Show 3 replies
2. Re: Script to search layer names
Michael L Hale Jul 15, 2010 8:18 PM (in response to jmug45)This requires CS4 or better. It searchs using a RegExp and Action Manager so it should be very fast. It is set up now to deal with more than one matching layer.
var re = /rA/;// a reg exp var matches = collectNamesAM(re);// get array of matching layer indexes for( var l = 0; l < matches.length; l++ ){ makeActiveByIndex( l, false ); // do something with layer alert(app.activeDocument.activeLayer.name); }// next match if any function collectNamesAM(re){ var allLayers = new Array(); var startLoop = Number( !hasBackground() ); var endLoop = getNumberOfLayer(); for( var l = startLoop;l < endLoop; l++){ while( !isValidActiveLayer( l ) ) { l++; } if( getLayerNameByIndex( l ).match(re) != null){ allLayers.push( l ); } } return allLayers; }; /*////////////////////////////////////////////////////////////////////////////// // Function: getActiveLayerIndex // Description: Gets gets the Action Manager API index // of activeLayer corrected for Background Layer // Usage: var idx = getActiveLayerIndex(); // Input: None // Return: Number - correct AM itemIndex // Dependices: hasBackground //////////////////////////////////////////////////////////////////////////////*/ function getActiveLayerIndex() { var ref = new ActionReference(); ref.putProperty( 1349677170 , 1232366921 ); ref.putEnumerated( 1283027488, 1332896878, 1416783732 ); var res = executeActionGet(ref).getInteger( 1232366921 ) - Number( hasBackground() ); res == 4 ? res++:res// why the skip in this doc? return res; } /*////////////////////////////////////////////////////////////////////////////// // Function: isValidActiveLayer( ) // Description: Checks LayerSection for 'real' layers // Usage: if( isValidActiveLayer() ) // Input: None // Return: Boolean - True if not the end of a Set // Notes: Needed only if the layer was made active // using Action Manager API //////////////////////////////////////////////////////////////////////////////*/ function isValidActiveLayer( idx ) { var propName = stringIDToTypeID( 'layerSection' );// can't replace var ref = new ActionReference(); ref.putProperty( 1349677170 , propName);// TypeID for "Prpr" // 'Lyr ", idx ref.putIndex( 1283027488, idx ); var desc = executeActionGet( ref ); var type = desc.getEnumerationValue( propName ); var res = typeIDToStringID( type ); return res == 'layerSectionEnd' ? false:true; }; /*////////////////////////////////////////////////////////////////////////////// // Function: hasBackground // Description: Test for background layer using AM API // Usage: if( hasBackground() ); // Input: None // Return: Boolean - true if doc has background layer // Notes: Requires the document to be active // DOM: App.Document.backgroundLayer //////////////////////////////////////////////////////////////////////////////*/ function hasBackground(){ var res = undefined; try{ var ref = new ActionReference(); ref.putProperty( 1349677170 , 1315774496); ref.putIndex( 1283027488, 0 ); executeActionGet(ref).getString(1315774496 );; res = true; }catch(e){ res = false} return res; }; function makeActiveByIndex( idx, forceVisible ){ try{ var desc = new ActionDescriptor(); var ref = new ActionReference(); ref.putIndex(charIDToTypeID( "Lyr " ), idx) desc.putReference( charIDToTypeID( "null" ), ref ); desc.putBoolean( charIDToTypeID( "MkVs" ), forceVisible ); executeAction( charIDToTypeID( "slct" ), desc, DialogModes.NO ); }catch(e){ return -1;} }; function getNumberOfLayer(){ var ref = new ActionReference(); ref.putEnumerated( charIDToTypeID("Dcmn"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") ); var desc = executeActionGet(ref); var numberOfLayer = desc.getInteger(charIDToTypeID("NmbL")); return numberOfLayer; }; function getLayerNameByIndex( idx ) { var ref = new ActionReference(); ref.putProperty( charIDToTypeID("Prpr") , charIDToTypeID( "Nm " )); ref.putIndex( charIDToTypeID( "Lyr " ), idx ); return executeActionGet(ref).getString(charIDToTypeID( "Nm " ));; }; -
3. Re: Re: Script to search layer names
barra Aug 9, 2014 9:25 AM (in response to Michael L Hale)@Michael: Thank you for the awesome code!
Annotation: line 4 must be the following:
var re = /rA/;// a reg exp var matches = collectNamesAM(re);// get array of matching layer indexes for( var l = 0; l < matches.length; l++ ){ makeActiveByIndex( matches[l], false ); // do something with layer alert(app.activeDocument.activeLayer.name); }// next match if any
