Bullet does not show correctly in WYSIWYG.
May 07, 2006 May 07, 2006
Hi All,
I'm currently using RoboHelp X5.
I use the .css file, which are already made, for a new project and the bullet style appears incorrectly in WYSIWYG. For example, if I apply the circle bullet, the square bullet appears in WYSIWYG. But If I see the topic in preview, it looks fine.
I'm not sure if it is related to the this bullet problem, when creating a new project, the errors occurred saying "An error occurred while trying to save data to <.../rhfontset.apj>" and "An error occured while trying to read data from <.../fhfontset.apj>"
Please help me with this problem, if anyone knows...
Thanks.
463
May 08, 2006 May 08, 2006
Welcome to the forum.
Where is your project stored, on your hard disk (good) or on a network drive (bad)?
Hi Peter,
My project is stored in my local hard..
Thanks.
May 09, 2006 May 09, 2006
Try creating another new project and see if you get the same error.
I created a new project and it has the same error.
Actually, I'm using the style sheet for the bullet and the list style for the bullet is specified "disc". If I change the style into square, it looks fine. Only the disc bullet style does not appear in WYSIWYG. One thing I don't really understand is that I've ever used the same style sheet and there was no problem then. There must be a font-related problem in my system, I just guess.
When you say you are getting the same error, do you mean just the wrong bullet or you also get the rhfontset.apj message?
Have you tried using a different style sheet to test whether that gives the same problem? Take a copy of the project using Windows Explorer and in the copy go to the topic list. Select all the topics and right click. Select Properties and you can apply the supplied style sheets.
Also test one of the supplied projects.
Sorry I won't be around much today so hopefully this helps or someone else can guide you.
RoboHelp Documentation
Download Adobe RoboHelp
