Hello staff,
is there already a bug filed for this?
The problem is that in certain situation the code hint popup does not appear at the first CTRL-Space key press. A black bar flickers across the screen, and then when you hit CTRL-Space a second time it appears.
I noticed this is very reproducable after code hinting just completed a function name and you want to input a local parameter via another code hint.
Hope this makes sense
Jason, Anirudh?
Could you help us out by recording a screen capture and filing a bug? I haven't seen this problem.
Jason San Jose
Software Engineer, Flash Builder
Sure. What tool would I use best to record that capture?
Try Jing http://www.jingproject.com/.
Jason San Jose
Hi Jason
I did record a screencast, however it doesn't show the flicker that occurs on the screen and is without audio. Hopefully it still makes sense.
Code completion fails after I used the completion to fill in the function name. Hitting CTRL-Space afterwards doesn't show the code hint, but just a black bar flickering across the screen (not visible in recording). A second time hitting it does show it then. This is a bit tricky to see in the screencast.
Err.. How to I upload a SWF file?!
Will file a bug.
I think there should be some kind of reward for putting so much time into this product.
So far I have just filed a bunch of bugs, all of those got deferred, no update in sight and paid $400 for it.
Thanks, Tom. We'll follow up in the bug.
Jason San Jose
Can you elaborate a bit more, why do think it is a bug?
I watched screencast, tried it personally, the behaviour of CTRL+Space code hinting feature works as I would expected.
I think its a bug because I have to press CTRL-Space twice to get the code hinting popup.
This is very consistent, and 100% reproducable. It still happens in 4.0.1 and in every project I have. As you can see in the screencast it happens in a newly created project, too.
Now, I see.
I misunderstood 2 natures of popups bubblles - code hinting popup (code assist feature) and function parameter hinting tooltip.
IMHO, what you've encountered undeniably is a bug, will vote and will bring on more public attention.
Yes, I am talking about the "code hinting popup". Thanks for advancing this annoying bug..
