Hi All,
I'm using AEGP_SetStreamValue to update the value of the effect parameter. The Edit menu shows Undo Set Stream flags. Now if I Undo, nothing happens. I tried AEGP_StartUndoGroup() before I set the stream value. I end the undo group after setting the stream value using AGP_EndUndoGroup(). Still Edit menu is showing Undo Set Stream Flags.
What is the issue? Any ideas?
Dheeraj.
