Hi all,
I tried to reinstall the Adobe Reader Plus on one of my machines and it would not work, so I deinstalled the Communication Suite 2.
When I tried to reinstall it (only the RH8 and Reader Plus) it would say that no products were installed, though it was confirming my choice, and actually not installing anything.
I thought that perhaps that machine is somehow corrupted, so I tried to install it on a different machine, however the same thing happened.
Am I doing something wrong? I deselected all the other components from the Communication Suite 2 because I do not use them, and wanted to install just the RH8 and the Reader Plus so I selected them to be installed fully.
Thank you,
Bogdan
I checked the DVD's and I think they are damaged a little bit.The DVD's also are not too reliable to install.
I will get new onese and will see if they work better than the ones I have right now.
Otherwise I will wait untill Adobe is coming with a better solution.
Thank you all
It seems that the installation DVD's for the Communication Suite 2 trial that I received are deffective, so we can consider this issue closed.
Thank you for your help,
Bogdan
