1 Reply Latest reply: Aug 7, 2010 7:00 AM by rproulxmtl RSS
    File Character Limit with Acrobat 9 Pro File Naming
    rproulxmtl Community Member
      I'm experienceing an issue that I'm sure was not there with previous versions of Acrobat. When printing a Word file with a long name to Acrobat (File->Print -> Adobe PDF) the original file name is being shortened and the end replaces by a series of "..."s.
      If I print a document named
      "The_Quick_Brown_Fox_Jumps_Over_The_Lazy_Dog_Sleeping_Under_The_Shadey_Tree.doc"
      it will be converted to Acrobat as
      "The_Quick_Brown_Fox_Jumps_Over_The_Lazy_Dog_Sleeping_Under….pdf"
      The original file's name is only 74 characters. I thought that Acrobat could create file names with up to 255 characters?
      Is there a setting I can modify to have Acrobat keep the original file's long name?
      I'm using Acrobat 9 Pro (part of the CS5 Suite) with Vista64.
      Thanks.
      Russell
        • 1. Re: File Character Limit with Acrobat 9 Pro File Naming
          Solved: It appears to be a Microsoft Word issue as it doesn't occur with other apps. When using the built-in 'convert to PDF' tool within Word the file name length is respected. It's an older version of Word (Word 2002 SP3). I printed a file using the same name length with Wordperfect and it works fine.
          I know this isn't a Word help forum, but if anyone does have a solution to offer it would be appreciated :-)
          Russell
