I'm in the process of configuring hudson to automate our managed environment builds for our lcds projects I've got the code compiling currently through the <fb.exportReleaseBuild project="testESN" /> task using the eclipse ant build. does any know if the fb.exportReleaseBuild task or if there is another task to generate/deploy the model as part of the build? our CM environment has its own lcds server. I will be migrating the current build to a standard ant build using mxmlc task. I noticed in the .fml file the <FbEntityProperties> hard wires the rootUrl to a specific host.
thanks in advance
chuckles
Solved! Go to Solution.
Total Likes
You can deploy the model by copying it to the WEB-INF/datamodel directory of your web application.
There is currently no Java client to deploy a model to a running server.
Total Likes
Total Likes
thanks, I will modify my hudson script to act accordingly
Total Likes
