Regrading connection through WSDL with SAP R3 system
Avatar
Level 1
The form is created using ALD8.0.we need to get data from SAP and populate them to field dropdown.
Trying to establish connection using WSDL link ..
But when we add a data connection in .XDP file of this form in ALD8, it is raising below error. If we edit the file in Adobe Live Cycle ES the data connection correctly asks for user authorization to connect to SAP system and gets added correctly.
Again in ES not able to retrieve the values ... from the data base..
Avatar
Former Community Member
Have you tried disabling security on the WSDL and testing the connection with LiveCycle Designer 8.0?
I cannot remember if LiveCycle Designer 8.0 enabled passing credentials to the SOAP endpoint as is possible with LiveCycle Designer 9.
Steve
Avatar
Level 1
Hi Steve,
Can you please advise How to disable the security on the WSDL.
Please let me if this will be possible with 8.1 or not.
Avatar
Disabling SAP WSDL security has nothing to do with LiveCycle Designer. It is an SAP issue. You will have to talk to an SAP administrator. SAP transactions that are exposed via SOAP may be secured at the endpoint and on the transaction level.
Steve
