I have been experimenting with the Resource Manager in RoboHelp. I get the concept that there is a central repository for the images, snippets, etc. where you can drag and drop said items into a topic. This is really helpful since there are several authors using the same graphics. (Now if they could autosync changes that would be the baum).
What's frustrating, and maybe not doable, is that once you select an image from the RM it copies the image to the root directory of the project. Which is what I don't want. This just creates one big mess at the root. I have set it up that the image layout in the project mirror the image layout in RM. For example:
images/buttons and images/screen_shots
I don't want all my images at the root when they come over. Is there a way to specifically tell the RM when copying from the buttons folder in RM to place that image in the buttons folder in the project or at least ask me where I want it?
CJ
Hi there
Unfortunately it pretty much is what it is at this stage. If you don't like where the images end up, you are free to move them after you insert.
If you would like to see it differently, please consider submitting a Wish Form to ask for the changes.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7 or 8 moments from now - $24.95! |
I was afraid of that. Thanks for replying Rick.
So just because I have no other person to brain storm with. I setup the image repository (as I call it). Drag and drop images into the project which makes a copy at the root. I don't like that many files at the root, nor with the amount of images that we'll have, do I want it that loosy goosy, talk about hard to maintain.
I also have 2 newbie RH Authors and want to teach them good habits from the start. I'm pretty OCD when it comes to organization and I always have an image folder then sub folders from there. Usually just 2 sub folders 1 for buttons and icons and another for screen shots, but at least you can find what you're looking for pretty quickly.
So here are the 3 ways I see handling this situation:
1) Leave it (easiest solution, but then a lot of files at the root)
2) Close the project at the end of the day and move the images via Windows explorer, but then I have to relink all the images (quick for moving all images though)
3) Create a folder in images called buttons and screen shots in the project manger and drag and drop the images from root into appropriate folder within RoboHelp (the links will change, however, you'll have to move the images one by one by one)
Any other suggestions? Or ideas?
Thanks.
CJ
We've always concentrated on naming files and images with prefixes related to functionality, such as these for the software client installation:
client_install.htm
etc.
I learned years ago to avoid folders like the plague; this forum is riddled with hundreds of postings on the nightmare that can be wrought with the use of folders. Granted, some users have no trouble with them. I, however, prefer to err on the side of caution.
Good luck,
Leon
Leon -- so you don't use any folders? I must admit I don't use a lot, but for easy maintenance I use a few. With the software programs we document with, especially this current client, the same screens can be used for multiple functional areas so adding a prefix isn't always easy to determine. We have 182 buttons so far (all start with button_<name> or icon_<imagename>) and 100 screen shots. The screen shots I do require the functional area prefix as that usually is pretty standard per user role, but the topics are conditionalized based on role so the prefix wouldn't work well there.
I've put images at the root before, but when you have 500 images it's a bit overwhelming when searching for an image. I like the resource manager, at least when you click on an image it shows you a thumbnail. If the Project Manager Pod did that without double clicking then closing the image that would make it less overwhelming than guessing which screen shot you want. Buttons are pretty easy to figure out, but not always.
While we only have 182 images, there will be 3 more projects coming online in the next week and we're only 25% into documenting. So there's going to be a lot in each project. If I'm overwhelmed by it, can you image the newbies with no RH experience?
I will ponder the images at root and maybe the renaming of some of the images with better prefixes. It would make it easier when selecting a button or screen shot from the PM and not worrying about the extra step moving it from the root to the image folder (neither which is easy to explain).
CJ
May I suggest opening a WinExplorer window on the project folder, set to thumbnails, whenever you work on the RH project?
You might also complete a RH Wish Form to get that idea out there for the RH developers.
Good luck,
Leon
We can't avoid folders in our projects, and we have experienced our share of folder-related crashes. Over the last three years, I have found that creating folders once and leaving them alone works quite well. Changing folder names, adding and deleting folders (especially at the root level) - these cause havoc.
I like your option 3 - drag new images from the root to the image folder - but that touches the root.fpj file (a list of the topics and folders in the project folder). So I agree with Leon - it's risky.
That leaves the wish form - and it's a good idea. In fact, I will send one myself.
Good luck,
Elisa
I'm really surprised to see the negative vibes about using folders. I use them extensively and wouldn't work any other way. Comes from once having a manager who used the skip approach to file. Throw everything into the skip and dig out what you needed, man could that waste time.
Hi folks
Like Peter, I too am surprised with the folder comments. I've used folders that are nested reasonably deep and never had a problem.
Could the issues be surrounding using Source Control? (You know, make a change in the source and lose all control!)
Cheers... Rick
Hi Rick,
This doesn't address the original post at all, but I wanted to mention my experience with RH folders. I used to have significant problems with renaming/nesting folders in two cases:
That is, the issues I used to experience with folders had nothing to do with source control, and once I adjusted my work habits a bit, folders have worked seamlessly.
The original post has been answered, albeit not with the answer that MeWrite would have wanted so I hope MeWrite doesn't mind us exploring the folder issue.
The CPD will grow just by the addition of topics and other information it gathers so even without folders, the CPD will ocasionally need to be deleted. It's normal and because it is really an Access database and they do need compacting from time to time. Explained in more detail in Snippets on my site.
I suspect the broken links referred to were not so much the number of folders but the cumulative length of the path name.
\folder1\folder2 is 16 characters as is \abcdefgehijklmn and that is all that matters, the number of characters where there is a limit of 255.
Well, I always did like a good discussion.
I don't go beyond 3 clicks for the user (although exceptions have been made from time to time), and I don't usually go below 3 folders deep in my structure, if nothing more than ease of maintenance for me.
I have found that when things start to go wonky, deleting the CPD file usually fixes it.
Oh, and to answer everyone's question (I hate when threads go off into ether and you rarely know what the original poster does after asking the question), I am probably going to leave the images at the root and have stricter naming prefixes. I hate to do this and my OCD is going to drive me batty, but with the tight deadline and 2 new writers I think this is easier for them. I meet with them on Tuesday and plan on showing them all 3 ways, but I think I know what they will want. I'm going to push for option 3 to drag and drop once they are in the root, but I suspect I'm gonna be looked at like I'm crazy.
Who knows? Maybe I am 🙂
Thanks for the discussion, the help, the advice, and the links to the wish form.
CJ
Hey, if they think you are crazy, they are less likely to argue with you. Has its upside.
