37 Replies Latest reply on Apr 12, 2012 12:19 PM by Peter Grainge
    Illegal character error on good filename
    kjc90 Level 1
      I created a new RoboHelp project and tried to insert a graphic named Timeline.jpg. I got the following error:
      Unable to rename file, "Timeline.jpg".
      The filename contains illegal characters.
      I tried inserting a graphic that I had used in a previous RoboHelp project and got the same error. Then I opened a previous RoboHelp project and was able to successfully insert the Timeline.jpg graphic into that project.
      I'm on Windows XP and RoboHelp 8. I would really like to avoid having to re-install RoboHelp, but I'm not sure where to look to troubleshoot this error message. Any help on this matter would be greatly appreciated.
      Thanks.
        • 1. Re: Illegal character error on good filename
          RoboColum(n) Level 5
          Hi kjc90 and welcome to the RH community.
          I'm wondering if the project name is at fault here. Can you tell us what the project title is?
          Read the RoboColum(n) for mutterings on RoboHelp, Technical Communication Suite and technical communication.
          • 2. Re: Illegal character error on good filename
            kjc90 Level 1
            Sure. The project name is: Online Guide to Performance Management
            Is it possibly too long?
            • 3. Re: Illegal character error on good filename
              It is longer than any project title I've ever used but it isn't too long. It also doesn't contain any special characters which I thought might be the issue. Is the project on a network drive?
              • 4. Re: Illegal character error on good filename
                kjc90 Level 1
                It's not on a network drive, it's on my hard drive. I tried creating a project with a shorter name and importing a graphic and I still got the same error message.
                • 5. Re: Illegal character error on good filename
                  Gravenstein Level 2
                  And it's not source-controlled, I presume?  When inexplicably odd behavior occurs, the two basic all-purpose fixes I have my writers try are 1) Reboot the PC, and 2) Rebuild the cpd file. If that doesn't work, then we dig deeper.
                  This fixes a *lot* of weird problems.
                  G
                  • 6. Re: Illegal character error on good filename
                    kjc90 Level 1
                    It's not source controlled and I knew enough to try rebooting, but that hasn't helped.
                    I'm new to RoboHelp and have been learning as I go. Therefore, I have limited knowledge of the cpd file, but would it really need rebuilding as soon as I create a project and try to insert a graphic into the first topic? If so, I'll look into rebuilding it.
                    In the meantime, I figured out something that makes it work.
                    Thanks for your response.
                    • 7. Re: Illegal character error on good filename
                      kjc90 Level 1
                      I figured out something that enables me to insert a graphic now.
                      Previously, I created the RoboHelp project in my Human Resources folder on my hard drive where I already have a couple of RoboHelp projects. This morning, I created a folder on my hard drive named Human Resources New and created a project in that folder. I can now insert graphics into this project.
                      Since any new project I create in the Human Resources folder won't allow me to insert graphics, I figure the error has something to do with that folder or the other projects in that folder. While I am slightly curious about the problem with the folder, I'm just glad I don't have to re-install RoboHelp.
                      Thanks for your input on this matter.
                      • 8. Re: Illegal character error on good filename
                        Captiv8r Adobe Community Professional & MVP
                        Hi there
                        Perhaps try attaching the image to this thread? If you can do this I'd be happy to download it and see if I get the same issues when attempting to insert into one of my own RoboHelp projects.
                        In this rare case, I'm advising to use the actual Attach function as opposed to my normal advice to insert the image inline.
                        Cheers... Rick
                        • 9. Re: Illegal character error on good filename
                          kjc90 Level 1
                          Thanks for the offer, but I'm pretty sure you wouldn't have any problem inserting the graphic. Since I was able to insert the graphic into one of my other RoboHelp projects and I'm not able to insert ANY graphic into this RoboHelp project, the graphic isn't the problem. It's something with the project itself or the folder where it resides.
                          Creating the project in a new folder seems to have resolved the issue.
                          • 10. Re: Illegal character error on good filename
                            NL_Derek-GsBV5a Level 1
                            Did anyone ever make progress on this?
                            A colleague is now unable to import images to her project (RH8.02, CHM output, Windows XP, local disk, no source control); she gets 'Unable to rename file, "SAXS_1_32_slit.png". The filename contains illegal characters'. Other images give a similar message.
                            I can import the image to a test project on my PC; her project is quite large (some 3000 topics) so I don't want to copy it to my PC if I can avoid it.
                            What strikes me as odd is that RoboHelp has no need to rename anything. It should simply copy the image to the project directory and insert it into the HTML. We can verify that the image is copied in OK; she just can't import it.
                            Jeff `jonestech' described a similar problem in http://forums.adobe.com/message/2390997#2390997
                            Obviously we tried zapping the CPD and rebooting -- no help. Any ideas?
                            --- Derek
                            • 11. Re: Illegal character error on good filename
                              NorBec Level 1
                              We're having trouble with this too.  Any solutions?
                              • 12. Re: Illegal character error on good filename
                                LarryTX
                                We're having the same problem. With three copies of RoboHelp 8 HTML running in the office (all under Windows XP Pro), two of us can insert images with absolutely no problem, and the third gets an "illegal characters" error on virtually every image. In fact, I'm able to insert the very same images with no problem at all, while my co-worker gets the error message. We've done all the usual, including rebooting, deleting the CPD file, and so on.
                                I guess our next step will be to re-install RoboHelp. It does seem like this is becoming a a more pervasive problem.
                                A copy of the image is attached, although it shouldn't be the source of the problem because I can import it with no problem.
                                • 13. Re: Illegal character error on good filename
                                  Gravenstein Level 2
                                  Did your colleague try inserting a graphic into a test project that was placed in a totally separate folder? This would be the fix used by the original poster. If that works, then I'd try copying the project (minus cpd) into a new location and trying again.
                                  HTH,
                                  G
                                  • 14. Re: Illegal character error on good filename
                                    NL_Derek-56V59O Level 1
                                    In January I posted that a colleague had this problem. The beastie has now hit another colleague, so that 40% of our team is suffering.
                                    Did anybody ever get a workaround?
                                    --- Derek
                                    • 15. Re: Illegal character error on good filename
                                      Peter Grainge Adobe Community Professional (Moderator)
                                      I don't see anyone in this thread saying they have tried renaming the CPD and reopening the project. Just wondering if something got screwed up there.
                                      Maybe also time to copy a project from someone with the problem to someone who is OK. Does the problem persist?
                                      @petergrainge
                                      • 16. Re: Illegal character error on good filename
                                        Now now, Peter, it's a bit early in the day but both LarryTX and I clearly stated the we had tried the CPD route.
                                        Unfortunately these are pretty big projects (3000 topics) so copying is not a five-minute job. And my vacation starts tomorrow so I don't have time until the middle of August. Johan (my colleague) is monitoring this thread and will try any useful ideas.
                                        --- Derek
                                        • 17. Re: Illegal character error on good filename
                                          You win on CPD, sorry I missed that.
                                          Zipping up a 3000 topic project and putting it on a network shouldn't take long though.
                                          Alternatively, if you want Johan to send it to me, I'll take a look.
                                          @petergrainge
                                          • 18. Re: Illegal character error on good filename
                                            Bang! bang! bang! That's the sound of the bug being nailed to the wall !
                                            It turns out that there was an apostrophe (') in a folder name in the path (not the filename at all). When I renamed
                                            D:\author_df\_MyNotes\RHtests\oldMyProduct\Generic
                                            into
                                            D:\author_df\_MyNotes\RHtests\oldMy'Product\Generic
                                            I was unable to import an image. I changed the name back and I could import OK.
                                            We had no problems with RoboHelp X5, so it's presumably appeared since then. Interestingly Windows allows the apostrophe -- see grab
                                            That'll help to assure me of a relaxed vacation
                                            --- Derek
                                            Message was edited by: NL_Derek
                                            • 19. Re: Illegal character error on good filename
                                              Johnt555 Level 1
                                              I'm getting the same error.
                                              This happened after I "upgraded" to 8.0.1.204 this morning.  Worked fine yesterday before the upgrade.  Now I can't insert any images at all, even ones I had inserted to the project earlier.
                                              It says, "Unable to rename file," but I'm not trying to rename it at all.
                                              Beats me...I'm at a standstill now.
                                              • 20. Re: Illegal character error on good filename
                                                johndaigle Level 4
                                                It's extremely important that you now update to 8.0.2.208
                                                You'll find it here:
                                                http://www.adobe.com/support/robohelp/downloads.html
                                                Then return here if your problem still isn't fixed.
                                                John Daigle
                                                Adobe Certified RoboHelp and Captivate Instructor
                                                www.showmethedemo.com
                                                • 21. Re: Illegal character error on good filename
                                                  Johnt555 Level 1
                                                  Yes, I did that - download 8.0.2.  Problem persists...
                                                  Did you see my note that I can insert images as long as they're in the Robo "Gallery?"
                                                  But, it's the message, "Unable to rename file," that sounds like a bug, you know?  Didn't ask Robo to rename a file.
                                                  Meanwhile the work-around helps...although my directory structure is going to be messed-up.
                                                  And THANKS, btw!
                                                  John
                                                  • 22. Re: Illegal character error on good filename
                                                    Johnt555 Level 1
                                                    Here's an update:
                                                    I copied an image into Robo's "Gallery," clicked Insert>>Image and that worked.
                                                    Any advice from the "robotic sages" out there?
                                                    • 23. Re: Illegal character error on good filename
                                                      johndaigle Level 4
                                                      I did not see anything about a Gallery reference from you up-thread but down below??? I'm a bit confused now. This thread was started in 2009 and is getting a bit long in the tooth
                                                      Is your problem that you are not able to import images, or is it that you are interrupted by illegal character errors as shown by NL_Derek in post 18?
                                                      If you can import from the Gallery (where we know there are no mis-named folders) maybe you were trying to insert the original image from a mis-named folder? Honestly I don't know.What is the image format and does it display correctly once it's in your project?
                                                      This should not be a problem. Once you insert your image from the Gallery or anywhere else, it is automatically copied to your RoboHelp Project folder. From the Images pseudo-folder (as Rick calls it) in Project Manager you can then locate it and move it to any project subfolder you like by dragging and dropping.
                                                      John
                                                      • 24. Re: Illegal character error on good filename
                                                        johndaigle Level 4
                                                        Just to be clear also. Did you do the "Rename the .cpd file and reboot RoboHelp to recreate it?" as referred to by Peter up-thread?
                                                        • 25. Re: Illegal character error on good filename
                                                          Johnt555 Level 1
                                                          No, but I will.
                                                          Thank you, again.
                                                          John
                                                          • 26. Re: Illegal character error on good filename
                                                            Johnt555 Level 1
                                                            The problem remains.  I get the "Unable to rename"because of "illegal characters."  I get this even though I'm not trying to rename anything, just inserting a new, properly-named image from the same folder I was previously able to insert images from the day before.
                                                            I've gone back and traced the entire folder path and file names...no spaces or illegal characters.  I've also checked to make sure I have access to the image folders.
                                                            The reason I think it might be a bug is that this began to happen after I downloaded the update.  I've been able to continue by saving the images to Robo's "Gallery" folder.  From there, no problem.
                                                            I now have 8.0.2.208
                                                            • 27. Re: Illegal character error on good filename
                                                              Johnt555 Level 1
                                                              I found the answer I was looking for here:
                                                              http://forums.adobe.com/thread/433500
                                                              Plus, I removed RB7.
                                                              THANKS for everyone's help.
                                                              • 28. Re: Illegal character error on good filename
        RoyceSA1 Level 1
        Hey John. Glad to see you solved it. However, the link to the thread you mention is *this* thread? Was this what you meant to do? What specifically was the magic solution? Also, can you tell if removing RoboHelp 7 affected the solution, or was it coincidental?
        • 29. Re: Illegal character error on good filename
        Johnt555 Level 1
        Sorry that I wasn't more specific in reporting my solution.
        I cannot say that the deletion RB7 helped because I had done that before making my other changes.  Another website that I had visited suggested that Robo sometimes has a problem when a previous version still exists, so I can't say that removing it solved the problem.
        Previously, all the project files were in a folder on my desktop, several layers deep.  BeforeI upgraded to v.208 I did not have a problem inserting images and I never got the "illegal character name" or "cannot rename" errors.  AfterI upgraded the problems began.  BTW, I had checked the file path back to the image locations to make sure there were no spaces, illegal file names, etc.  So I knew the errors were bogus.
        After the upgrade I also noticed that all of the images I had previously inserted remained viewable in Preview Topic, but ALL of the images disappeared when I looked at the project after compilation.  At that time I was able to insert new images by saving them to the Gallery folder of RB8.  Perhaps I may have been able to insert them from another, nearby folder...I don't know.
        AfterI deleted RB7 I figured, heck, why not make everything clean and simple and copy the whole project from the desktop folder to a new folder in the root of "C."  When I re-opened the project everything was okay - back to normal.
        If I can suggest anything from my experience it would be that clean, simple directory structures are what RB-8.208 likes most and if you get too far away from RB's project folders you may get similar errors.
        Hope this helps, and thanks again for your assistance!
        John
        • 30. Re: Illegal character error on good filename
        Rob in Cleveland Level 1
        PROBABLE SOLUTION:
        I don't know if this is your issue, but I had this same problem and this was the solution for me. RoboHelp hates special characters. If anywhere in the file path of the image or the project -- from C:\ on out -- there is an apostrophe or an ampersand or any special character in a folder name, the image import will crap out even if there are no special characters in the image name itself. I had to change a folder name in my directory tree and the import worked immediately. Good luck.
        • 31. Re: Illegal character error on good filename
        Ms Lee Anne Ward Level 1
        I took the spaces out of the directory name, and was able to place the previously-unplaceable graphic! What weird, demented developer at Adobe was responsible for this bizarre requirement?
        Lee Anne
        • 32. Re: Illegal character error on good filename
        In Tools > Options do you have the Use Underscore in File Names field ticked or cleared?
        You haven't told us what "previously-unplaceable graphic" you are referring to. This seems to be your first post in this thread so we have no idea what problem you are referring to. What were you trying to do that gave you a problem with a space in the folder name?
        What version of RoboHelp are you using?
        @petergrainge
        • 33. Re: Illegal character error on good filename
        Peter,
        Use Underscore is checked. The issue was a space in the folder name. Once the space was removed, the problem was solved.
        The previously-unplaceable graphic was any of a number of simple .png files. No special characters or spaces in the names of the files.
        “This seems to be your first post in this thread so we have no idea what problem you are referring to.” Strange, as I was replying to a response in a thread that specifically dealt with not being able to place graphics (this one), but getting an error indicating illegal characters in the file name. On my screen, my reply is clearly shown as the last reply in that thread.
        The problem was seen with RoboHelp 9.02.271.
        Lee Anne Ward, PMP, BSLS, BSME
        Technical Writer
        • 34. Re: Illegal character error on good filename
        Yes I could have been clearer, still jet lagged. What I meant was I was not clear exactly what steps YOU were following, there are many posts in this thread.
        Not sure quite why this problem arises, as you can see it is a while since this thread was started and I know since then there have not been other reports.
        @petergrainge
        • 35. Re: Illegal character error on good filename
        I understand about the jet lag, although I’ve not had to deal with it for many years.
        Apparently, the problem still occurs. It may be that, since the reply before mine, there was a known and posted solution, there hasn’t been a need for reports. I was basically just confirming that the solution that was proposed does work for me.
        Oh, how I miss the days when Blue Sky did RoboHelp. It was so easy to use, back then. That was 1998!
        cid:image001.png@01CD00F6.A02A6460
        Technical Writer
        Doble Engineering
        www.Doble.com<http://www.doble.com/>
        617-926-4900
        • 36. Re: Illegal character error on good filename
        Gigenny123 Level 1
        Hi Peter,
        Although this is my first post, I have been using Robohelp for many many years.   I experienced the same issue as what has been discussed in this thread since 2009.  The illegal characters (e.g. apostrophe) that my co-worker inserted in his directory structure for the French project made it impossible to insert any graphics (we were getting the same error as described by others).  This series of posts gave me the information I needed to troubleshoot the issue.
        After removing the apostrophes from the top level folder of the directory structure (a very simple 2 minute fix), the images could once again be inserted without any issues.  We are using Robohelp v  9.0.1.262
        I am wondering if this issue has ever been reported to the Adobe Robohelp techies and if they will ever fix it?
        Thanks for everyone who's ever posted.  It took me approx. 45 mins from beginning to end to troubleshoot this issue because of this knowledge base/forum.
        Genevieve Richer
        Consultant
        Ottawa, Ontario
        • 37. Re: Illegal character error on good filename
        If in doubt about whether a job has been done, do it yourself.
        The more people who report a bug or request a feature, the more likely it is to be actioned. Please follow this link.
        http://www.Adobe.com/cfusion/mmform/index.cfm?name=wishform&product=38
        @petergrainge
