In Captivate 5:
Among others, I have set the following preferences prior to recording:
The text captions in the resulting recording show the following:
Any ideas as to why some of the text caption prefs are not being applied to the recording (while some are)?
Many thanks.
Hello,
Can you explain what you exactly changed before recording? In the Preferences you can choose a style for each of the captions during recording. Did you check those styles in the Object Style Manager?
Lilybiri
Absolutely. Here are screen captures to clarify:
Settings in Prefs and Object Style Manager prior to recording:
Properties of text caption in resulting recorded project (notice some settings match while the three identified [Size, Vertical alignment, and Display for] do not):
Hello,
This can be confusing, I agree. You set the preferences for Text Captions, that means for captions you create yourself on a slide. But from your question and screenshot I do detect that the captions were created by CP5 during a capture? Those default settings are elsewhere in the Preferences. Did you check those? I post a screenshot.
Lilybiri
I have checked the preferences and regardless of where I change those three properties (size=12, vertical alignment=top, and timing=rest of slide), the recording reverts to font size=19, v alignment=middle, and timing=specific time). Because some of the changed settings are being applied (font style, justification, font color) and these other three are not, I am inclined to go ahead and report this as an issue.
Hi there
Definitely report any issue you feel is a Bug! Link to the Bug Reporting form is in my sig line.
Cheers... Rick
Helpful and Handy Links Begin learning Captivate 5 moments from now! $29.95 Captivate Wish Form/Bug Reporting Form |
Rick, I have submitted a bug report. Many thanks for yours and Lilybiri's assistance.
Any update to this bug that was reported? I am having similar issues. I set the Object Style Manager Preferences without a project being open to (font size 20😞
Recording Defaults show pointing to Deafult Caption Style (font size 20😞
Recording ends up with this (font size 31😞
I don't want to have to go and change each recorded text box from 31 to 20 pt font. Any ideas on how to fix?
Sam
