Show 2 replies
1. Re: Help with setting classpath for Papervision in Flash CS5
funkysoul Jul 18, 2010 5:16 AM (in response to vco_se11)I assume you want to import the .as classes and not the .swc correct?
Use the sourcepath ( the upper most field) to import your classes to your project, you can recognize it as well because it's the only field without the capability of importing .swc files.
2. Re: Help with setting classpath for Papervision in Flash CS5
vco_se11 Jul 18, 2010 7:56 AM (in response to funkysoul)Thank you! I would never have guessed that the one on top was the place to put it -- because the middle one says it's where to put the path to class files!
But that works and I'm so so so happy.
I'm very grateful for your help.
All the best
