Using RH8 / Windows XP;
Four projects, by same writer, converted to RH8 from 7.
3 of the projects had a similar issue, which I am posting about.
Using a Master Topic on all 3 projects.
After the conversion, viewing a topic in design mode the header appears empty, and very large, no text. Fills the screen. Need to scroll down to see the topic text.
Also, the TOC was gone in two of the three projects.
I have inserted a topic HTML at the end of this posting from two of the projects in case that helps.
One is a french translation and has a lot of XML tags regarding the language. I'm not sure where that even comes from. The other is in English and has just the normal XML tags in the "head".
Both projects have the same issue with the huge, blank header on the Design page. But compiled they look normal except as noted below.
In the compiled Help the topic named "PAC Config" shows no border AND no background color. All topics are the same.
In the compiled Help the topic named "French PAC" shows no border in the Header/Banner, but does have the background color. All topics are the same.
I'm at a loss, and not really sure what else to include. Any help would be greatly appreciated.
Regards
Joe
PAC CONFIG
<?xml version="1.0" encoding="utf-8" ?>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<meta name="template" content="PAC Configuration 4.0.htt" />
<meta name="topic-status" content="Ready for Review" />
<meta name="generator" content="Adobe RoboHelp 8" />
<title>An Overview of the PAC Configuration Process</title>
<link rel="StyleSheet" href="../default.css" type="text/css" />
</head>
<body>
<?rh-placeholder type="header" ?>
<h1>An Overview of the PAC Configuration Process</h1>
<p style="font-weight: bold;">The Configuration File</p>
<p> </p>
<p>Library<span style="color: #ff0000;">•</span><span style="font-weight: bold;">Solution</span>
PAC lets you create a number of different sets of PAC display pages to
suit your needs.  Each set of pages has a configuration file that
stores all the information about that set of pages – the content of each
page, the variables used, the way lists are displayed, and more.  For
example, you could create customized configurations to have General, Reference,
and Children's displays within the same library, or Main, South Branch,
and North Branch display for a library system.  Any number of combinations
are possible.</p>
<p style="font-weight: normal;"> </p>
<p style="font-weight: bold;">The Display Pages</p>
<p> </p>
PAC Configuration Utility</span> contains many display pages that are
generated by the parameters set in a PAC Configuration file.  You
can edit many of the display parameters through the PAC Configuration
program.  If you have expertise with HTML and JavaScript, you can
also use an HTML Editor and edit the contents of the display pages to
create HTML pages that can supplement or replace the existing display
pages.  The <span style="font-weight: bold;">PAC Configuration Utility</span>
program also lets you create user-defined HTML pages.</p>
<p> </p>
<p>The table below shows the <span style="font-weight: bold;">PAC Configuration
Parameters</span> expanded menus:</p>
<p> </p>
<p><img src="../PAC Config Parameters menu chart.gif" alt="" style="border: none;"
width="644" height="494" border="0" /></p>
<p> </p>
<p>   <span style="font-weight: bold;">PAC Configuration
Parameters</span> (continued)</p>
<p> </p>
<p><img src="../PAC Config Parameters menu chart 2.gif" alt="" style="border: none;"
width="643" height="341" border="0" /></p>
<p> </p>
<?rh-placeholder type="footer" ?>
</body>
</html>
FRENCH PAC
<head>
<meta name="Originator" content="ImportDoc" />
<meta name="OriginalFile" content="PAC_4.0_Help_FRENCH.doc" />
<meta name="template" content="PAC 4.0 Aide.htt" />
<title>Bienvenue</title>
<link rel="stylesheet" href="../PAC_4.0_Help_FRENCH.css" type="text/css" />
<style type="text/css">/*<![CDATA[*/
A:visited {
color: #0000ff;
A:link {
color: #0000ff;
/*]]>*/</style>
</head>
<body lang="EN-US" xml:lang="EN-US">
<div>
<h1><span lang="FR" xml:lang="FR">Bienvenue</span></h1>
<p style="margin-top: 6.0pt; margin-right: 0in; margin-bottom: 6.0pt;
margin-left: 0in;"><span lang="FR" xml:lang="FR">Bienvenue dans
le catalogue public en ligne (PAC) de votre bibliothèque.</span> <span
lang="FR" xml:lang="FR">Le catalogue PAC vous aidera à trouver ce
que vous cherchez dans votre bibliothèque, sans qu’il soit nécessaire
de vous rendre dans toutes les allées où VOUS croyez pouvoir trouver
les ouvrages qui vous intéressent.</span> <span lang="FR" xml:lang="FR">Le
catalogue PAC vous indique si l’article qui vous intéresse est disponible
ou mis de côté.</span> <span lang="FR" xml:lang="FR">Il vous permet
également de modifier vos renseignements d’abonné, comme votre numéro
de téléphone ou votre adresse électronique.</span> <span lang="FR"
xml:lang="FR">Vous pouvez aussi vérifier vos amendes et imprimer un
historique de vos prêts.</span></p>
margin-left: 0in;"><span lang="FR" xml:lang="FR">Il est plus facile
d’effectuer une recherche lorsque vous disposez de certaines informations,
comme un titre ou un nom d’auteur, mais même sans aucune information
précise de départ, vous pouvez trouver ce que vous chercher.</span>
<span lang="FR" xml:lang="FR">Lorsque vous avez inscrit ce que vous
cherchez, vous recevez une série de résultats et des informations
sur votre recherche.</span> <span lang="FR" xml:lang="FR">Si vous
ne trouvez pas exactement ce que vous cherchez lors de votre première
tentative, vous pouvez modifier vos critères de recherche et essayer
de nouveau.</span></p>
margin-left: 0in;"><b style="font-weight: bold;"><span lang="FR"
xml:lang="FR">Comment fonctionne le système?</span></b></p>
margin-left: 0in;"><span lang="FR" xml:lang="FR">Vous êtes-vous
déjà demandé d’où venaient les résultats obtenus d’une recherche?</span>
<span lang="FR" xml:lang="FR">Les informations disponibles dans le
catalogue PAC sont regroupées dans ce que nous appelons des fiches
MARC.</span> <span lang="FR" xml:lang="FR">Une fiche MARC se compose
de plusieurs champs.</span> <span lang="FR" xml:lang="FR">Tout d’abord,
on y retrouve un champ indiquant le titre de l’article, peu importe
qu’il s’agisse d’un livre, d’un DVD, d’un CD ou autre.</span> <span
lang="FR" xml:lang="FR">La fiche contient également des champs d’auteur,
d’éditeur, d’illustrateur, de sujet et de remarques concernant l’article.</span>
<span lang="FR" xml:lang="FR">Tous ces champs forment une fiche MARC
et les informations qu’ils contiennent sont traitées par le programme
du catalogue PAC pour vous transmettre les résultats désignant des
articles de votre bibliothèque.</span> <span lang="FR" xml:lang="FR">Vous
pouvez remercier vos bibliothécaires.</span> <span lang="FR" xml:lang="FR">C’est
grâce à leur travail constant que le catalogue PAC vous est offert.</span>
 </p>
margin-left: 0in;"><span lang="FR" xml:lang="FR">Maintenant que
vous savez de quoi il s’agit, nous pouvons commencer.</span></p>
xml:lang="FR">Premier pas</span></b></p>
margin-left: 0in;"><span lang="FR" xml:lang="FR">La première chose
que vous devez comprendre est comment naviguer dans le module d’aide.
Il a été conçu pour vous aider à exécuter les tâches les plus simples
et les recherches les plus complexes. Il vous indique également comment
accéder à votre dossier d'abonné afin que vous</span> <span lang="FR"
xml:lang="FR" style="font-family: Arial, sans-serif;">puissiez vous
aider vous‑même. Pour savoir comment circuler dans le catalogue PAC,
reportez-vous à </span> <span class="Hyperlink" lang="FR" xml:lang="FR"><a
href="Naviguer_dans_le_PAC.htm" style="font-family: Arial, sans-serif;">Naviguer
dans le PAC</a></span><span lang="FR" xml:lang="FR" style="font-family: Arial, sans-serif;">.
Si vous savez déjà comment circuler dans le PAC, passez directement
à </span> <span class="Hyperlink" lang="FR" xml:lang="FR"><a href="../Options_de_recherche/Aperçu_des_proc_dures_de_recherche.htm"
style="font-family: Arial, sans-serif;">Aperçu des procédures de recherche</a></span>
<span lang="FR" xml:lang="FR" style="font-family: Arial, sans-serif;">et
trouvez votre livre sans plus perdre de temps!</span></p>
margin-left: 0in; font-family: Arial, sans-serif;"><span lang="FR"
xml:lang="FR">Si vous désirez obtenir des informations supplémentaires
sur la façon de circuler dans le catalogue PAC, reportez-vous à </span>
<span class="Hyperlink" lang="FR" xml:lang="FR"><a href="../Barre_d%27outils_PAC/Aperçu_de_la_barre_d’outils_PAC.htm"
de la barre d’outils PAC</a></span><span lang="FR" xml:lang="FR">.</span></p>
</div>
<span style="font-size: 12.0pt; font-family: 'Times New Roman'; layout-grid-mode: line;"><br
style="clear: all;" clear="all" />
</span>
</body>
</html>
Peter Grainge has a lot of advice for RH7 to 8 conversions on his site (www.grainge.org). One of the things he's always asking is if you updated your RH8 install first with the sequential patches before opening the RH7 projects - that can eliminate a lot of issues right away.
Make sure you have a copy of your Project in RH7. Have you tried to install the service releases of 8.0.1 and 8.0.2? That might help you with your issues.
