I have followed the manuals'
code for updating a record in the database via a webpage, and the update page produces an error. I have received two or three errors, but the update is never successful. Below, I have the templates - with their code. Please help.
vwp_swdc_lsn_mstr_lst.cfm
This is the master list of lesson plans - it works great. - (a candiddate for CFCACHE)
<CFQUERY NAME="ViewLessonsMstr" DATASOURCE="vwp">
SELECT swdc_lsn.*, IIf([swdc_lsn_del_x]=Yes,'Yes','') AS swdc_lsn_del_z, swdc_crs_rf.*, swdc_tpc_rf.*, swdc_lvl_rf.swdc_lvl_clr
FROM ((swdc_lsn LEFT JOIN swdc_tpc_rf ON swdc_lsn.swdc_lsn_tpc_ = swdc_tpc_rf.swdc_tpc_rfID) LEFT JOIN swdc_crs_rf ON swdc_tpc_rf.swdc_tpc_crs_ = swdc_crs_rf.swdc_crs_rfID) LEFT JOIN swdc_lvl_rf ON swdc_crs_rf.swdc_crs_lvl_ = swdc_lvl_rf.swdc_lvl_rfID
ORDER BY swdc_lsn.swdc_lsn;
</CFQUERY>
<CFQUERY NAME="_css" DATASOURCE="vwp">
SELECT site_txt_misc.*
FROM site_txt_misc
WHERE ((vwps_incl_ttl)='CSS');
</CFQUERY>
// © 2010
// The Vivace Web Project
// All Rights Reserved
<HTML>
<HEAD>
<TITLE>Lesson Master List</TITLE>
<CFOUTPUT QUERY="_css">#site_txt_misc#</CFOUTPUT>
</HEAD>
<BODY>
<H1 CLASS="H1_c17">School of Web Development</H1>
<H2 CLASS="H2_c16">Curriculum</H2>
<H3 CLASS="H3_c15">Lesson Master List</H3>
<BR>
<TABLE
BORDER="0"
CELLPADDING="5"
CELLSPACING="0"
BORDERCOLOR="white"
BGCOLOR="#FFFFFF">
<!-- Headings -->
<TR CLASS="td_hd">
<TD>
</TD>
<TD>
Lesson Name
</TD>
<TD>
Course Name
</TD>
<TD ALIGN="center">
Level
</TD>
<TD WIDTH=15>
Minutes
</TD>
<TD WIDTH=15>
Del
</TD>
</TR>
<CFOUTPUT QUERY="ViewLessonsMstr">
<!-- data -->
<TR BGCOLOR=#swdc_lvl_clr#>
<TD>
<A HREF="vwp_swdc_lsn_det_e.cfm?call_number=#swdc_lsnID#">
<IMG
SRC="C:/acb/img/util/bullets/a_note.gif"
WIDTH="24"
HEIGHT="24"
BORDER="0">
</A>
</TD>
<TD>
<A HREF="vwp_swdc_lsn_det_e.cfm?call_number=#swdc_lsnID#">#swdc_lsn#</A>
</TD>
<TD>
#swdc_crs_rf#
</TD>
<TD ALIGN="center">
#swdc_crs_lvl_#
</TD>
<TD WIDTH=15>
#swdc_lsn_dur_#
</TD>
<TD WIDTH=15>
#swdc_lsn_del_z#
</TD>
</TR>
</CFOUTPUT>
</TABLE>
</BODY>
</HTML>
- Having trouble with a select box (tried CFSELECT with CFFORM and had trouble, but I'd prefer to use CFSELECT)
- The selectbox already has a choice in the database, and the record being edited is not reflecting the current value for the field: swdc_lsn_tpc_ during editing
<CFQUERY NAME="q_swdc_lsn_det_e" DATASOURCE="vwp">
SELECT swdc_lsn.*
FROM swdc_lsn
WHERE #call_number#=swdc_lsnID;
</CFQUERY>
FROM site_txt_misc
</CFQUERY>
<!--- query used for field dropdown in table.field: swdc_lsn.swdc_lsn_tpc_ --->
<CFQUERY NAME="q_swdc_lsn_tpc" DATASOURCE="vwp">
SELECT swdc_tpc_rfID, swdc_tpc_r
FROM swdc_tpc_rf
ORDER BY swdc_tpc_r;
</CFQUERY>
// © 2010
<HTML>
<HEAD>
<TITLE>Edit This Lesson</TITLE>
</HEAD>
<BODY>
<H3 CLASS="H3_c15">Lesson Detail Edit Page</H3>
<DIV ALIGN="left">
<!-- f_vwp_swdc_lsn_det_e -->
<FORM
ACTION="vwp_swdc_lsn_det_e_ud.cfm"
NAME="form">
<CFOUTPUT QUERY="q_swdc_lsn_det_e">
<INPUT
TYPE="hidden"
VALUE="#swdc_lsnID#"
NAME="swdc_lsnID">
<P>
Lesson Pre Title (The, A, or An):
<INPUT
TYPE="textbox"
VALUE="#swdc_lsn_pre_#"
NAME="swdc_lsn_pre_"
MAXLENGTH="1"
SIZE="3">
<P>
Lesson Title or Name:
<INPUT
TYPE="textbox"
VALUE="#swdc_lsn#"
NAME="swdc_lsn"
MAXLENGTH="100"
SIZE="100"> <!-- database character max for this field -->
<P>
Lesson Topic:
</CFOUTPUT>
<SELECT
<CFOUTPUT QUERY="q_swdc_lsn_tpc">
NAME="swdc_lsn_tpc_">
<OPTION VALUE="swdc_tpc_rfID">#swdc_tpc_r#</OPTION>
</CFOUTPUT>
</SELECT>
<P>
Lesson Sequence Number:
<INPUT
TYPE="textbox"
VALUE="#swdc_lsn_n_#"
NAME="swdc_lsn_n_"
MAXLENGTH="3"
SIZE="5">
<P>
Lesson Expected Duration:
<INPUT
TYPE="textbox"
VALUE="#swdc_lsn_dur_#"
NAME="swdc_lsn_dur_"
MAXLENGTH="3"
SIZE="5">
<P>
Select here to delete this lesson:
<INPUT
TYPE="checkbox"
VALUE="#swdc_lsn_del_x#"
NAME="swdc_lsn_del_x">
<P>
<DIV ALIGN="center">
<INPUT
TYPE="Submit"
VALUE="submit"
NAME="submit">
</DIV>
</CFOUTPUT>
</FORM>
</DIV>
</BODY>
</HTML>
- The next problem is that certain fields are not recognized, but I tripled checked field spellings
- unsuccessful update (I tried CFUPDATE also)
<!--- <CFUPDATE DATASOURCE="vwp" TABLENAME="swdc_lsn"> --->
<CFQUERY DATASOURCE="vwp" NAME="q_swdc_lsn_det_e_ud">
UPDATE swdc_lsn
SET
swdc_lsn_pre_='#form.swdc_lsn_pre_#',
swdc_lsn='#form.swdc_lsn#',
swdc_lsn_n_='#form.swdc_lsn_n_#',
swdc_lsn_tpc_='#form.swdc_lsn_tpc_#',
swdc_lsn_dur_='#form.swdc_lsn_dur_#',
swdc_lsn_del_x='#form.swdc_lsn_del_x#'
WHERE call_number=#form.swdc_lsnID#;
</CFQUERY>
<HTML>
<HEAD>
<TITLE>Update Verification</TITLE>
<!--- <CFOUTPUT QUERY="incl_css_bd">#incl_code#</CFOUTPUT> --->
</HEAD>
<BODY>
<TABLE
BORDER="0"
WIDTH="100%"
HEIGHT="100%"
CELLPADDING="0"
CELLSPACING="0">
<TR>
<TD HEIGHT="100%" ALIGN="center" VALIGN="middle">
Your edit has been saved.
</TD>
</TR>
</TABLE>
</DIV>
</BODY>
</HTML>
(My server I rent space from doesn't yet use Access 2007)
The database file: vwp.mdb
The table: swdc_lsn (the table of lesson plans)
Fields:
swdc_lsnID (Autonumber)
swdc_lsn_pre_ (choice of "The", "An", "A" Byte)
swdc_lsn (Title of lesson plan: Text-100)
swdc_lsn_n_ (lesson plan sequence number: Byte)
swdc_lsn_tpc_ (Topic of this lesson plan - dropdown fed by table: swdc_tpc_rf: LongInteger)
swdc_lsn_del_x (deletion of this lesson plan is emminent: checkbox)
The table: swdc_tpc_rf (the table of topics)
Fields:
swdc_tpc_rfID (Autonumber)
swdc_tpc_r (Title of Topic: Text-100) {I originally spelled this field as swdc_tpc_rf, but changed it to experiment}
swdc_tpc_crs_ (Course - dropdown fed by table: swdc_crs_rf: LongInteger)
swdc_tpc_del_x (deletion of this lesson plan is emminent: checkbox)
In summary, I get a little confused with when to use the number signs and when not to, becuase I have noticed that sometimes, the CF code doesn't use them! Also, the VALUE attribute in the INPUT objects - I beleive - is the database field name, but I noticed that the update page refers to the NAME attribute, ie. form.objectname instead of the value (which is the database field name).
Message was edited by: EwokStud
Please show the error message and only the part of the code that is relevant for your problem. We are all busy people and you are more likely to get help if we don't have to search through your code to find the relevant part. See http://forums.adobe.com/thread/607238?tstart=0
This is a new abbreviated version of my first post (which was originally titled poorly as "CFUPDATE versus SQL UPDATE"). The 3 problems remain the same.
- edit page
SELECT swdc_lsn.*
FROM swdc_lsn
</CFQUERY>
FROM swdc_tpc_rf
</CFQUERY>
---snippet from page---
<CFFORM
NAME="f_vwp_swdc_lsn_det_e">
---form snippet---
<INPUT
TYPE="checkbox"
NAME="obj_swdc_lsn_del_x">
Lesson Topic:
<CFSELECT
SIZE="1"
REQUIRED="No"
VALUE="swdc_lsn_tpc_"
MULTIPLE="no"
DISPLAY="swdc_tpc_r">
</CFSELECT>
---end form snippet---
</CFFORM>
---end page snippet---
- update page
UPDATE swdc_lsn
SET
swdc_lsn_pre_='#form.obj_swdc_lsn_pre_#',
swdc_lsn='#form.obj_swdc_lsn#',
swdc_lsn_n_='#form.obj_swdc_lsn_n_#',
swdc_lsn_tpc_='#form.obj_swdc_lsn_tpc_#',
swdc_lsn_dur_='#form.obj_swdc_lsn_dur_#',
swdc_lsn_del_x='#form.obj_swdc_lsn_del_x#'
WHERE call_number=#form.obj_swdc_lsnID#;
</CFQUERY>
Using vwp.mdb with two tables: swdc_lsn, and swdc_tpc_rf
swdc_lsn: (fields in the update SQL above)
swdc_tpc_rf: (fields: swdc_rfID (Autonumber), swdc_tpc_r (text), and non-pertinent fields)
Given: tpc=topic, lsn=lesson
Problem 1: The edit page for the lesson displays well (no error), but the dropdown
topic field in the lesson table (swdc_lsn_tpc_), which is a Long Integer field, is not displaying the current choice. In other words, the the lesson on apples should display the topic called fruits (using its ID); it is not. Instead, the edit page displays all the fields correctly, except in the CFSELECT dropdown list (nbr field for topic). I know that in the database, the topic field is correct (fruits). However, the first choice in CFSELECT is cookbooks (Given: cookbooks, fruit, spices, and vegetables.)
Problem 2: The submit does take me to the correct template using the correct linkage of id's, but the error is:
Error Occurred While Processing Request
Error Diagnostic Information
Error resolving parameter FORM.OBJ_SWDC_LSN_DEL_X
The specified form field cannot be found. This problem is very likely due to the fact that you have misspelled the form field name.
The error occurred while evaluating the expression:
The error occurred while processing an element with a general identifier of (#form.obj_swdc_lsn_del_x#), occupying document position (11:18) to (11:42).
Remote Address: 127.0.0.1
HTTP Referer: http://127.0.0.1/vwp/School/Curric/vwp_swdc_lsn_det_e.cfm?call_number=32
Template: C:\vwp\School\Curric\vwp_swdc_lsn_det_e_ud.cfm
Problem 3: is CFINSERT and CFUPDATE still used? my environment is CF 4.5
end post======================================
EwokStud wrote on 7/17/2010 7:37 PM:
Use # around the selected value in the code.
This problem occurs because you use a checkbox in the form. A checkbox
only exists in the action page if it is selected. Use a radio button in
your form or isDefined() in your action page to make sure the variable
exists. If you need more info, read the chapter on forms in the HTML
4.01 standard at w3c.org.
I believe cfinsert and cfupdate run the risk of SQL injection attacks in
CF 4.5. Not many people use them.
Checkbox was eliminated (commented out) as per your recommendation. The topic for Spices and Seasonings Lesson is still coming as Fruits....in the topic dropdown (CFSELECT) on the detail page. The checkbox was also eliminated in the list of fields to update (on the update page vwp_swdc_lsn_det_e_ud.cfm).
Food Lesson Listing:
http://65.61.35.197/family/doug/bd/hby/cook/vwp_swdc_lsn_mstr_lst.cfm
Edit a particular line item (record/lesson) by clicking on the pencil graphic. Let's say The Balance of Spices Lesson Lesson (call_number=4)
http://65.61.35.197/family/doug/bd/hby/cook/vwp_swdc_lsn_det_e.cfm?call_number=4
I then successfully arrive at the editing page for the record "The Balance of Spices", change the topic from Fruits to Spices and Seasonings (with the hidden ID field in the CFSELECT). Click submit....
Error:
Error Executing Database Query.
[Macromedia][SequeLink JDBC Driver][ODBC Socket][Microsoft][ODBC Microsoft Access Driver] Too few parameters. Expected 1.
The error occurred in E:\benoitsystems.com\wwwroot\family\doug\bd\hby\cook\vwp_swdc_lsn_det_e_ud.cfm: line 11
9 : swdc_lsn_tpc_='#form.obj_swdc_lsn_tpc_#',
10 : swdc_lsn_dur_='#form.obj_swdc_lsn_dur_#'
11 : WHERE call_number=#form.obj_swdc_lsnID#;
12 : </CFQUERY>
13 :
SQL UPDATE vwp_swdc_lsn SET swdc_lsn_pre_='1', swdc_lsn='The Balance of Spices', swdc_lsn_n_='3', swdc_lsn_tpc_='1', swdc_lsn_dur_='45' WHERE call_number=4;
DATASOURCE 9130.vwp
VENDORERRORCODE -3010
SQLSTATE 07002
Please try the following:
Check the ColdFusion documentation to verify that you are using the correct syntax.
Search the Knowledge Base to find a solution to your problem.
Browser Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; .NET CLR 2.0.50727; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729)
Remote Address 71.233.234.226
Referrer http://65.61.35.197/family/doug/bd/hby/cook/vwp_swdc_lsn_det_e.cfm?call_number=4
Date/Time 17-Jul-10 05:22 PM
Stack Trace (click to expand)
Though,...I changed some of teh database field names (removing the _rf extension) I also changed these in the CF code,...that's not a problem.
Doug
I'll just throw in that this seems a discussion better suited to one of the CF forums (rather than CFBuilder). I suppose this will happen from time to time as people new to CF get introduced to CFBuilder as "the editor" and therefore they assume this forum is a place to ask getting started questions.
EwokStud, you may want to check out:
http://forums.adobe.com/community/coldfusion/coldfusion_getting_started
http://forums.adobe.com/community/coldfusion/coldfusion_general
Others at http://forums.adobe.com/community/coldfusion.
/charlie
EwokStud, as you've changed this discussion to a new thread title, I'll repeat my comment I made just at the end of your last one. (I can't tell if you read it before you chose to create this new topic).
Your question is not about CFBuilder (the IDE). As such, you really should take it to the correct CF forum. I'd recommend either:
Since people reading this may not see my note in that other topic thread (http://forums.adobe.com/message/2981760#2983674), I also noted that "I suppose this will happen from time to time as people new to CF get introduced to CFBuilder as "the editor" and therefore they assume this forum is a place to ask getting started questions."
It's not to discourage such questions, but rather simply to direct people to the proper forums for different topics. Hope that's helpful.
/charlie
