RH8 Search results - can sort by title be for all found?
Guest
Jul 19, 2010 Jul 19, 2010
The new Search capabilities of RH8 are impressive.  However, we have popular searches where the results could be 50 topics and our users are used to looking for the desired file by alphabetical order.  Now results are limited to 10 per screen and clicking 'title' just sorts the 10 displayed.  Rank is not helping them in this case.
Is there a way to get more than 10 to a results screen....or to sort 'all found' in alphabetical order?
Thank you for suggestions!
479
Aug 18, 2010 Aug 18, 2010
Hi Teri.
I can tell you how you can get more than 10 to a result screen:
- In the folder of the generated WebHelp, open the file "whform.js" (I'm doing it with MS Visual Studio 2008);
- Click "Ctrl + f" to open the search window;
- Search the line "var gnMaxRslt = 10";
- Overwrite "10" with the number you want (I think 99 is the maximum)
- Save the file
- Open your project, and it should work.
Attention: do not generate the project, because this line you just altered will be overwritten again with the standard number (maybe this can be overruled somehow, but I don't know how).
Hope this helps!
Greetings,
Kurt.
Guest
Aug 19, 2010 Aug 19, 2010
Hi Kurt,
Turns out that if you generate with Skins, the user then gets a field on the Search panel that allows them to chose how many results to display - 1-99 and that's incredibly popular since each person is in control.  Its just not documented well that you need to use the Skins feature to get this.
Thanks for replying - have a great day!
RoboHelp Documentation
Download Adobe RoboHelp
