18 Replies Latest reply: Feb 4, 2013 12:07 PM by SudiScott RSS
    How to "unthread" a text frame?
    craigatadobe12345 Community Member
      I have a document with continuous text
      threading from start to finish. I want to interrupt the text threading, and create a separate page where the threading stops just before that page. Could someone tell me how I would do this?
        • 1. Re: How to "unthread" a text frame?
          Joel Cherney Community Member
          Well, you didn't tell us which version of ID you're using, but if you know where your scripts are in your version of ID, most of them have a script called "SplitStory" that does exactly what you want.
          (I really hope that you're the last person to use this document and that you're not doing this because you're unfamiliar with how well-constructed InDesign documents function; there are very good reasons to leave stories threaded. However, it's quite possible that your reasons to want to split the story into individual frames are even better reasons...)
          • 2. Re: How to "unthread" a text frame?
            MT.Freelance Community Member
            Need more input!
            Are you wanting to split each linked text frame into a separate text frame and RETAIN THE CONTENTS of each frame?
            If so, the script mentioned will do that. Once run with any of the frames selected, all frames in the series become unlinked, yet retain the content.
            Are you wanting to keep the linked text frames before and after the split linked?
            This is done by clicking on the INPORT of the text frame, and then clicking on the frame itsel (the icon will change to a broken link).
            This splits that text frame, and all subsequent frames from the original series of linked frames and leaves the content of the frames in the first set, possibly resulting in overset text in the last frame. The new series that has been split off will be empty, but still linked.
            If you need the content of the second set to be retained, then you need to copy the contents before you break the link and then paste it into the new set once it is split off.
            • 3. Re: How to "unthread" a text frame?
              Also, do not forget that there is a
              HELP document available for InDesign.
              • 4. Re: How to "unthread" a text frame?
                MT.Freelance wrote:
                Need more input!
                MT gets the "actually read the original post" award for the day.
                • 5. Re: How to "unthread" a text frame?
                  Thanks everyone for responding. I'll clarify my situation which should help.
                  I'm using InDesign CS5.
                  My documents are actually part of a book. Each document contains four or five chapters with continual text flow threaded, and there are also some tables in each document.
                  I have two reasons for wanting to un-thread. One is that I want each chapter to begin new on a page, so that when the text before it changes position during the formatting process, it won't move the chapter front page.
                  Similarily, I want my tables to be on one page, and not move when the text before them moves during the formatting process.
                  Does that make sense?
                  • 6. Re: How to "unthread" a text frame?
                    Both of these can be handled without breaking the threaded story (tables can be told to not break across pages in the Table Properties, and there are multiple ways to force chapters to start on a new page, the most obvious of which is a frame break right before the end of a chapter).
                    But, that being said, it turns out that the SplitStory script will do what you want. I don't know if it is automatically installed with CS5, or if you have to go pull it off the install discs yourself. But it's in there, somewhere.
                    Lastly: don't use it unless you're 100% certain that you will be the last person who will ever be working in this file.
                    • 7. Re: How to "unthread" a text frame?
                      I'll go with this method, since there will probably be someone else working with this book before it's all finished. Thanks very much.
                      • 8. Re: How to "unthread" a text frame?
                        No problem. And, on behalf of the anonymous folks who might be working on this book after you, thank you very much.
                        • 9. Re: How to "unthread" a text frame?
                          P Spier CommunityMVP
                          I'm really late to this thread, but you can do this manually pretty easily, too, if you want to isolate each chapter into a new thread (though telling the chapter title style to start on the next odd page is probably easier). Click the outport on the last frame you want in the first thread, then click inside the frame to break the thread. The rest of the story will be overset and the following frames will be empty, but threaded.
                          Put the cursor after the last character in the last frame and press Shift +End to select everything from there to the end of the story. Cut and paste into the empty frames. Repeat for the next chapter.
                          Thinking about it, this might actually be all that the split story script is doing.
                          • 10. Re: How to "unthread" a text frame?
                            Nope, split story looks like it splits each frame.
                            I'm pretty sure  Dave Sunders posted a script a few years ago, though that automates the break thread, cut, paste I just described.
                            • 11. Re: How to "unthread" a text frame?
                              cara_emily Community Member
                              Spit Story seems to be the thing that will help me, for my situation too...I have a large document and am trying to format each page slightly differently, and indivdually.  I placed all the text in at once though and it is threaded all the way through--everytime I hit returm or space or backspace the whole doc shifts.  How do i find Split Story? is this really the right thing for me??
                              thanks
                              cara
                              • 12. Re: How to "unthread" a text frame?
                                John Hawkinson CommunityMVP
                                Cara:
                                Open the Scripts panel (in Window > Utilities in CS5.5, slightly different places in some earlier versions) and find it under Application > Samples > JavaScript
                                • 13. Re: How to "unthread" a text frame?
                                  [Jongware] Community Member
                                  If there are no pressing reasons to physically split a threaded story, I'd rather leave it as it is and use ID's Frame Break or Page Break codes to force content onto a new page. You didn't really put hard returns in each frame to go to the next page, did you?
                                  • 14. Re: How to "unthread" a text frame?
                                    Felipe - dualpixel Community Member
                                    In this case you can use Break Frame - in Windows > Utilities > Scripts Panel. Different Split Story this script just break one frame from story, right?
                                    • 15. Re: How to "unthread" a text frame?
                                      I used the Split Story Script and it broke all the frames, which I thought was great until I started working with the text and did need to space things around and then the single page frame became too small for a page but the text didn't move to the next page or push the next frames over. what do I do now?  How can I get frames to extend into the next page without attaching all the frames againn??
                                      I am afraid I need some more "tutorial-like" help, i've never made such a long document--this will be 50 or 60 pages.
                                      thanks so much for the help!!
                                      • 16. Re: How to "unthread" a text frame?
                                        Daniel Flavin Community Member
                                        If you have overset text, click the (red) overset box to load the curser. Go to a next page and place the loaded text.
                                        Optionally, and not recomennded, you could place the text curser in the frame, hit ctrll + y to enter story view and select > cut the remaining text to the clipboard. Not recomennded, but you might appreciate knowing about story view.
                                        • 17. Re: How to "unthread" a text frame?
                                          SudiScott Community Member
                                          Your responses should be deleted.
                                          • 18. Re: How to "unthread" a text frame?
                                            Do
                                            • Respect others.
                                            • Assume good faith.
                                            • Share what you know.
                                            • Be good to "newbies." We were all new once.
                                            • Encourage each other; recognize and praise good work.
                                            • Attract and honor good, knowledgeable people.
                                            • Ask for help and help others in return.
                                            • Set a good example.
                                            Don't
                                            • Infringe copyright. Submit only original material that you create and own.
                                            • Use obscene or offensive language.
                                            • Personally attack people, their edits, or their comments.
                                            • Rant or otherwise harass, abuse, or intimidate others.
                                            • Post anything you don't want the world to see. This is a public space.
                                            • Post content that violates Adobe Community Help guidelines or Adobe.com Terms of Use in any manner.
                                            • Be afraid to identify errors or shortcomings in Adobe content. We need to know!
                                            • Discuss legal issues or Adobe patents.
                                            • Discuss information covered by a nondisclosure agreement, such as prerelease features.
