Help with new Table Style formatting??
Jul 20, 2010 Jul 20, 2010
I am having all kinds of problems using the new table style formatter.  I am not a RoboHelpHTML 8 expert (I did better with version 5).  I am trying to create a table with 3 columns, the first of which is left-justified, the last 2 are centered.  The header (row 1) is bolded and centered.  Also I want all the lines the same thickness.  I created the table using the standard SimpleGridBlack... Image2.jpgThere actually is a line across the top... don't know what happened to it.  Next I ran WebHelp and the picture there looked identical to one here.  Then I duplicated the SimpleGridBlack and applied the new style to this table.  Next I started making changes to the new style.  I selected the First Row and made all columns centered and bolded.Image4a.jpgSince I want columns 2 and 3 to be centered, I next selected even columns for changing.Image5a.jpgThis took care of column 2.  Then I selected the last column for change.Image6a.jpgThis took care of column 3.  However, the results were not what I expected.Image10.jpgThe upload does not quite show the picture correctly.  The line under the "gg" is actually there and the lines separating columns 1-2 and 2-3 in row one are actually there.
Image15.jpgHowever, the first line of column 3 is not centered and lines A-B-C, D-E-F, A-D-G, and B-E-H are thicker than the other lines.
I certainly hope someone can help.  It has taken 2 days and getting a web site unblocked for my use to get to the point that I am at now.  This is a document that I have to get out this week and I have a lot of tables to change.  Thank you for any help.
Virginia
1.3K
Participant , Jul 23, 2010 Jul 23, 2010
Tables in RH 8 are annoying to say the least.
First your alignment issues, you should have a look in the HTML itself to make sure it is being applied correctly. The amoun of timers I have told text to centre, and align and the HTML behind just wont do it. So check here quick.
As for the double-lines that you seem to be getting around the table, this may help but Im not sure as your using styles around them now.
If you select the table as a whole, right click Table Properties > Table tab > Table Bor
The lines I stated are missing are there in the post, but were not there while I was inputting the post.
Following the same as above, this is the result I received for the real tableImage22.jpgNo centering anywhere.
Jul 22, 2010 Jul 22, 2010
While I appreciate the answers that have appeared at the top of the thread, I have no idea as to how to get to them or what points are.  I have not been to this forum before and seem to be unable to get an adequate reply from the people answering the email at Forum Etiquetts etc. - which is the only place I can find that actually lets you send an email to someone (little good that appears to do me).
I cannot see any answers to your posts. Maybe you are referring to the stuff about points being available? If so, just ignore that like most folks do.
Answers are only given in the thread and the reason you are not getting any is that the table editor is not intuitive is difficult to describe. I'll try to look at your problem tomorrow.
@petergrainge
Thank you. I sincerely appreciate it.
Virginia
Prompt me if there is no answer by Monday.
@petergrainge
Ok. Thanks again.
Participant ,
If you select the table as a whole, right click Table Properties > Table tab > Table Borders > Turn off ALL table borders. Then go back to that Table tab > Cell Borders > set the thickness youwant to use here, this will apply all round and give you the lines you want.
good luck.
Jul 24, 2010 Jul 24, 2010
Thanks. I will give the borders a try. I did check the HTML code and it says align=center. However, I have not checked the class. Some of my images weren't centering and I found out it was the class designator.
I've never before had to go in and correct the HTML code more than I've had to do with this version. I had v5 before and liked it just fine. I don't care for all the bells and whistles as it usually just complicates things and doesn't make them any easier. We're seriously considering changing software.
Virginia
I want to thank you again. My borders now look good - using Table Properties as you suggested. I've mostly force-fed my tables, not using the models any more than I had to. I've also accepted less than what I would them to look like.
It has taken me 3+ days to get my document mostly back into the shape it was in before I started using 8. There are some things I still cannot do. I have changed html code until I am dreaming about it. I think I told you that the images were aligned=center, but the best that I could figure is that the class-function is over-riding the alignment specification. So I found a class that was alignment center and changed all(!!) my images to that class.
Just wanted to say... thanks again.
Virginia
Jul 25, 2010 Jul 25, 2010
It looks like you are fixed now except centering. Take a look at Using RH8 on my site, item 24.
@petergrainge
Participant ,
the only other thing i could think of with the images in the table not centering...
If I were you Id look at the style thats applied in that cell/table and align the text to centre, even though there is no text it might help.
as well, set the cell/table to align its contents centre, you can use the quick button in RH, but also go through the table properties window and double check it through there.
if that fails, you could create a new style, that is centred by default and try applying that.
good luck. hope it helps.
Jul 28, 2010 Jul 28, 2010
Thank you so very much for all your help. I appreciate your time and effort.
Virginia
RoboHelp Documentation
Download Adobe RoboHelp
