SOLVED
Image field in repeating Subform
Avatar
Level 2
I created a flyer and wanted the ability to enter pictures on the fly.  Well, I used an image field to do this however users need to be able to insert up to 4 images.
I know the way to do this is a repeating subform so I put the image field in one and set the options to "Repeating..etc. ; 4 max ; 1 count".  I added a subform control that is built in with livecycle to add/delete fields.  Well, after testing..it does not work..Nothing happens when I click + or -. Additionally I need to be able to have the repeating image field appear to the right or left of the one already there and then have both centered horizontally on the page..
The form is a "missing Persons" type form so I need it to be as fool proof as possible to the users.  I don't know how to upload the form but is anyone out there that knows more than I willing to help?? I can't figure out what I am doing wrong.  The form is otherwise complete except for this little issue..
Brenda
1 Accepted Solution
Avatar
Correct answer by
Former Community Member
By default subforms are set to flow top to bottom. You can change it to flow Western Text (left to right). That setting is on the subform objects Subform tab and it is called flow direction (of course it will only appear on flowed subforms).
paul
Avatar
Correct answer by
paul
Avatar
Level 2
Thanks Paul, I did set the flow to Western Text. Actually when I changed the initial count to 3 to test where they would show up the repeated image fields showed up below. I changed the underlying subform to flow as well but still nothing..maybe it’s the code I'm using from the auto buttons in Adobe?
Brenda
__
paul
Avatar
Can you send the form to LiveCycle8@gmail.com and I will have a look. Please include a description of the issue in th email.
Paul
The following has evaluated to null or missing: ==> liqladmin("SELECT id, value FROM metrics WHERE id = 'net_accepted_solutions' and user.id = '${acceptedAnswer.author.id}'").data.items [in template "analytics-container" at line 83, column 41] ---- Tip: It's the step after the last dot that caused this error, not those before it. ---- Tip: If the failing expression is known to be legally refer to something that's sometimes null or missing, either specify a default value like myOptionalVar!myDefault, or use <#if myOptionalVar??>when-present<#else>when-missing. (These only cover the last step of the expression; to cover the whole expression, use parenthesis: (myOptionalVar.foo)!myDefault, (myOptionalVar.foo)?? ---- ---- FTL stack trace ("~" means nesting-related): - Failed at: #assign answerAuthorNetSolutions = li... [in template "analytics-container" at line 83, column 5] ----
