JSON call - PHP to CFML translation
Participant ,
Jul 27, 2010 Jul 27, 2010
Hi all,
I am working on communicating to an api of a domain register, now i found the following code that is voor php:
$domain = "test.nl";
$params = array();
$request_url = "https://httpapi.yoursrs.com/v1/domains/" . urlencode($domain) . "/check";
$response = sendRequest($request_url, $params, "tester", "pass1234");
print_r($response);
Now i need to change this to cfml code and i tried:
<cfset jsondata = {
login_handle = "username",
login_pass = "password"
<cfhttp
url="https://httpapi.yoursrs.com/v1/domains/test.nl/check"
method="post"
result="result">
#SerializeJSON(jsondata)#
</cfhttp>
Still i have no luck, does anyone can translate that php to cfml?
Advanced techniques
1.4K
Valorous Hero , Jul 28, 2010 Jul 28, 2010
"pass1234");
A quick google search suggests sendRequest is not a standard php function. What does the sendRequest function do and how is json involved ...?
Valorous Hero ,
"pass1234");
Participant ,
From the API doc this is the code how it should be used:
Request
Method: POST
URL: https://httpapi.yoursrs.com/v1/domains/example.com/check
BODY:
"login_handle":"example_user",
"login_pass":"********"
Response
"command":"domain:check",
"handle":"example.com",
"code":1000,
"msg":"Command completed successfully",
"error":[
"params":{
"svTRID":"158759-2-yoursrs",
"response":{
"avail":"0"
So this JSON markup needs to be placed inside the body of the post request.
Any idea's? Or examples somewhere?
I can find pieces of info around the net but nowhere a full example...
Valorous Hero ,
Try using cfhttpparam type="body"
http://livedocs.adobe.com/coldfusion/8/htmldocs/help.html?content=Tags_g-h_10.html
Participant ,
Tried that also like:
<cfhttp url="https://httpapi.yoursrs.com/v1/domains/test.nl/check" method="post">
<cfhttpparam type="body" name="login_handle" value="namevalue">
<cfhttpparam type="body" name="login_pass" value="passvalue">
</cfhttp>
#cfhttp.fileContent#
Keep getting error about:
{"command":null,"handle":null,"code":2400,"msg":"Command failed","error":["Internal Server Error. resulted in the following error: array_key_exists() [function.array-key-exists<\/a>]: The second argument should be either an array or an object"],"params":[],"svTRID":null,"response":[],"children":[{"command":"Internal Server Error.","handle":null,"code":2400,"msg":"Command failed","error":["array_key_exists() [function.array-key-exists<\/a>]: The second argument should be either an array or an object"],"params":{"errno":2,"errstr":"array_key_exists() [function.array-key-exists<\/a>]: The second argument should be either an array or an object","errfile":"\/home\/live\/httpapi\/v1\/index.php","errline":54},"svTRID":null,"response":[]}]}
Valorous Hero ,
From what you have described, the encoded json should be sent as the body of the request. So there should be only one tag with type="body".
Participant ,
OK, tried this:
<cfset jsondata = {
login_handle = "namevalue",
login_pass = "passvalue"
<cfset jsondata = SerializeJSON(jsondata)>
<cfhttp
method="post">
<cfhttpparam type="body" name="params" value="#jsondata#">
</cfhttp>
Now i get:
{"command":null,"handle":null,"code":2003,"msg":"Required parameter  missing","error":["Parameter 'login_handle' missing.","Parameter  'login_pass'  missing."],"params":{"LOGIN_PASS":"passvalue","LOGIN_HANDLE":"namevalue","handle":"test.nl"},"svTRID":null,"response":[]}
Message was edited by: marco van den oever
Valorous Hero ,
It looks right.  Try it without the name "params". Maybe that is confusing things?
Participant ,
Ah got it, i used:
<cfset jsondata = {
That should be:
<cfset jsondata = {
"login_handle":"namevalue",
"login_pass":"passvalue"
So the JSON markup was not correctly set...
Thanks for correcting and guiding me!
Valorous Hero ,
Yes, but calling SerializeJSON() before you send the packet should generate the correct mark up.  Maybe it was a case sensitivity problem.  (Notice how CF converted the keys to upper case in the error message). Just for grins try setting the keys with assocative array notation.  Any difference ?
<cfset jsonData = {}>
<cfset jsonData["login_handle"] = "namevalue">
<cfset jsonData["login_pass "] = "passvalue">
<cfset jsonData = SerializeJSON(jsonData)>
Participant ,
I tried and now it works! That is the correct way of doing so
Documentation
