I'm trying to connect on Flash Builder 4 to my BlazeDS RDS server, and after being prompted for RDS username/password (which I mark as not required) I get a Server error window with the useless following error text "┴└". (or some characters that look like those).
I'm pretty sure I've everything well configured because if I go to my browser and try to reach:
https://localhost:8443/myServer/CFIDE/main/ide.cfm
I get the "HTTP Status 405 - HTTP method GET is not supported by this URL" which is supposed to be telling you things are up and working.
My JEE configuration is: JBoss 5, Spring 3, spring-flex 1.0.3, blazeds 3.2.0.3978
I think my configuration pretty much follows all manuals I found in the internet, including this one:
http://www.jamesward.com/2010/01/11/flash-builder-4-data-wizards-with-java-spring/
When I set the flex server, server location, I''ve set:
Root folder: c:\jboss-5.0.1.GA\server\default\deploy\myServer.war ( <---- is an exploded war)
Root URL: https://localhost:8443/myServer
Context root: /myServer
Output folder: c:\jboss-5.0.1.GA\server\default\deploy\myServer.war\apk-debug
My services-config.xml on JEE has the following conf, in case it is relevant:
<channel-definition id="my-amf" class="mx.messaging.channels.SecureAMFChannel">
<endpoint url="https://{server.name}:{server.port}/{context.root}/messagebroker/amf" class="flex.messaging.endpoints.AMFEndpoint"/>
<properties>
<add-no-cache-headers>false</add-no-cache-headers>
</properties>
</channel-definition>
Any idea of what that this error means? What shall I do to connect my Flex project to the services? I've been googling for three days, but didn't find anything...
Thank you very much indeed for your time
http://forums.adobe.com/message/2986585
does this help ?
No it doesn't.
I corrected the error endpoint class from "flex.messaging.endpoints.AMFEndpoint" to class="flex.messaging.endpoints.SecureAMFEndpoint", but still the problem is happening.
My application is working actually. The problem is just that I can't use the Data/Services tab on FlashBuilder, because when I click on 'Connect to Data/Service...' and I select BlazeDS as the Service Type, and then I say "No Password required", as in the tutorials I found in the internet, then I get a error window that has the title "Server Error", and the following unfriendly error message: ┴└
(Or, maybe some other odd characters that look like those to me).
File a bug for this issue with the steps to reproduce along with the error screen shot.
Please attach the project to the bug or attach the sample testcase which reproduces this issue.
this is still not fixed
