1. Re: Launching flash panel from menu other than Window -> Extensions
Peter Celuch Aug 8, 2010 12:14 AM (in response to Peter Celuch)So far, I'm only able to instal flash dockable panel(s) through manifest.xml but they are thrown in special submenu and act as two separate panels (no panel group association)
I can launch palette with new Window("palette") but it's not dockable. I've looked at Panel class and it seems like dead end - all read-only properties ..
There has to be a way. I've seen flash extension that was launched from custom menu and after clicking the menu item, panel group opened, in each panel SWF extension.
2. Re: Launching flash panel from menu other than Window -> Extensions
Harbs. Aug 8, 2010 12:29 AM (in response to Peter Celuch)Yes, and yes.
You need to create a startup script to create the menu in the startup script. The script can launch as many extensions as you'd like.
The only straight-forward way I know to launch extensions from an external script, is by invoking the menu item of the panel.
FWIW, You will probably get better answers on Extension Builder / CS SDK in the CS SDK forum: http://forums.adobe.com/community/creativesuites/cs_sdk
Harbs
3. Re: Launching flash panel from menu other than Window -> Extensions
Peter Celuch Aug 8, 2010 12:35 AM (in response to Harbs.)Sorry, I didn' realize I'm shouting in the wrong room. I'm gonna move my problems over there
