I created a flyer and wanted the ability to enter pictures on the fly. Well, I used an image field to do this however users need to be able to insert up to 4 images.
I know the way to do this is a repeating subform so I put the image field in one and set the options to "Repeating..etc. ; 4 max ; 1 count". I added a subform control that is built in with livecycle to add/delete fields. Well, after testing..it does not work..Nothing happens when I click + or -. Additionally I need to be able to have the repeating image field appear to the right or left of the one already there and then have both centered horizontally on the page..
The form is a "missing Persons" type form so I need it to be as fool proof as possible to the users. I don't know how to upload the form but is anyone out there that knows more than I willing to help?? I can't figure out what I am doing wrong. The form is otherwise complete except for this little issue..
Brenda
Solved! Go to Solution.
Total Likes
By default subforms are set to flow top to bottom. You can change it to flow Western Text (left to right). That setting is on the subform objects Subform tab and it is called flow direction (of course it will only appear on flowed subforms).
paul
Total Likes
paul
Total Likes
Thanks Paul, I did set the flow to Western Text. Actually when I changed the initial count to 3 to test where they would show up the repeated image fields showed up below. I changed the underlying subform to flow as well but still nothing..maybe it’s the code I'm using from the auto buttons in Adobe?
Brenda
__
paul
Total Likes
Can you send the form to LiveCycle8@gmail.com and I will have a look. Please include a description of the issue in th email.
Paul
Total Likes
