Hi All,
I've been creating DSCs in which I set the supports-export element to "true". This is supposed to trigger my DSC to be exported whenever a LiveCycle archive is created (of an application which makes use of my DSC obviously). But somehow this does not work. I can rename the lca to a zip to look into it and my files are never there. Does this functionnality actually work or am i doing something wrong?
Here's the contents of my component.xml:
<component xmlns="http://adobe.com/idp/dsc/component/document">
<component-id>Test</component-id>
<version>1.0</version>
<supports-export>true</supports-export>
<services>
<service name="Test" orchestrateable="true" title="Test">
<implementation-class>com.livecycle.test.Test</implementation-class>
<auto-deploy major-version="1" minor-version="0" category-id="Test" />
<operations>
<operation name="Test1" method="Test1">
<input-parameter name="test" type="int" required="true" title="test">
<supported-expr-types>Variable,XPath,Literal,Template,</supported-expr-types>
</input-parameter>
<output-parameter name="output" title="output" type="int">
<supported-expr-types>XPath,Variable</supported-expr-types>
</output-parameter>
</operation>
</operations>
</service>
</services>
</component>
As always any help is greatly appreciated!
Nic
Solved! Go to Solution.
Total Likes
You still need to create a component reference (New->Component Reference) for it to be included in your lca.
Jasmin
Total Likes
Jasmin
Total Likes
Great, this works perfectly then.
Thank you!
Nic
Total Likes
