4 Replies Latest reply on Jul 16, 2010 5:40 AM by victor_shamo
    Advanced DataGrid Group Data Representation - Customize way
    victor_shamo Level 1
      ArrayCollection:
      Group                   SubGroup           Items    Val1       Val2        Val3
      Goup1                 Sub Group 1       Item 1   123         123         123
      Group1                 Sub Group 1       Item 2   123         123         123
      Group1                 Sub Group 2       Item 3   123         123         123
      Group1                 Sub Group 2       Item 4   123         123         123
      Group1                 Sub Group 3       Item 5   123         123         123
      Group1                 Sub Group 3       Item 6   123         123         123
      I want to group the data and display the above data in following format (mention below). Please help how to achieve and is it possible using Adobe Flex?
      I have tried with groupCollection and Groupfield but unable to get the desired format. Require your guidance. Your help will be appreciated!!!
      Desired Format
      Group
      Sub Group
      Items
      Value 1
      Value 2
      Value 3
      Sub Group 1
      Item 1
      Xxx
      Xxx
      xxx
      Item 2
      Xxx
      Xxx
      Xxx
      Total
      XXX
      XXX
      XXX
      Group 1
      Item 3
      Xxx
      Xxx
      Xxx
      Sub Group 2
      Item 4
      Xxx
      Xxx
      Xxx
      Total
      XXX
      XXX
      XXX
      Sub Group 3
      Item 5
      Xxx
      Xxx
      Xxx
      Item 6
      Xxx
      Xxx
      Xxx
      Total
      XXX
      XXX
      XXX
      Grand Total
      XXXXX
      XXXXX
      XXXXX
      Victor
        • 1. Re: Advanced DataGrid Group Data Representation - Customize way
          leybniz Level 4
          As a possible solution: Transform ArrayCollection to mx:HierarchicalData
          and use AdvancedDataGrid.treeColumn.
          As to your data structure, the Tree model has to be more preferable to store and operate with, than a plain collection you are using now.
          • 2. Re: Advanced DataGrid Group Data Representation - Customize way
            HI,
            Thanks for your reply,
            How would i include Sub Group Total and Grand Total if i use Hierarchical Data ?
            Victor
            • 3. Re: Advanced DataGrid Group Data Representation - Customize way
              leybniz Level 4
              Totals could be sparate entities, pre-calculated during aggregative conversion from ArrayCollection you have to Tree structure. This way You'll have Read-only model. For all times Custom things requires custom solutions
              • 4. Re: Advanced DataGrid Group Data Representation - Customize way
                Thanks for your reply...
                Plz Guide me how to get the total under sub group column and colour them. Please refer image given...
                I am new bie to advance datagrid. Please guide how to get...
                private var dpHierarchy:ArrayCollection = new ArrayCollection([
                                  {Group:"Group", children: [
                                     {SubGroup:"SubGroup", children: [
                                         {BSGroup:"SUbSubGroup", children:[
                                         {Item:"Item 1", Val1:30566, Val2:40000},
                                        {Item:"Total SubGroup", Val1:99999, Val2:99999}]}
                a. Can we get rid of these yellow blank areas and make the data compact?
                b. Can i bring Total SubGroup Text Under SubGroup column.
                c. SubGroup column and Sub Group Total can be of same colour. Is this is possible ?
                Please guide your help would really help!!!!
                Victor
