3 Replies Latest reply on Jul 20, 2010 11:00 AM by Chris Brind
    No version of AIR installs on Mac OS/X 10.6 after upgrading to 2.0.2
    Chris Brind Level 1
      I'd been using Air 1.5 happily for a long time running apps like Balsamiq with no problem.
      I decided to build an app myself using FB4 4.0.1.  The app ran fine from within FB4 but when I tested the export .air file before sending it to people it complained about not having the right version of AIR.
      So I downloaded 2.0.2 from Adobe's website and installed that ... except that it didn't work properly.  It prompted me for my administrator password before installing and then after it finished, saying it had successfully installed, I clicked Finish and it showed an error message saying "An internal error occurred ... The administrator may not allow you to install this" - or something similar.
      However, it looked as though it had installed OK as there was a framework installed under /Library/Frameworks/Adobe AIR.framework.
      So tried installing the .air file I'd created and this seemed to work, except that it then prompted me to enter my password and gave me the error "This application is already installed".
      In the /Applications folder I can see my app.  If I double click it, it prompts me to agree to the TOS for Air and then shows a dialog which says "Installing..." and a progress bar, but just hangs indefinitely.
      Next I uninstalled AIR - both by running the uninstaller in /Applications/Utilities and by running the installer with -uninstall.  Both methods appeared to successfully remove AIR from my system.
      Then I tried the above several times trying various combinations of install / uninstall and restarting my system but to no avail.
      I decided to re-install Adobe AIR 1.5 ... and now I get the same problem with that as well and none of my AIR apps will run at all.
      Here's the output from my console after uninstalling, installing and trying to run an app again today.
      Thanks in advance.
      Cheers,
      Chris
      19/07/2010 09:24:44 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7439] UI SWF load is complete
      19/07/2010 09:24:44 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7439] UI initialized
      19/07/2010 09:24:44 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7439] starting user confirmation
      19/07/2010 09:24:44 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7439] Version of this installer: 2.0.2.12610
      19/07/2010 09:24:44 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7439] Installed version: 2.0.2.12610
      19/07/2010 09:24:44 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7439] Installation type: patchSame
      19/07/2010 09:24:46 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7439] starting elevated install
      19/07/2010 09:24:49 authexec[7443] executing /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer
      19/07/2010 09:24:49 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7443] UI SWF load is complete
      19/07/2010 09:24:49 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7443] starting uninstall
      19/07/2010 09:24:49 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7439] subinstaller: starting uninstall
      19/07/2010 09:24:49 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7443] Beginning install
      19/07/2010 09:24:49 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7439] subinstaller: Beginning install
      19/07/2010 09:24:49 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7443] Copying /Library/Frameworks/Adobe AIR.framework to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0/temp
      19/07/2010 09:24:49 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7439] subinstaller: Copying /Library/Frameworks/Adobe AIR.framework to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0/temp
      19/07/2010 09:24:50 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7443] Deleting /Library/Frameworks/Adobe AIR.framework
      19/07/2010 09:24:50 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7439] subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework
      19/07/2010 09:24:50 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7443] Copying /Applications/Utilities/Adobe AIR Uninstaller.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1/temp
      19/07/2010 09:24:50 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7439] subinstaller: Copying /Applications/Utilities/Adobe AIR Uninstaller.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1/temp
      19/07/2010 09:24:50 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7443] Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
      19/07/2010 09:24:50 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7439] subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
      19/07/2010 09:24:50 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7443] Copying /Applications/Utilities/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp2/temp
      19/07/2010 09:24:50 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7439] subinstaller: Copying /Applications/Utilities/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp2/temp
      19/07/2010 09:24:50 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7443] Deleting /Applications/Utilities/Adobe AIR Application Installer.app
      19/07/2010 09:24:50 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7439] subinstaller: Deleting /Applications/Utilities/Adobe AIR Application Installer.app
      19/07/2010 09:24:50 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7443] Copying /Applications/Adobe/Flash Player/AddIns/airappinstaller to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp3/temp
      19/07/2010 09:24:50 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7439] subinstaller: Copying /Applications/Adobe/Flash Player/AddIns/airappinstaller to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp3/temp
      19/07/2010 09:24:50 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7443] Deleting /Applications/Adobe/Flash Player/AddIns/airappinstaller
      19/07/2010 09:24:50 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7439] subinstaller: Deleting /Applications/Adobe/Flash Player/AddIns/airappinstaller
      19/07/2010 09:24:50 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7443] Execution complete; beginning commit phase
      19/07/2010 09:24:50 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7439] subinstaller: Execution complete; beginning commit phase
      19/07/2010 09:24:50 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7443] Deleting /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0/temp
      19/07/2010 09:24:50 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7439] subinstaller: Deleting /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0/temp
      19/07/2010 09:24:50 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7443] Deleting /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1/temp
      19/07/2010 09:24:50 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7439] subinstaller: Deleting /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1/temp
      19/07/2010 09:24:51 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7443] Deleting /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp2/temp
      19/07/2010 09:24:51 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7439] subinstaller: Deleting /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp2/temp
      19/07/2010 09:24:51 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7443] Deleting /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp3/temp
      19/07/2010 09:24:51 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7439] subinstaller: Deleting /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp3/temp
      19/07/2010 09:24:51 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7443] Commit complete
      19/07/2010 09:24:51 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7439] subinstaller: Commit complete
      19/07/2010 09:24:51 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7443] install complete
      19/07/2010 09:24:51 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7439] subinstaller: install complete
      19/07/2010 09:24:51 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7443] begin quitting
      19/07/2010 09:24:51 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7439] subinstaller: begin quitting
      19/07/2010 09:24:51 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7439] Elevated install completed
      19/07/2010 09:24:51 /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[7439] begin quitting
      19/07/2010 09:30:40 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7490] Performing runtime install
      19/07/2010 09:30:40 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7490] UI SWF load is complete
      19/07/2010 09:30:40 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7490] UI initialized
      19/07/2010 09:30:40 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7490] starting user confirmation
      19/07/2010 09:30:40 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7490] Version of this installer: 2.0.2.12610
      19/07/2010 09:30:40 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7490] Installation type: new
      19/07/2010 09:30:43 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7490] starting elevated install
      19/07/2010 09:30:46 authexec[7495] executing /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer
      19/07/2010 09:30:46 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7495] performing an elevated runtime install
      19/07/2010 09:30:46 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7495] UI SWF load is complete
      19/07/2010 09:30:46 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7495] starting install
      19/07/2010 09:30:46 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7495] Scheduling runtime installation operations
      19/07/2010 09:30:46 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7490] subinstaller: starting install
      19/07/2010 09:30:46 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7490] subinstaller: Scheduling runtime installation operations
      19/07/2010 09:30:46 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7495] Beginning runtime installation
      19/07/2010 09:30:46 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7490] subinstaller: Beginning runtime installation
      19/07/2010 09:30:46 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7495] Beginning install
      19/07/2010 09:30:46 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7490] subinstaller: Beginning install
      19/07/2010 09:30:46 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7495] Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
      19/07/2010 09:30:46 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7490] subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
      19/07/2010 09:30:49 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7495] Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
      19/07/2010 09:30:49 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7490] subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
      19/07/2010 09:30:52 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7495] Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0/temp
      19/07/2010 09:30:52 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7490] subinstaller: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0/temp
      19/07/2010 09:30:52 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7495] Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
      19/07/2010 09:30:52 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7490] subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
      19/07/2010 09:30:52 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7495] Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
      19/07/2010 09:30:52 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7490] subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
      19/07/2010 09:30:54 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7495] Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1/temp
      19/07/2010 09:30:54 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7490] subinstaller: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1/temp
      19/07/2010 09:30:55 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7495] Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
      19/07/2010 09:30:55 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7490] subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
      19/07/2010 09:30:55 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7495] Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
      19/07/2010 09:30:55 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7490] subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
      19/07/2010 09:30:55 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7495] Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
      19/07/2010 09:30:55 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7490] subinstaller: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
      19/07/2010 09:30:55 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7495] Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp2/temp
      19/07/2010 09:30:55 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7490] subinstaller: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp2/temp
      19/07/2010 09:30:55 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7495] Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
      19/07/2010 09:30:55 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7490] subinstaller: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
      19/07/2010 09:30:55 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7495] chown of /Library/Frameworks/Adobe AIR.framework completed with status 0
      19/07/2010 09:30:55 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7490] subinstaller: chown of /Library/Frameworks/Adobe AIR.framework completed with status 0
      19/07/2010 09:30:55 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7495] chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
      19/07/2010 09:30:55 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7490] subinstaller: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
      19/07/2010 09:30:55 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7495] chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status -1
      19/07/2010 09:30:55 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7490] subinstaller: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status -1
      19/07/2010 09:30:55 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7495] Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/airappinstaller to /Applications/Adobe/Flash Player/AddIns/airappinstaller/airappinstaller
      19/07/2010 09:30:55 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7490] subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/airappinstaller to /Applications/Adobe/Flash Player/AddIns/airappinstaller/airappinstaller
      19/07/2010 09:30:55 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7495] Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/digest.s to /Applications/Adobe/Flash Player/AddIns/airappinstaller/digest.s
      19/07/2010 09:30:55 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7490] subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/digest.s to /Applications/Adobe/Flash Player/AddIns/airappinstaller/digest.s
      19/07/2010 09:30:55 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7495] Execution complete; beginning commit phase
      19/07/2010 09:30:55 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7490] subinstaller: Execution complete; beginning commit phase
      19/07/2010 09:30:55 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7495] Deleting /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0/temp
      19/07/2010 09:30:55 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7490] subinstaller: Deleting /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0/temp
      19/07/2010 09:30:55 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7495] Deleting /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1/temp
      19/07/2010 09:30:55 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7490] subinstaller: Deleting /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1/temp
      19/07/2010 09:30:55 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7495] Deleting /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp2/temp
      19/07/2010 09:30:55 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7490] subinstaller: Deleting /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp2/temp
      19/07/2010 09:30:56 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7495] Commit complete
      19/07/2010 09:30:56 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7490] subinstaller: Commit complete
      19/07/2010 09:30:56 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7495] install complete
      19/07/2010 09:30:56 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7490] subinstaller: install complete
      19/07/2010 09:30:56 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7495] begin quitting
      19/07/2010 09:30:56 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7490] subinstaller: begin quitting
      19/07/2010 09:30:56 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7490] Elevated install completed
      19/07/2010 09:30:59 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7490] Elevated install failed (2038)
      19/07/2010 09:30:59 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7490] runtime install entering error state: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Error #2038" errorID=2038]
      19/07/2010 09:31:00 /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[7490] begin quitting
      19/07/2010 09:31:37 /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/MacOS/Adobe AIR Installer[7522] UI SWF load is complete
      19/07/2010 09:31:38 /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/MacOS/Adobe AIR Installer[7522] UI initialized
      19/07/2010 09:31:44 /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/MacOS/Adobe AIR Installer[7522] begin quitting
      19/07/2010 09:33:25 /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/MacOS/Adobe AIR Installer[7539] UI SWF load is complete
      19/07/2010 09:33:25 /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/MacOS/Adobe AIR Installer[7539] UI initialized
      19/07/2010 09:33:28 /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/MacOS/Adobe AIR Installer[7539] begin quitting
