Platform: PC/Windows XP SP2
Adobe: Illustrator CS3 (13.0.2)
Is it possible to release all compound paths in an illustration at the same time (and if so - how)?
I receive drawings from engineering in either PDF or CGM format, which I edit in Illustrator and save as AI. I have to release compound paths in order to delete specific parts of the drawing.
This isn't difficult, but it is very time-consuming because the CGM(or PDF)-to-Illustrator conversion results in quite a few compound paths.
Thanks - I appreciate your help,
Dan
Select all, go to Object>Compound Path>Release.
Sorry -- I forgot to mention that I tried that; some of the compound paths were released but there were still quite a few that weren't...
Hmm...That's always worked for me. Are the ones that aren't getting released part of a clipping mask, or locked, or on a different layer, etc?
None of the above... I'll spend some time to see if I can figure out what the un-released paths have in common & repost if I figure it out. Thanks - I really appreciate you replying so quickly.
Are they all compound paths or are some of them compound shapes?
Try release/expand compound shape?
Hi jesseham,
Yeah, they are all compound paths. If I ever resolve this, I'll leave a post. Thanks,
Dan
Are they grouped?
SOUNDS LIKE THOSE OBJECTS ARE GROUPED, PRESS CTRL-SHIFT-G
thanks for the help, no need to shout.
Use this script
var doc=activeDocument;
var sel = doc.selection;
var len = sel.length;
while(len--)
if(sel[len].typename ==="CompoundPathItem"){
sel[len].selected=false;
alert("Only non-compound items are selected.");
