I am having trouble figuring out how to apply margin notes
and graphics for dicumentation. I understand how to exclude them
from the online help generation, but I do not see an easy way of
creating margin notes or margin graphics for the generated document
itself. Does anyone have some idea on how this is done?
If I'm understanding you correctly, I think you would
accomplish this using tables. You would have two columns. One used
for Margin Notes and the other for text. You could then use Build
Tags/Build Expressions to hide or show the margin notes.
I have several different styles that create text in the
margin in my Word output using Frames. I use them for 'Trainer
notes' etc.
You need to define a style in your Word template with the
appropriate formatting (e.g. Frames etc) and then use a style in
RoboHELP which is then mapped to the template style.
The style in RoboHELP doesn't need to have any special
formatting - just so long as it is mapped to the style in your
template.
notes' etc.
template.
The pages I'm dealing with in RoboHelp are standard HTML. I
would like to output a PDF that contains a margin note. My batch
output is WebHelp and PDF.
