I have FB4 installed as an eclipse plugin to Eclipse Galileo. I'm moving on to Eclipse Helios (32bit). How do I deal with the FB4 eclipse plugin? Do I have to reinstall the entire thing? If so, do I first uninstall it?
Glad to hear that.
When you have a sec Gary, would you mark this question as "answered". I think only the original person who posed the question can make that change (or a forum admin perhaps).
-Chris
You shouldn't need to install anything - just copy the link file from your Galileo dropins folder, and paste it into the dropins folder in Helios.
Let me know whether or not this works smoothly for your configuration.
-Chris
Sweet! It worked flawlessly. Thanks
Glad to hear that.
-Chris
Is Flex Builder 4 supported on Eclipse 3.6? If so the doco should be changed. The webpage says it's only supported on Eclipse 3.4 and 3.5 - does that mean "only supported on these versions" or "not supported on versions lower than 3.4"?
Flash Builder 4 is only supported on Eclipse 3.4 and Eclipse 3.5.
Andrew,
Product Manager, Flash Builder
Any updates on this? I don't want to use an old version of Eclipse with the new version of Flex.. And I can't create a Flex J2EE project in Helios.
The preview release of Flash Builder 4.5, currently available on Adobe Labs (http://labs.adobe.com/technologies/flashbuilder_burrito/) supports Eclipse 3.6.
Andrew
On my Mac Snow Leopard, I am using the Flash Builder Pro plugin with 32 bit STS 2.5.1 which I am pretty sure is Helios.
...it works most of the time, but is not so stable.
I haven't been able to find a Flex 4.5 plugin version.
Burrito (FB 4.5) installs a plug-in utility you can use for plugging into your own copy of Helios. You can find this utility in the folder named "utilities", in the same folder where you installed Burrito.
Also, Burrito comes bundled with Helios.
-Chris
Thanks, Chris!
Do you know when we'll get a newer build than the 10/25/10 one ? The Flex Team blog hasn't been updated in a while...
