I was wondering if it is possible to apply a style sheet to a project after importing it from a Word document in RoboHelp8.
When I import a document in a RoboHelp8 project, it does not let me apply a style sheet at that point, therefore I was wondering if it would be possible to apply the desired style sheet to the whole project after the importing procedure is finished.
Thank you,
Bogdan
Select all the topics in the Topic List, right click for Properties, then select the style sheet from the Appearance tab.
Good luck,
Leon
Good luck,
Leon
Thank you Leon.
I will try this.
Bogdan
It would have been too straightforward to be that simple.
I tried to select multiple topics in the Project Manager and it does not work.
It works only one by one.
Sorry, I did as you suggested Leon and it worked.
Thank you sou much!
No, not in the Project Manager.
I said: "Select all the topics in the Topic List, right click for Properties, then select the style sheet from the Appearance tab."
Good luck,
Leon
