fff8783efe7  com.apple.VideoToolbox 0.484.11 (484.11) <4577FF14-E6A7-AAD8-E6E6-ECA9CFCC6989> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
          0x7fff8783f000 -     0x7fff878f4fe7  com.apple.ink.framework 1.3.3 (107) <FFC46EE0-3544-A459-2AB9-94778A75E3D4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
          0x7fff87909000 -     0x7fff8796bfe7  com.apple.datadetectorscore 2.0 (80.7) <5B6AABCA-C75A-D28F-6A2F-59648F0ABFC8> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
          0x7fff8796c000 -     0x7fff879eefff  com.apple.QuickLookUIFramework 2.2 (327.4) <C35D9F62-73D0-262C-B0CE-BFF64E230588> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
          0x7fff879ef000 -     0x7fff87a03ff7  com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <63C87CF7-56B3-4038-8136-8C26E96AD42F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
          0x7fff87a04000 -     0x7fff87a07ff7  com.apple.securityhi 4.0 (36638) <38935851-09E4-DDAB-DB1D-30ADC39F7ED0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
          0x7fff87c75000 -     0x7fff87cc1fff  libauto.dylib ??? (???) <8145CA34-EA03-11D2-5C60-02C1E5750593> /usr/lib/libauto.dylib
          0x7fff87ce5000 -     0x7fff87d75fff  com.apple.SearchKit 1.3.0 (1.3.0) <3403E658-A54E-A79A-12EB-E090E8743984> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
          0x7fff87d76000 -     0x7fff87daefef  libcups.2.dylib 2.8.0 (compatibility 2.0.0) <31A78904-A500-0DA9-0609-F1EB81383326> /usr/lib/libcups.2.dylib
          0x7fff87daf000 -     0x7fff88018ff7  com.apple.QuartzComposer 4.1 (156.16) <0BAE3C90-CF60-C0C7-C29E-BF9922074095> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
          0x7fff88019000 -     0x7fff880cffff  libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <4B6351E5-A293-D814-36E1-E75E35C25D86> /usr/lib/libobjc.A.dylib
          0x7fff880fe000 -     0x7fff8817dfef  com.apple.audio.CoreAudio 3.2.2 (3.2.2) <243E456E-7A74-BE76-FF18-E589BDCAA785> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
          0x7fff8817e000 -     0x7fff88233fe7  com.apple.ColorSync 4.6.3 (4.6.3) <AA93AD96-6974-9104-BF55-AF7A813C8A1B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
          0x7fff88583000 -     0x7fff885b4fef  libTrueTypeScaler.dylib ??? (???) <0A30CA68-46AF-3E74-AE9E-693DB5A680CC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
          0x7fff885bc000 -     0x7fff8860dfe7  com.apple.HIServices 1.8.0 (???) <1ABA7802-C1E4-06A0-9035-2792CC915BF6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
          0x7fff88644000 -     0x7fff88669fe7  com.apple.CoreVideo 1.6.1 (45.4) <B1516554-88BC-CF1E-5409-BFF27A73D1AF> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
          0x7fff8866a000 -     0x7fff88690fe7  libJPEG.dylib ??? (???) <4060F3E2-BAD3-244F-D777-51BA16569DA4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
          0x7fff88691000 -     0x7fff88731fff  com.apple.LaunchServices 362.1 (362.1) <2740103A-6C71-D99F-8C6F-FA264546AD8F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
          0x7fff88732000 -     0x7fff88b76fef  libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <E14EC4C6-B055-A4AC-B971-42AB644E4A7C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
          0x7fff88b77000 -     0x7fff88b98fff  libresolv.9.dylib 41.0.0 (compatibility 1.0.0) <6993F348-428F-C97E-7A84-7BD2EDC46A62> /usr/lib/libresolv.9.dylib
          0x7fff88d23000 -     0x7fff88d2eff7  com.apple.HelpData 2.0.4 (34) <9BA1003B-65F7-D1B2-E924-61309EFD784B> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
          0x7fff88d2f000 -     0x7fff88d2fff7  com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <DA9BFF01-40DF-EBD5-ABB7-787DAF2D77CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
          0x7fff88d30000 -     0x7fff88d58fff  com.apple.DictionaryServices 1.1.1 (1.1.1) <CC593ECB-8FFA-BF81-0B0D-F8C606B31318> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
          0x7fff88d59000 -     0x7fff88d66fe7  libCSync.A.dylib 543.50.0 (compatibility 64.0.0) <7B891D4C-1F19-4DB0-FD12-7A7D5E8F47AE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
          0x7fff88ded000 -     0x7fff88deefff  liblangid.dylib ??? (???) <EA4D1607-2BD5-2EE2-2A3B-632EEE5A444D> /usr/lib/liblangid.dylib
          0x7fff88def000 -     0x7fff88e0fff7  com.apple.DirectoryService.Framework 3.6 (621.3) <EDCAF7ED-36E1-121F-D294-5CEBC1C34C5A> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
          0x7fff88edc000 -     0x7fff88f20fe7  com.apple.ImageCaptureCore 1.0.2 (1.0.2) <075198A5-4C6B-D945-D3EF-D13960C9F738> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
          0x7fff88f21000 -     0x7fff88fecfe7  ColorSyncDeprecated.dylib 4.6.0 (compatibility 1.0.0) <3C223A94-EF14-28C5-844B-C25DFC87FB42> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/V ersions/A/Resources/ColorSyncDeprecated.dylib
          0x7fff88fed000 -     0x7fff89010fff  com.apple.opencl 12.1 (12.1) <403E8F37-4348-B9BC-08E6-7693A995B7EC> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
          0x7fff89011000 -     0x7fff89027fff  com.apple.ImageCapture 6.0 (6.0) <BF702F65-8E30-E318-1B58-AE6C0D5E5715> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
          0x7fff89028000 -     0x7fff89090fff  com.apple.MeshKitRuntime 1.1 (49.2) <1F4C9AB5-9D3F-F91D-DB91-B78610562ECC> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitRuntime. framework/Versions/A/MeshKitRuntime
          0x7fffffe00000 -     0x7fffffe01fff  libSystem.B.dylib ??? (???) <95E02DD0-ADEA-745B-E7FA-ABA064E4658C> /usr/lib/libSystem.B.dylib
      (/edit)
      Does anybody know what I can do?
      William (aka Bob Fijiwinkle)
