Show 3 replies
1. Re: How to select a para without para marks?
[Jongware] Jul 22, 2010 4:37 AM (in response to Praveen10)app.selection[0].paragraphs[0].characters.itemByRange(0,app.selection[0].paragraphs[0].cha racters.length-2).select();
(This does not work with the final paragraph in a story when it has *no* closing hard return, and you need to check what happens with inline tables and/or footnotes, as these tend to throw off proper character counts.)
2. Re: How to select a para without para marks?
Harbs. Jul 22, 2010 9:12 AM (in response to [Jongware])Another method which basically does the same thing (but written a little easier to read, and more complete):
var para=app.selection[0].paragraphs.item(0); var startChar = para.characters.item(0); var endChar = para.characters.item(-1).contents == "\r" ? para.characters.item(-2) : para.characters.item(-1); app.select(para.texts.itemByRange(startChar,endChar));
Harbs
3. Re: How to select a para without para marks?
Marc Autret Jul 22, 2010 9:21 AM (in response to Praveen10)As a first try, here is a function which might work in various contexts:
function selectParagraph(/*Paragraph*/par, /*?bool*/includingEndmark) //---------------------------- // Returns FALSE if the target is invalid, else returns TRUE // - Supports single Paragraph, or Paragraph range, or everyItem() // - If the target is empty (no character), move the insertion pt within { var p, ips, c = -1; try { p=resolve(par.toSpecifier()); if( p && p.constructor == Array ) // converts everyItem into a range p=p[0].parent.paragraphs.itemByRange(0,-1); ips = p.insertionPoints; } catch(_){} if( !ips ) return false; // invalid specifier if( !includingEndmark ) c -= ((c=p.characters) && c.length && c[-1].contents=='\r'); ips.itemByRange(0,c).select(); return true; } //---------------------------- // Sample tests //---------------------------- var pars = app.activeDocument.stories[0].paragraphs; // Single paragraph //---------------------------- if( selectParagraph(pars[1]) ) alert( "Selection of the 2nd paragraph EXCLUDING end mark" ); else alert( "Unable to select the 2nd paragraph" ); if( selectParagraph(pars[1], true) ) alert( "Selection of the 2nd paragraph INCLUDING end mark" ); else alert( "Unable to select the 2nd paragraph" ); // Paragraph range //---------------------------- if( selectParagraph(pars.itemByRange(1,2), true) ) alert( "Selection of paragraph range [1,2] INCLUDING end mark" ); else alert( "Unable to select the paragraph range [1,2]" ); if( selectParagraph(pars.itemByRange(1,2)) ) alert( "Selection of paragraph range [1,2] EXCLUDING end mark" ); else alert( "Unable to select the paragraph range [1,2]" ); // everyItem() support -- equiv. to itemByRange(0,-1) //---------------------------- if( selectParagraph(pars.everyItem()) ) alert( "Selection of every paragraph EXCLUDING end mark" ); else alert( "Unable to select every paragraph" ); if( selectParagraph(pars.everyItem(), true) ) alert( "Selection of every paragraph INCLUDING end mark" ); else alert( "Unable to select every paragraph" );@+
Marc
