I just got a new laptop and I'm unable to open ANY projects or import custom skins into RH8. I was on 8 previously, but I cannot open my projects nor can I import skins. I click on Skins>import>choose the skin, then nothing. It's like it's not even recognizing I'm doing anything. Any suggestions?
If you can't open a project, how are you getting to the File > Import > Skin menu item? Also can you give us some additional information about the laptop (e.g. the OS).
I've had to recreate all the projects from scratch, since I'm getting an error message that all my projects are not recognized help projects.
I'm on a Lenova Thinkpad
T400. I'm on Xp Windows 2007.
I'm also seeing similar behavior.
Using RH8, I've created a new project and right-click skins, import, select the saved custom skin, click ok and nothing happens. Has anyone found a cause/solution or have any ideas I can give a try?
