I have a multiple page form (4 forms built into one) that once I try to extract a single part I loose all of the from filling capabilities. Is there a way to keep that when you extract a page. Also along the same line- is there a way to extract a pre set single page (usable) with the print button?
Solved! Go to Solution.
Total Likes
Extracting pages from a form and keeping them interactive (usable) is not doable because of cross page dependancies and reliance on root subform containers.
I assume you are doing this after the form is filled in. If the form is an XFA form then you coudl extract the data, manipulate the base form to pull out a blank page, then remerge the data back onto the form (single page). This would involve lots of code (not javascript in the PDF) - XML manipulation. If you are not code savvy then I woudl not even attempt it.
Paul
Total Likes
Paul
Total Likes
Thanks Paul,
I'm not code savvy at all so I've left it as is. I do have another question though, can I lock a page with a password within the form?
Robin
Robin Kramer
Technical Representative
Dartmouth Printing Co.
603.643.2220 ext 291
603.643.5479 fax
rkramer@dpc-nh.com
Total Likes
There is a password mechanism to open th eentire form but it does not filter down to a page by page level. If you describe your use case a little better I might be able to come up with a different solution.
Paul
Total Likes
Within the form there is a billing sheet that we would like to at least password protect since the form has to travel as one piece to different vendors.
Robin
Robin Kramer
603.643.5479 fax
rkramer@dpc-nh.com
Total Likes
Protect how .....do you not want then to see it or make changes to it .....what do you mean
by protect?
Paul
Total Likes
We don’t want them to see our pricing within the form or the entire page if possible.
Robin Kramer
603.643.5479 fax
rkramer@dpc-nh.com
Total Likes
Then I woudl change the presence of th epage to hidden exclude from layout by default and then add a button to the form where you can use an app.response which will allow you to enter a password and if they enter the right password then you can change the presence to visible. Not the most secure thing in the world but better than nothing.
Paul
You are right that sounds better than nothing, is there info about this in the 'Help' or can you direct me how to do this?
Robin Kramer
603.643.5479 fax
rkramer@dpc-nh.com
Total Likes
It is pretty straight forward ......I am leaving on vacation so I cannot help you until next week. Maybe someone else from th eforum can step in and help out.
Paul
Total Likes
Take a look at this. This should be a good start.
Jasmin
Was there something supposed to be attached?
Robin Kramer
603.643.5479 fax
rkramer@dpc-nh.com
Total Likes
Don't you see the ProtectWithPassword.pdf (77.2 K) document attached to the previous post?
Jasmin
Total Likes
No I didn't, but thank you! Robin
Robin Kramer
603.643.5479 fax
rkramer@dpc-nh.com
Total Likes
I saw the PDF you posted, but it had "Page1" and two buttons on it. Not knowing the password (password and test didn't work) I can't find any use for it revelant to this discussion.
So what's the password? <g>
Total Likes
The password is "password".
Just open it with LiveCycle Form Designer and you'll see the code.
Jasmin
Total Likes
Hi Jasmin,
I copied and placed the two buttons into my document and re-set the page in 'Hide' to page 4 in the script.
I checked the PDF and page 4 was still there?
Help! Thanks,
Robin
Robin Kramer
603.643.5479 fax
rkramer@dpc-nh.com
Total Likes
Make sure to save your form as a dynamic pdf.
Jasmin
Total Likes
I did, still not hiding the page...
Robin Kramer
603.643.5479 fax
rkramer@dpc-nh.com
Total Likes
Are you using PDF Preview or stand alone Acrobat to test?
Try to use stand alone Acrobat. The PDF Preview could still be configured to render a static pdf even if you save as dynamic pdf.
If that still doesn't work, attach your pdf and I'll have a look.
Jasmin
Total Likes
Hi Jasmin,
I still can't get the file to hide page 4 (Sheridan Dynamic Edition Billing New Issue Work Order) in this document. Please let me know what I did incorrectly.
Robin
Robin Kramer
603.643.5479 fax
rkramer@dpc-nh.com
Total Likes
