I am attempting to use cfhttp to make a call to an SSL
encrypted URL. I am recieving the following cfdump when i attempt
to connect.
struct
Charset [empty string]
ErrorDetail I/O Exception: peer not authenticated
Filecontent Connection Failure
Header [undefined struct element]
Mimetype Unable to determine MIME type of file.
Responseheader
struct [empty]
Statuscode Connection Failure. Status code unavailable.
Text YES
I am able to successfully reach this URL through my
development environment (coldfusion developer edition server) with
no issues, on my production machine i get the above error. Every
reference i can find on the web is that the keystore does not have
the required certificates installed. I know this is not the issue
because i have never done this on my development environment where
it works with no issues. However, to rule out the possibility i
have used the keytool to import both certificates on the website i
am attempting to connect to into the certificate store and still
have the above cfdump. Also I have taken the certificate store from
my development environment and replaced the one on my production
machine with no change in the results either.
I am at a complete impasse at this point. I could really use
some assistance. Both servers are Coldfusion 7.
